Flat Panel Televisions
Problem for Flat Panel Televisions
Generic problem for all Flat Panel Televisions
Can't receive proper dvd/vcr signal
By WAL972 on May 14, 2008
I just bought the tv today and replaced my OLD Samsung 27" tv with the new Toshiba. I had this tv hooked up to my LG dvd/vcr from a new Sony BRAVIA HDX500i home theatre system via the old yellow video cord. The dvd/vcr is from Australia, while everything else I bought from the U.S. in the last 2 months.
I know a clear signal is coming from the BRAVIA hts because it receives the dvd signal fine. However, when I switch the function on the Bravia over to SATELLITE/TV in order to send the signal from my dvd/vcr player, the picture shows but with no colour, the wrong size and very fuzzy - like the signal is not tuned in.
However, when I take the same yellow video cord from my new tv to plug it back into the old, the signal is just dandy as always. For some reason it appears that the new toshiba HDMI tv just doesn't like the signal from the dvd/vcr via the Bravia.
Do I need to:
a) tune in the signal coming from the dvd/vcr?
b) get a HDMI cord instead?
c) reconfigure the setup (don't know why though as it still works on the old tv), or
d) some other solution?
Is it possible that the new Toshiba tv from the U.S doesn't like the signal from the old dvd/vcr player from Australia? Any help would be greatly appreciated as more than half my dvd collection is PAL Region 2 and 4, not to mention my Xbox.
Cheers
WAL972
Comments:
May 14, 2008
- I think it's clear that the problem is a format issue. Can either the dvd player on the Sony Bravia HDX500/i or the Toshiba Regza 37RV530U television support the PAL format and if not, is there any way I can get either to do so? Cheers.
May 16, 2008
- The original dvd player is an LG V271 DVD/VCR combo.
The other dvd player is a Sony BRAVIA HDX500/i home theater system. However I think the problem is with the Toshiba tv rather than the dvd player
Best Solution
posted on May 14, 2008
Helpful)
avid_imps
Rank: Guru
Rating: 86%, 411 votes
Your Toshiba TV uses the American NTSC standard.
Your DVD/VCR uses the Australian PAL B/G standard.
Unfortunately the two are not compatible as they stand, but there may be an option in the DVD/VDR menu to force the output to NTSC. This varies from make to make.
Another option would be to modify your main DVD player to make it multi-region so it will play ALL of your DVDs. Some models can be modified with a simple handset code, some can be modified with a software update, and others need an internal modification.
Post your make and model, and I can advise you on modification.
Was this helpful?
Yes
No
Popular Solutions for Flat Panel Televisions
Questions and Unsolved Problems for Flat Panel Televisions
Answer
While watching TV, every once in a whule the sound changes and it sounds like an echo/blown out... (More)
Answer
What is a good still camera to buy?
Answer
I have a GoVideo dvr4000 which is more than 5 years old. Currently it will not stay in the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Flat Panel... Experts
Top TV Repairmen
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
