Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Mitsubishi rear projection tv when plugged in power led blinks 3 times then when i switch it on remains powered for about 2 seconds before switching back off again...
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
DO THE SELF CHECK THIS SET HAS: WHEN POWER LIGHT GOES OUT-----ON FRONT OF SET PRESS AND HOLD BOTH THE MENU AND INPUT BUTTONS FOR AT LEAST 5 SECONDS AND RELEASE BOTH BUTTONS. The power light will blink a two digit error code like: 2 blinks, 2 blinks, a pause and then repeat the code several times. Let me know what error code you find and I will tell you what it means. IF this told you something you did not know rate this solution as very helpful as I do this here for free. SD TECH
Posted on Sep 07, 2010
When the tv plugged up the power led blinks 3 times. When the power button is pressed the tv comes on for three seconds and turns back off. What could be the problem? Could this be a convergence problem?
Do the self check when power light goes out:
ON front of set (not remote) press and hold both the Menu and Input (Device) buttons at same time for 5 seconds or longer and release both buttons.
Power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know code.
SD TECH
Sep 24, 2010 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WD 52525
GOOD DAY;
THIS COULD BE YOUR PROBLEM:
1. Red status LED, self-diagnosis error 44, check for open F9A06 on the Power PCB part # 283P128050 on the Power PCB 2. Red lamp LED, self diagnosis error 34. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 930B921002 3. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature, this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 4. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector LE pin 3 and 4 on the Control PCB, if low suspect problems with the switches/buttons on the Control PCB part # 935D776001 5. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector LE pin 3 and 4 check good. Suspect the E2P PCB part # 934C121001 6. (LED does not stop blinking after plug in) Disconnect the USB connector from the card reader to the front from the Chassis, if the LED stops blinking after 70 seconds replace the Card Reader part # 299P271010. 7. (LED does not stop blinking after plug in) Disconnecting the USB connector from the Card Reader did not help. Remove connector FC from the FMT PCB and plug the unit in, if the LED stops blinking after 70 seconds with FC removed suspect a problem on the FMT PCB (part # 930B924002), if the LED keeps blinking with connector FC removed suspect a problem on the DM PCB (part # 934C116002). 8. (LED does not stop blinking after plug in) On the DM PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). See Service Tip VS-78A 9. (LED does not stop blinking after plug in) On the FMT PCB (part # 930B924002) check C8F19, C8F21, C8F22, and C8F27 (16V 1000 UFD 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). Good Luck, big IRISH.
Sep 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Red lamp light on
Good Day;
Most likely you have bad caps on the TV's power supply. The following will guide you in the correct direction to properly repair your TV. Good Luck, big IRISH:
1. Red status LED, self-diagnosis error 44, check for open F9A06 on the Power PCB part # 283P128050 on the Power PCB 2. Red lamp LED, self diagnosis error 34. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 930B921002 3. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature, this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 4. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector LE pin 3 and 4 on the Control PCB, if low suspect problems with the switches/buttons on the Control PCB part # 935D776001 5. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector LE pin 3 and 4 check good. Suspect the E2P PCB part # 934C121001 6. (LED does not stop blinking after plug in) Disconnect the USB connector from the card reader to the front from the Chassis, if the LED stops blinking after 70 seconds replace the Card Reader part # 299P271010. 7. (LED does not stop blinking after plug in) Disconnecting the USB connector from the Card Reader did not help. Remove connector FC from the FMT PCB and plug the unit in, if the LED stops blinking after 70 seconds with FC removed suspect a problem on the FMT PCB (part # 930B924002), if the LED keeps blinking with connector FC removed suspect a problem on the DM PCB (part # 934C116002). 8. (LED does not stop blinking after plug in) On the DM PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). See Service Tip VS-78A 9. (LED does not stop blinking after plug in) On the FMT PCB (part # 930B924002) check C8F19, C8F21, C8F22, and C8F27 (16V 1000 UFD 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C) .
Sep 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Wd 52725 52" mitsubishi
Good Day;
Bad news this TV has multi problems, check these:
Aug 31, 2008 | Mitsubishi WD-52725 52". Rear Projection...
We had thunder storms my tv 65613 has a green blinking light wont star
Good Day,mikeybecerra; TV wont come on mb try these 6 items, please pay attention to the blinking light (it's a code) : 1. Check for no 8.4 volts DC at pin 3 of PC9A10 on the Power PCB, if low or missing replace PC9A10 part # 268P058020. 2. LED does not blink at plug in. Check for 3.3-volts DC at connector RF pin 3 (system reset) if low or missing suspect the reset switch S7L20 part # 432P109010 on the Control PCB. 3. LED does not stop blinking after plug in. Verify the standby supplies, 12-volts at connector KA pin 17, 6-volts at KA pin 18 and the 28-volts at KA pin 19, if the supplies are present suspect the DM PCB part # 934C067001 4. LED does not stop blinking after plug in. Check C9B01, C9B02, C9B10, and C9B11 (1000 UFD 16) on the DM PCB, if they are bad replace them with part # 181P734030 (680 UFD 16 V). LED stops blinking after 70 seconds of plug in but will not power on. 5. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector RF pin 4 and 5 on the Signal PCB if low suspect problems with the switches/buttons on the Control PCB part # 935D736001 6. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector RF pin 4 and 5 check good suspect the E2P PCB part # 934C061001. Good Luck, big IRISH.
Jun 30, 2008 | Mitsubishi WS-65613 65" Rear Projection...
Slow blinking red light
Yes you can first try this:. Red status LED, self-diagnosis error 44, check for open F9A06 on the Power PCB part # 283P128050 on the Power PCB 2. Red lamp LED, self diagnosis error 34. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 930B921002 3. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature, this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 4. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector LE pin 3 and 4 on the Control PCB, if low suspect problems with the switches/buttons on the Control PCB part # 935D776001 5. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector LE pin 3 and 4 check good. Suspect the E2P PCB part # 934C121001 6. LED does not stop blinking after 70 seconds of plug in. Disconnect the USB connector from the card reader to the front from the Chassis, if the unit will then boot up replace the Card Reader part # 299P271010. 7. LED does not stop blinking after 70 seconds of plug in. Disconnecting the USB connector from the Card Reader did not help. Suspect the DM PCB part # 934C116002
Sep 11, 2007 | Mitsubishi WD-52525 52" Rear Projection...
TV NO TURN ON
Hello erraez, I would suggest that you first get a schematic for this set (either call the manufacture or go to a sams photofact site and order one). It sounds like you have a powersupply problem, the only way to make sure is to have someone or yourself check the power supply levels to determine what is happening. You will also need a multimeter for this task. If you do not feel comfortable doing this you can lok for a shop on fixya.com or find one in your neighborhood that will look at it and give you an estimate on what is wrong.
Sep 08, 2007 | Mitsubishi WD-52525 52" Rear Projection...
73" rear projection Mitsubishi TV
1. Check for no 8.4 volts DC at pin 3 of PC9A10 on the Power PCB, if low or missing replace PC9A10 part # 268P058020. 2. LED does not blink at plug in. Check for 3.3-volts DC at connector RF pin 3 (system reset) if low or missing suspect the reset switch S7L20 part # 432P109010 on the Control PCB. 3. LED does not stop blinking after plug in. Verify the standby supplies, 12-volts at connector KA pin 17, 6-volts at KA pin 18 and the 28-volts at KA pin 19, if the supplies are present suspect the DM PCB part # 934C067002 4. LED does not stop blinking after plug in. Check C9B01, C9B02, C9B10, and C9B11 (1000 UFD 16) on the DM PCB, if they are bad replace them with part # 181P734030 (680 UFD 16 V). 5. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature; this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 6. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector RF pin 4 and 5 on the Signal PCB if low suspect problems with the switches/buttons on the Control PCB part # 935D736001 7. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector RF pin 4 and 5 check good suspect the E2P PCB part # 934C061001
Sep 05, 2007 | Mitsubishi WS-73713 73" Rear Projection...
My TV won't turn on. The Green light just keeps on flashing
Jan 30, 2007 | Mitsubishi WS-73713 73" Rear Projection...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
