Question about Peg Perego John Deere Turf Tractor
I have obtained a new motor for the rear passenger side wheel but am having trouble getting to the screws behind the rear wheel. How do I remove the wheel so that I can install the rear motor? thanks.. Nate
    Problem Solver:
  • 3 Answers
I had this same problem, but eventually figured it out.
The wheel comes off by removing the little black piece in the center of the yellow hubcap. There are a couple of snap tabs in this black piece, but it comes out well enough. You'll see the end of a metal rod going through the center of the wheels. Remove the star-looking washer and pull the wheel off. The other wheel will now come out as well, taking the rod with it.
Behind the wheel, you'll see 2 screws that hold the motor assembly in place. You'll also need to remove the seat and black cover to access the motor assembly.
Good luck.
Posted on Oct 16, 2010
Order a motor from Perego, for the side that is not working properly (about $20 including shipping). Talk to Perego (use Their 800 #) first because they can talk with you and determine exactly what part is needed.
Posted on Sep 28, 2010
I'm bleeding the breaks on a 1999 grand vitara and I can only find a bleeder screw on the drivers side rear. Can't find anything on passenger side. Is there one?
Most certainly there should be one. It should be in the same relative location as the one on the driver's side rear was (typically reversed due to being on the other side). What often happens is that over time, bleeder screws have a tendency to seize up and unless care is used to loosen them, they will shear off flush to the caliper/wheel cylinder. Inspect closely for this problem. If you have to replace the bleeder screw, chances are you will need to remove the caliper/wheel cylinder to drill out the old one, and hopefully, not damaging the threads, can install a new one. Many folks just get a new caliper/wheel cylinder and get on with the repair.
Sep 25, 2016 | 1999 Suzuki Grand Vitara
There is black fluid all over the passenger side of my car. Its coming from behind the passenger wheel. The car is reading "traction off" My brakes are good but having trouble stopping on and off. Not...
depending if its front or rear if its in the rear most likely the brake wheel cylinder , and your brakes is part of the traction control why its off, you should make sure brake fluid is full and get it fix
Mar 10, 2015 | 2008 Chevrolet Chevrolet Cobalt LT
Where is the blower motor... i know that is the problem, but where and how do I change it. i already have the part
Blower Motor Removal & Installation Front To Remove:
NOTE: The blower motor is positioned on the passenger side of the vehicle beneath the instrument panel, and can be removed from the vehicle without removing the HVAC housing.
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Remove or disconnect the following:
    • Negative battery cable
    • Passenger side cowl trim panel
    • Carpet to access the front upper screw that secures the air inlet housing
    • Recirculation door actuator
    • Recirculation door actuator wire lead from the routing clip located on the lower air inlet housing and position the wire lead aside
    • Blower motor wire lead connector from the blower motor resistor or power module, depending on application. Lower Air Inlet Housing chr_pacific_lwr_inlt_hsng.gif
    • One screw (from the top) that secures the lower air inlet housing to the upper air inlet housing
    • Four screws (from the bottom) that secure the lower air inlet housing to the upper air inlet housing and remove the lower HVAC housing Blower Motor Wire Lead Grommet chr_pacific_blwr_wrg_grmmt.gif
  3. Feed the rubber blower motor wire lead grommet through the opening in the lower air inlet housing.
  4. Push the blower motor wire lead through the opening in the lower air inlet housing and remove the lower air inlet housing from the vehicle.
  5. Place the recirculation-air door as needed to access and remove the three screws that secure the blower motor to the lower half of the HVAC housing.
  6. Lightly bend the recirculation air door far enough down to remove the blower motor and wheel from the HVAC housing. Blower Motor Mounting Tabs blwr_mnting_tabs.gif
  7. Remove the blower motor and wheel from the HVAC housing. Make a note of the location of the blower motor mounting tabs.
To Install:
  1. Install or connect the following:
    • Blower motor and wheel to the lower half of the HVAC housing and line up the blower motor mounting tabs to the correct location on the HVAC housing
    • Blower motor and wheel into the HVAC housing by lightly bending the recirculation-air door far enough down
    • Three screws that secure the blower motor to the HVAC housing by positioning the recirculation-air door as needed
      1. Torque to: 17 inch lbs. (2 Nm)
    • Blower motor wire lead through the opening in the lower air inlet housing and seat the rubber grommet into the lower air inlet housing
    • Recirculation-air door pivot into the lower air inlet housing
    • Four screws (from the bottom) that secure the lower air inlet housing to the upper air inlet housing and the lower HVAC housing
    • Blower motor wire lead connector to the blower motor resistor or power module, depending on application
    • Recirculation door actuator wire lead into the routing clip located on the lower air inlet housing
    • Carpet
  2. Perform the heater-A/C control calibration procedure.
Rear To Remove:
NOTE: The rear blower motor and blower wheels are repaired only as a balanced unit. The entire blower motor and wheel assembly must be replaced if either component is fault or damaged.
    • Front center floor console cover
    • Negative battery cable Rear Blower Motor Housing chr_pacific_rear_blwr_hsng.gif
    • Body wire harness connectors from the rear blower motor power module and the rear mode door actuator
    • Body wire harness bracket from the console support bracket
    • Eight screws and the two console support brackets from the floor console base and duct assembly
    • Four screws that secure the rear blower motor housing to the floor console base and duct assembly
    • Rear blower motor housing and place it on a bench
    • Rear blower motor wire harness connector from the power module
    • Eleven retaining clips and three screws that secure the housing together
    • Two halves of the housing
    • Blower motor wire harness and grommet from the housing and remove the blower motor
To Install:
    • Rear blower motor into the housing and install the blower motor wire harness and grommet
    • Two halves of the rear blower motor housing and install the eleven retaining clips and three screws
    • Rear blower motor wire harness connector to the rear blower motor power module
    • Rear blower motor housing into the floor console
      2. Two console support brackets onto the floor console base
      3. Eight screws that secure the support brackets to the floor console base
      4. Body wire harness bracket onto the console rear support bracket
      5. Body wire harness connectors to the rear blower motor power module and the rear mode door actuator
      6. Negative battery cable
      7. Front center floor console
  2. Calibrate the A/C-heater control.
Aug 13, 2010 | 2004 Chrysler Pacifica
I have a 2005 ford freestyle the ac is fully charged the rear works great the front passenger side is ok but the drivers side is warm about 20 degrees difference between the drivers side an passenger
there is a door that directs cold or hot air behind the dashboard in order to make the passenger's side colder or hotter relative to the driver's side.
The a/c door servo may be bad, or the temperature settings for each zone are not balanced.
In-vehicle Temperature Sensor Removal & Installation
  1. For the Five Hundred and Montego;
    • Lower the steering column to the full tilt-down position.
    • Remove the instrument cluster finish panel screws.
    • Release the locking tabs on the steering column upper shroud located behind the steering wheel.
    • Remove the instrument cluster finish panel and the steering column upper shroud as an assembly.
  2. For the Freestyle;
    • Remove the lower steering column cover.
    • Remove the lower steering column shroud.
    • Disconnect the electrical connector from the in-vehicle temperature sensor.
  3. Remove the in-vehicle temperature sensor.
To Install:
  1. Reverse the removal procedure to install.
Jul 22, 2010 | 2005 Ford Freestyle
If I need to replace the blower motor for my 2001 Ford Expedition air conditioner, does the entire dash have to be removed to reach it?
If you are removing the main blower motor at the passenger side of the cabin then you don't have to remove the dash. It's behind the lower dash trim panel and takes about an hour and a half to two hours to do. Not to bad a job but you will need to be a bit flexible to see under there.
Jun 08, 2010 | 2001 Ford Expedition
I need step by step instructions on how to bleed brakes on my 2005 toyota celica
If you don't have someone to help you you'll need to get a one man brake bleeding kit. The bleeding kit will take the place of the helper. IF you have a helper start with the rear passenger side wheel (furthest from master cylinder). Remove the wheel, have a helper sit in the vehicle and pump the brakes several times (motor off). Tell them to hold the pedal down while you open the bleeder screw. Tighten the bleeder screw before the helper releases the brake pedal to avoid sucking air back into the line. Repeat this process until the fluid flows out of the bleeder with no air. Then repeat these steps on each wheel. The order of bleeding is always furthest from the master cylinder. Rear passenger, rear driver, front passenger, and lastly front driver. After each wheel is done check the fluid level in the master cylinder and add as necessary. You don't want it to get low and **** air in from the cylinder.
Nov 06, 2009 | 2002 Toyota Celica
Removing passenger door panel
There is a screw behind the lock rod. Lift door panel straight up to remove
Jun 13, 2009 | 2003 GMC Yukon XL
Blower moter will not work need to find the location
The motor is located behind the glove box on the passenger side under the dash, here is the change out procedure.
First, remove the glove box...easy three screws total. Two on the bottom, and one holding the shock on the right side. Second, remove the metal bar that is behind the glove box...four phillips screws. Third, remove the two bolts securing the dash on the right side. Fourth, remove the small RH kick plate...pull hard it has three clips. Fifth, remove the two screws on the bottom of the fan housing and remove the bottom diffuser...small plastic peice. Sixth, remove the front center metal clip and remove this small plastic piece. Seventh, pull the carpet back on the passenger side and remove the four nuts securing the computer to the floor board and swing it out to the left. Next, disconnect the neg terminal on the battery and remove the three plugs that were near the RH kick plate. Now comes the fun part. The dash will be hindering the removal of the blower motor housing. First, remove the metal band securing the blower motor housing and the heater core housing together. It's one 10mm bolt at the top. This band clips to another band securing the two housing together on the back side. You will also need to remove the two small phillips screws securing the rear band to the blower motor housing...one on the top and one on the bottom. The rear band gets in the way when removing the housing. So when the housing assembly drops remove the rear band from the top...set this part in first on installation. Last, remove the four 10mm nuts securing the blower motor housing to the firewall. The housing will not fall to the floor on its own. You will need to pull up and out on the bottom of the dash while guiding the housing assembly down and to the left. Be careful not to pull aggressively on the dash. It's sturdy, but will crack if you are too rough.
Apr 14, 2009 | 1991 Honda Accord
Peg Perego John Deere Turf Tractor Logo
377 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
