Question about Sony KDF-E50A10 50 in. LCD HDTV
No picture, no sound red led lamp flash - Sony KDF-E50A10 50 in. LCD HDTV
  • Sony Master
  • 8,457 Answers
The Lamp life is over.Require a new Lamp.
Posted on Sep 07, 2010
73735 no picture no sound
Are you sure it is turning on? It sounds like your lamp has failed. Look at the LEDs on the front. If one is red then you need to check your lamp. Refer to the troubleshooting section of your manual to determine if the indicator LEDs match the symptoms. If the status light is flashing then your lamp cover is not installed all the way.
Feb 28, 2015 | Mitsubishi Televison & Video
Installed new lamp. When powered up blue solid light and yellow blinking light (15x) , tv would torn off and on several times trying to light lamp. Once that failed red blinking light and yellow solid...
Hi Genaro,
Blue led light lit solid and yellow led light flashes is an initial attempt of the set to re-light the lamp.Red led flashes and yellow led light solid means that the lamp won't light up that's why it only has sound without the picture.
Since you've replaced the lamp twice and still the symptoms persist, I suspected that the fault came from the ballast board and not on the lamp itself. If the ballast board gone to malfunction, there's no high voltage will produce to light up the lamp and will sensed by the processor and trigger the error code (Flashes/solid led light with color code).
To verify whether the ballast board is faulty or not, check if the lamp will lit by looking through the lamp door louvers at the rear of the cabinet upon turning on the set.
Please let me know what you will find to assist you further.
Jdvillanueva
Nov 05, 2011 | Toshiba 65HM167 65" Projection Television
Sound but no picture; little red light showing instead of green led power indicator. less than two years old. original owner
Tv LED light indication"LAMP" is flashing or staying on?Yes 2 years old projection lamp and watches tv daily 4 or 5 hours a day?Yes,it is time to replaced the tv projection lamp.
Feb 18, 2011 | Mitsubishi WD 65837 65 in. HDTV
I recently purchased a used 50' Hitachi 50V500a Ultravision HDTV. I've had it for about a week. Was watching it. Turned it off to run an errand. Came back. Tried to turn it on. There is power. No...
The "LAMP" LED light indication still light up,after all the other LED lights indications turn off?The tv projection lamp is dead.Require a new tv projection lamp.
Oct 15, 2010 | Televison & Video
When turned on green light flashes and no picture
Check the Lamp if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 2X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Check the ballast if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 3X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Dec 24, 2009 | Panasonic PT-50LC13 50" Rear Projection...
No sound or picture, 2004 pt50dl54j
remove back panel. blow out all the dust from all the components except the fan on the right.
Vacuum out all the dust.
Have you replaced the lamp? that would help too.
There are 2 small red lamp. One indicates HEAT problem. The other one is the LAMP indicator.
Jun 13, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Panasonic PT-43LC14
The TV shutdown error code can help you with this problem. If the power led flashes green for 2 Min's then red. The Lamp led should flash red 1-2-3 or 4 time every 5 Min's. These are error codes that may point you in the right direction to you problem.
May 24, 2009 | Panasonic PT-43LC14 Television
Sony KDF-E50A10
If the lamp is new it could be the ballast the one is supply high voltage for the lamp you can order that ballast from Sony
Check the lamp if is not damage any where
Cheers
Dec 11, 2008 | Sony (XL-2400) Projector Lamp for...
Sony KDF-E50A10 50 in. LCD HDTV Logo
46 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
