Question about Porter Cable Random Orbital Sander, 5"
My 5" random orbit sander model 333 is spinning out of control. What do I do?
  • 490 Answers
I may not have the whole picture, but all random orbits spin wildly if they are not pressed onto the wood a little. Do you mean it is not oscellating, but just spinning when it is on the wood? That would be an issue requiring cleaning or repair, otherwise, just don't turn it on until you have placed it on the wood to avoid marring.
Farmerbear:)
Posted on Sep 07, 2010
4 Suggested Answers
SOURCE: Porter Cable Random Orbital Sander rotates but does not "orbit"
Just solved my problem with Porter Cable 333 orbital sander which just groaned. I thought the worst. I carefully took it apart on the garage floor and immediately suspected it needed lubrication as the motor turned hard. I used my flexible long plastic tube lubrication and put some on the bottom bearing shaft the best I could. I worked it around and around. I began to feel it turning easier. I applied more oil and kept moving and it became completely free. I put a drop on the top bearing even though it was loose. I put it all back together and it works like new. Lesson: do not look for the worst when a tool quits. Suspect the culprit to be lack of lubrication!!!
Posted on Aug 15, 2011
rowdy45176
  • 2176 Answers
SOURCE: Sander does not turn on when power is applied
could be a couple things but I am going to guess the switch is contaminated and keeps tool from running. The switch number is A22667 and lists for 2.81. What you can do to find out possibly is hold tool up and in rapid sequence turn tool on and off and sometimes it will move enough dirt to operate. Let me know if you need any more assistance
Posted on May 16, 2009
SOURCE: My porter cable orbital sander, model 333 needs to be lubricated
how to lube sander
Posted on Jul 12, 2011
What is happening to my Dewalt DW421 spinning fast, but no random orbiting motion.
Probably need to replace bearing 6202. I took mine apart, dissambled the retainer and used PB Blaster on the bearing. It seems to be a short term fix. At least it's not operating at hyper speed anymore. Long term, I probably need to replace the bearing and maybe a new lower retainer if I can't press the bearing out.
May 25, 2013 | Dewalt DW421 5'' orbital sander
Porter cable model 333 will not orbit and spins at a very high speed. I do not have a manual.
there is a belt from the motor to the pad that has apparently broken. Go to dewaltservicenet.com and you can download both the parts breakdown and the operators manual. If I have helped you would you please vote accordingly and thank you
Sep 06, 2011 | Porter Cable 332K Quicksand Random Orbit...
Porter Cable random Orbital Sander (Quicksand) Model 333, Double insulated When sanding, it stops and starts, it sounds as thogh it is stuck and then gets going for a short while
Hi, Sanders are prone to getting lots and lots of dust inside the unit. The cooling fan makes this problem inevitable. The only way to fix this is to take it apart and and blast it with a pressurized air tool. Hopefully this will bring back some life to your sander. The effectiveness of this procedure is dependent on how well you can remove all of the dust. hope this helps.
Nov 16, 2010 | Porter Cable 332K Quicksand Random Orbit...
Dewalt d26451 type 1 random orbital sander. why does this sander jump around on the material and feel like it's fighting me all the time instead of sanding smooth and easy?
I have the same problem with a Porter Cable orbital sander I recently purchased. Whats happening is the sander is catching the edge of the board you're trying to sand and jerking back and forth as the sander base spins. It seems that if the board your're sanding is at least as wide as the sander base, the problem goes away, which does little good because there will be many times I we'll need to sand wood that is less in size. But you may try using a lesser grit sandpaper and see if that alleviates the problem somewhat.
Aug 10, 2010 | Dewalt Heavy - Duty 5" Random Orbit Sander...
It spins out of control if I don't keep it under load.
Im not sure what you mean "out of control" but the tool is only meant to be on while in use . If the tool is really going crazy ,pull off orbital and check all screws and tighten accordingly
Dec 28, 2009 | Makita BO5010 5" Random Orbit Sander
May 20, 2009 | Porter Cable 332K Quicksand Random Orbit...
May 07, 2009 | Tools & Hardware - Others
Porter Cable Random Orbital Sander, 5" Logo
385 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
T bone 1963
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
