Question about Dell Delta Electronics CPU Processor Fan w/ Shroud D530 BFB1012H CPU Fan
MLTIPEL PROECESS EROOR
I have dell 640M i enter for Dell dognomic CD to cheek my PC and all thing is ok only CPU fan and process
1-Fan ERROR
2-CPU Multiple ERROR Cashe 2
my computer is work but not very fast and when i open any multimedia
games move song it is work and puse and work and puse . . .
pls inform me how can i fix this problem
my email
okah_20@hotmail.com
omer_algaity@yahoo.com
omer_algaity@skype.com
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 262 Answers
Sounds like your fan on your cpu is almost taken a dump common prombelm you better change it before it over heats and takes your cpu out ... lala linda
Posted on Jun 05, 2008
Assassins creed 3 on dell inspiron 640m
CPU: 2.66 GHz Intel Core 2 Duo E8200 or 2.66 GHz AMD Athlon II X4 620 CPU Speed: Info RAM: 2 GB
Not enough RAM!
OS: Windows Vista (SP2) / Windows 7 (SP1) / Windows 8 Video Card: 512 MB DirectX 9.0c-compliant with Shader Model 4.0 or higher (GeForce 8800 GT or Radeon HD 4850) Sound Card: Yes Free Disk Space: 17 GB
Jan 11, 2014 | Dell Inspiron 640m Notebook
I have a problem in my cdrom(dell inspiron 1525) it is giving eroor code as 0148 while diagnostic.plzz send me a good solution other than buying a new cdrom
Sorry, the error code indicates IDE ERROR: status which means that your CD drive is bad or the circuit which controls it (the motherboard).
Aug 08, 2011 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
Hi my dell INSPIRON/640m starts with Dell.com
try hitting the F8 button as it starts to boot you should get a screen with several options see if it will go into SAFE MODE or Last Known good Settings that worked try safe mode first,,,,,Good Luck
Jun 15, 2010 | Dell Inspiron 640m Notebook
Hi i have dell inspirion 531 desktop win xp sp3 installed. currently my machine OS not booting. after loading BIOS system restart again in loop. i tried chkdsk no errors also ran mem test, all pass. i have...
1.Reinstal the os with Good CD.
Even if not ok.
2.If u use 2 rams,then use a single ram.cheak it...
if not ok.Then Use other Ram only...
Even not ok
3.Cheak the Fan of cpu,It may be thermal problem.(Fan Must be rotate).So cheak it.
Feb 13, 2010 | Dell Inspiron 531s Desktop Computer
Dell inspiron 640m...laptop screen in back. it
Possible only 2 solutions 1,the inverter has gone out and the othere is a replacement screen!
Aug 08, 2009 | Dell Inspiron 640m Notebook
My dell latitude d600 keeps freezing no matter what i'm doing after a few minutes. I reinstalled windows and it still continues to do the same thing. Some one please help!
Check your RAM size, if this is a hardware problem, you will like to check your RAM first. Apparently, your hard drive is moving/functioning, you may have half of the RAM fail on you! and for our technician help contact us at http://tinyurl.com/mtgjzz
Jun 22, 2009 | Dell Latitude D600 Notebook
Computer is keep rebuting
Access the Recovery Console and extract a new copy of the Kernel32.dll file from the original WinXP CD
1. Start recovery console as described above
2. Insert the WinXP CD
3. At the command prompt, type CD system32, press ENTER
4. Type ren kernel32.dll kernel32.old, press ENTER
5. Type map, press ENTER
6. Go to the drive that contains your CD
7. Type expand drive\i386\kernel32.dl_, press ENTER; Kernel32.dll should be listed as 1 file expanded
8. Type exit, the computer restarts
9. Remove the WinXP CD
  1. Check cpu for dust
  2. Run a virus scan
  3. Check power supply
  4. Check other hardware such as memory
[Start] [Run] [Regedit]
Registry Key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\CrashControl
Modify/Create the Value Data Type(s) and Value Name(s) as detailed below.
Data Type: Dword // Value Name: AutoReboot
Setting for Value Data: [0 = AutoReboot Disabled / 1 = AutoReboot Enabled]
Exit Registry and Reboot
Open System Properties via Start > Control Panel > Performance and Maintenance > System
[ System Properties may also be opened using the WinKey+Pause key combination ]
Select the Advanced tab and then click Settings in the Startup and Recovery section
In System Failure section, clear the checkbox next to Automatically Restart
Click OK and OK to exit
  Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!! yuva
Mar 26, 2009 | Dell Dimension 4500S PC Desktop
CPU cooling fan
Hi...you can press the F2 key to enter setup...and scroll down until the fan is highlited...hit enter and then F10 to save and exit.This tells the computer its OK.
you should have plugged the fan in the same pin port the old fan was in. Usually only 1,.
If the new fan is not from dell..it may be faster and noiser..or it may be faulty..if you bought it locally you may try to return it.
The purpose of the fan of course is to remove the hot air from the CPU to keep it from overheating. If this fan does it it is most likely ok.
Hope this helps..
Squipps
Feb 07, 2008 | Dell Dimension 8200 PC Desktop
Computers & Internet Logo
293 people viewed this question
Alun Cox
