Question about Princeton Digital VL2018W Monitor
I have Princenton Monitor, when I connect it to my laptop to work with two monitor, some times is works and some time the Princeton monitor goes blank and the blue light on the on/off switch blinks. I have to turn the monitor off and leave it of for a couple of hours and the turn off the laptop and restart everything togeth to get the Princeton monitor to work with the laptop
  • 11,361 Answers
Look for bad caps just like these Princeton as shown here:
http://s807.photobucket.com/albums/yy352/budm/Princeton%20VL2018W/
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Posted on Sep 07, 2010
I have a 17 inch princeton monitor and the screen goes off frequently. each time it was every 15 mintuires now it goes off every 4 to 5 mintures. i turn if off and back on and it works. help
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed PRINCETON monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
May 18, 2010 | Princeton Digital VL1716 17" LCD Monitor
"no signal"
"no signal" means that the monitor is not receiving a video signal from your computer or laptop. This is normal if the compouter is OFF and the monitor is ON. Is the computer still on and connected to the monitor?
Mar 27, 2010 | Princeton Digital VL1514 Monitor
Princeton Digital VL1716 monitor - no image and completely dark
1. Most of the time it's the florecent tube about to go out. Check other posts to replace it.
2. Alot is the adapter after a while will lose voltage check the voltage out of the adapter it should be 12V at 4A or 5A would work fine.
Jul 13, 2009 | Princeton Digital VL1716 17" LCD Monitor
Same problem
Check the Inverter card Connector which goes to pannel,Next Panel to AD card signal Cabble,..
Jul 10, 2009 | Princeton Digital VL1918 Monitor
Monitor goes blank
Sometimes, i can be the wiring, so check all of that. But apart from that. I don't know! Hope this helps!
DigicalJAI
May 21, 2009 | Princeton Digital VL1717 LCD Monitor
Monitor goes to sleep after 30 minutes vl1919
Welcome to FixYa! The default power saving feature is turning the monitor off. To change the settings go to the Desktop>Right click on it>Properties>Settings and you will see power saving settings where you can choose "Never turn off" or a longer time interval. These settings can also be found in your Control Panel for all of the Power Saving features for the computer, monitor and hard drive. Steve
Jan 03, 2009 | Princeton Digital VL1916 19" LCD Monitor
No Display on Monitor (Princeton VL1917)
Try leave it for some time and try it again to the PC, when you connected it to the laptop it must have auto configs it selfself too suit the laptops resolution.
Nov 24, 2008 | Princeton Digital VL1918 Monitor
Using with a Mac
Looks like a power save program has hibernated your monitor. Look in Control panel settings to see if the power settings hibernate your monitor. Reset to never and this may fix your problem.
Drivers usually do not fail after 20 mins it is usually a software option set incorrectly.
Also, check the Bios program for correct settings or options.
I haven't had a Macintoch in a while but, this may give you some where to look for the solution
Good Luck
HJ
Dec 11, 2007 | Princeton Digital VL1916 19" LCD Monitor
Princeton Monitor blackout
May I know how do make sure the connection is ok.. the only way to do is to use a known good monitor and connected to your system... this will tell you if you need a new one or not...
Aug 30, 2007 | Princeton Digital LCD1510 15" Flat Panel...
Princeton Digital VL2018W Monitor Logo
245 people viewed this question
Top Princeton Digital Computers & Internet Experts
Josh Whitehead
Josh Whitehead
William Ward
Level 1 Expert
Daniel Dollive
Daniel Dollive
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
