Question about Iomega 1TB Desktop USB 2.0 Hard Drive
Iomega 1 TB hard drive clicks for a few seconds along with a beep. It stops, but my computer doesn't recognize it anymore.
joey64
  • 209 Answers
SOURCE: NTFS hard disk not recognized as 'RAW' iomega hdd160
format this with NTFS to recognize by your computer, RAW means no file system
Posted on Dec 03, 2007
Crankstart
  • 696 Answers
SOURCE: My Iomega hard drive (MDHD-UP) not working, only beeps
Hi, Generally the HDD inside the shell can handle about a 6' drop when it's off and about a 1' drop if it's active. The beep is most likely coming from one of the shell components. Take the drive to a pc store and ask the techs to move the HDD into a new shell and test it for you. Most likely it's ok and you can just buy a new shell/enclosure for it. If that doesn't work it may have been actively reading/writing when it toppled and as the drives are a lot more delicate during that process you may need the help of a recovery pro. If that's the case comment back here with your country/state/city and I'll pass on a recommendation for a nearby facility that can assist you in retrieving the files. Chris
Posted on Jun 09, 2009
  • 97 Answers
SOURCE: Can't mount my external Iomega harddisk anymore
Try running disk utility. If it can see the hard disk but it isn't mounting it, try clicking "repair" or if that is greyed out, "verify" then "repair". Be warned that this could take a very long time, so leave it over night. It may even look like it has crashed. This may either fix the problem, or tell you that the drive can't be repaired (in the data sense) and it will hopefully mount it read-only so you can retrieve the data. You will need another drive with enough space to copy everything off. If copying data fails, try copying folder by folder or even file by file to get off all files that are ok, as otherwise it will just give up when it finds corrupt data.
If disk utility cannot see the hard disk at all, try the other interfaces (usb/firewire/sata). If it can't see it in any of them, try it on another computer. If none of them can read it then the unit is dead. You may be able to retrieve your data by taking the unit apart, removing the hard disk, and placing it in another enclosure. This will probably void your guarantee though, so it's a choice you may have to make :(
Posted on Oct 27, 2009
  • 393 Answers
SOURCE: Hard drive clicks several times when turned on,
I have to say from the sounds you describe the Hard Drive is totally destroyed, the noises you can hear are the mechanical parts inside grinding and clanking together. If the information is critical it may be recovered by a specialist data recovery company, but we are talking £100's even £1000's to do the job, so otherwise I would suggest taking case apart and buying a new hard drive for it.
Sorry its not what you want to hear but it sounds very terminal to me.
The reason the PC can detect a device is that it can see the Interface card that sits between the USB port and the Hard Drive.
Posted on Mar 03, 2010
Testimonial: "Thanks for a quick reply! "
lock123
  • 6831 Answers
SOURCE: iMac not recognizing external hard drive
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
My iomega 1 tb hard drive isn't recognized by computer. Blue light turns on but I don't hear anything from the device itself
What's your operating system? If windows: Check in device manager if its recognized as USB device. You can also look in disk managment
Aug 31, 2013 | Iomega 1TB Desktop USB 2.0 Hard Drive
Iomega eGo was working before and not now. All it does is beep. Read on other forums that it could be a power issue. Windows sees the drive in device manager but drive doesn't spin up. Just beeps for...
the beeps are post during post the very first work is done by the ram all the memory in the ram is first transferred to the hard disk and remains active until turned off.
make sure that your RAM is securely seated,
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
when you plugged the external disk drive you got that windows could recognize the USB device change the cable just replace the cable of the hard disk everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
May 15, 2011 | Iomega eGo 1 TB USB 20 Hard Drive
I need a users manual to learn how to operated my new Iomega Desktop hard drive
if you type "Iomega Prestige 1 TB USB 20 Hard Drive users manual" into google it should bring up a few results for you, or simply type what your problem is and see if we can answer it for you
May 12, 2011 | Iomega Prestige 1 TB USB 20 Hard Drive
My hard drive is beeping and "clicking" non stop
the drive is defective. that clicking noise is the read head not aligned properly. take the hard drive out of the enclosure and place it in the freezer for about an hour and see if it works long enough to the data off it, but ultimately you will need a new hard drive.
Mar 16, 2011 | Iomega Prestige 1 TB USB 20 Hard Drive
Purchased new Iomega 1 TB Home Media network HD, and both my MBP and PC windows 7 won't recognize the device.
you have to initilize the disk in disk management utility, heres how (windows XP)
  1. Click on Start and then Control Panel.
  2. Click on the Performance and Maintenance link.
    Note: If you're viewing the Classic View of Control Panel, you won't see this link. Just double-click on the Administrative Tools icon and skip to Step 4.
  3. In the Performance and Maintenance window, click on the Administrative Tools link located under the or pick a Control Panel icon heading near the bottom of the window.
  4. In the Administrative Tools window, double-click on Computer Management.
  5. When Computer Management opens, click on Disk Management on the left.
    In a few seconds, Disk Management will load on the right side of the Computer Management window.
    Note: If you don't see Disk Management listed, you may need to click on the + icon to the left of Storage to expand the option.
  6. You can now format a hard drive, change a drive's letter, partition a hard drive, or do whatever else you need to do in Windows XP's Disk Management tool.
Dec 11, 2010 | Iomega 1TB Home Media Network Hard Drive...
I have an Iomega Prestige 500 GB hard drive and its broken all it does is click click click and my computer doesnt recognize it..its still on warranty any ideas
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked. I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 22, 2010 | Iomega Prestige 500 GB USB 20 Hard Drive
Could not find pretige iomega icon on my computer
format the harddrive as MS-Dos to be able to use it on Mac and PC.
Apr 17, 2010 | Iomega Prestige 1 TB USB 20 Hard Drive
Computer doesnt read the external hard drive anymore
It sounds like the hard drive head crashed when you pulled the power plug. Unfortunately if you can't get drive to be recognized, you won't even be able to run any diagnostics. You will have to take the drive to an authorized repair shop who will have to check the electronics to see if the head will respond. Unless you have data on your drive that you absolutely need, you will probably save a lot of money by replacing rather than repairing the drive.
Jul 10, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
Iomega 1TB Desktop USB 2.0 Hard Drive Logo
67 people viewed this question
Top Iomega Computers & Internet Experts
Owen Barnes
Martin Murray
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
