Question about Speed Queen AWS44NW Top Load Washer
THE MACHINE DONT TAKE OR MIX WATER,ONLY COLD WATER WIL TAKE.
  • vincenzo543 Sep 07, 2010
    I INSTAL NEW WATER VALVE DINOT DO JOB
  • 15,935 Answers
The dual inlet water valve has a failed solenoid on the hot side.
Visit repaircenter.com and enter your full model number to see/order the valve.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 07, 2010
  • blueextc3221
    blueextc3221 Sep 22, 2010
    Did you VERIFY the water valve had voltage when the timer was calling for water?
    If there is voltage - the water valve solenoid has failed.
    If no voltage - the Timer (CCU) is the culprit.
    Please reconsider the 1 Thumb rating - as it is reserved for abusive posts. Most experts at FixYa answer questions for free, and ratings are our only satisfaction for doing so.
    Thanks!!
The cold water is not working in my washing machine
Check the supply hose filter, and the filter on the intake of the solenoid. Switch the wires on the solenoid to see if rinse will put hot water into the machine, the contact at the timer may be going bad. While reversed, see if it puts cold water into the wash, that will test the solenoid.
Dec 01, 2013 | Maytag Washing Machines
Maytag washer will not get warm
1) the temperature coming from your house determine how is the temperature. You can get hot, cold or mix of hot and cold available to your machine.If the water is too cold affect the machine,and if is too hot, the warm temperature colapse.
If you live Northern are, unless you adjust the cold and hot verywell affect the temperatur of your machine.WARM water is better in summer and Colder during the winter.
God bless you
Jun 21, 2012 | Maytag Washing Machines
Machine runs and mixes. Compressor seems to run but mix will not thicken. Seems like mix is not getting cold enough. A water cooled unit.. Tried to bypass water intake switch so water was always...
if its a water cooled unit when the compressor is running water should be running thru the valve, if it isn't be sure you have the water correctly hooked up and its cold water, if it is and still no water you have a bad valve
Apr 03, 2011 | Taylor 632-27 Ice Cream Maker
We have both hot and cold hoses going into washing machine but cannot get anything but cold or lukewarm water no matter what setting we choose. The pipe leading into the hot water hose feels warm and we...
sounds like the mix valve on the washer is broken and not opening properly -- the mix valve is the valve that both hot and cold water are connected to on the back of the machine.. turn off water valves and remove the hoses,, remove the back panel from the washer -- the mixer is held in place by one little screw,, also mark the wires going to the mixer ( hot/cold ) --- remove the mixer valve and take it down to your local appliance repair shop and match it up to a new one -- install the new mixer and connect wires and panel and then hoses and all will be working good as new.
c...
Feb 01, 2011 | Hotpoint Washing Machines
My washer will not work. It will not fill unless the washer is on warm warm, hot warm anything but cold. Otherwise I get NO water. It will spin. But I can only get hot water. Not even warm water.
One of two things, easy one first, the cold water inlet screen on the back of the machine is clogged preventing cold water from entering,or more likely the mix valve has gone bad (the cold water solenoid) replacing the mix valve is not hard on these for a doit your selfer and the parts are less than $ 50.00
Sep 18, 2010 | Kenmore 24032\24036 Top Load Washer
Error code is LE. Washer fills up with water and
If water runs in when the machine is OFF but stops when the tap is turned off it means a faulty watervalve.replace water valve. Probably a double valve. Dont mix up the hoses or the wires........Nomess
Apr 18, 2010 | LG WM1812C Front Load Washer
Our washing machine is putting out hot water when the temprature setting is on cold ...and cold water when it is on hot. All rinses are hot. What part could be bad?
The water temperature is incorrect The temperature of the incoming water determines the temperature of the water in your washer. You get either hot, cold, or a mix of the hot and cold water that's currently available to the machine. So if the cold water that enters the machine is very cold--or if the hot water entering the machine is very hot--the warm water is affected. If you live in a Northern climate, unless you adjust the hot and cold water taps that supply water to your washer, the warm water supplied to your washer is usually hotter during the summer months and colder during the winter months.
Jan 03, 2010 | Washing Machines
Kenmore 110.27822790 Top Load Washer
Check screens on the mix valve, hoses removed. If there is no humming sound when cold is selected then the mix valve needs to be replaced
Jan 03, 2009 | Kenmore 24032\24036 Top Load Washer
Indesit wil 113
this is a cold fill only machine as nearly all machines today are designed that way to save energy , as you only heat the water that you need
Mar 28, 2008 | Indesit W 123 Front Load Washer
Speed Queen AWS44NW Top Load Washer Logo
69 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
