Question about InFocus LP 70 Multimedia Projector
On projector screen the words are cut off - almost like there is a black border around the edges. Ideas to turn off?
2 Suggested Answers
  • 167 Answers
SOURCE: Slanted Border- Projector image is not square
Is the image slanted on the bottom as well?
Make sure the projector's throw is pointed directly at the target ie. screen or wall etc. there's not much else it could be.
Posted on Nov 29, 2009
Why does the screen have Black Border around the picture , picture distorted?
There are connectors and circuitry that control the vertical and horizontal picture image generation that need to be at the edges of the screen. The border simply covers these connectors and circuitry so the user cannot see it. Newer models of flat panel TV's solve this problem better to get more picture real-estate to the user. Flat panel TV's are not like the original CRT (cathode-ray) TV's of the past that had borders to conceal a non-linear distortion that occurred at the edges.
Jun 23, 2014 | LG 37LC7D 37 in. LCD HDTV
My Epson TW 700 suddenly went black,and the fan startet to go very fast.I could also see the red light ( temp. Indicator? ) coming on.Tried to cut the power, cleaned the filter and start it again, but...
Don't cut power to a projector when you power down. The fan has to run after the projector is powered down so that the lamp can cool evenly. If you unplug or if there is a power failure the lamp will develop cracks around the edges of the reflector and will fail quickly. If the fan is not moving air through the projector, it will overheat and shut down.
Nov 03, 2013 | Epson EMP-TW700 LCD Projector
My brother printer cuts off the right margin
how much if just border cutting from word then set the borders around the text
Jan 14, 2013 | Brother MFC-7360n Laser Printer
I wanted to place a sign board in our workplace and i wanted to put the words "SAFETY FIRST".My concern is how do i design the letters and what color is best for the letters.
I suggest this combination for a sign that stands out. Some road signs use this combination too.
Yellow background with black bold font such as ARIAL.
Place a black border around the edge of the sign.
Jul 11, 2011 | Audio Players & Recorders
Background "halo light effect" when using XR-10-XL in 16x9 mode
Do you mean there is a dark grey outline when using it in 16x9 mode? This happens with my projector too. Try using dark (or black) masking around the screen.
Aug 20, 2009 | Sharp XR-10X Multimedia Projector
Screen won't stop rolling out
There is a rubber grommet on the left top of the projection screen, insert the supplied Allen key and turn anticlockwise and adjust turn by turn till the screen rolls out with just 2 to 3" of the black border shows on the top
May 16, 2009 | Draper Baronet 106 in. diag HDTV MW...
Printing problem in Microsoft Word 2003
Does the bottom border show up in Print Preview? Some printers will not print the full page, to include the border if it is too close to the papers edge. If you adjust the border to be further away from the pages edge, it should print. Instead of applying a page border, you may have to draw a border using a rectangle shape and apply the desired line style.
You can also try to adjust the border margin to measure from "edge of page" instead of measure from "text". This setting is on the options button located on the page border tab under the Borders and Shading window. This may allow you to adjust the margin enough to be able to print the border.
Apr 09, 2009 | Microsoft Word 2003 for PC
Jan 10, 2009 | InFocus ScreenPlay 4805 Multimedia...
Picture does not bleed to edge
this symptom is caused by a poor regulation in the power supply circuit. too low dc supply voltage will result to insufficient deflection, both vertically and horizontally. black borders appear around the raster. receivers generally use regulator in the main power supply to set the dc supply voltage at the value that will allow the picture to fill the screen with a little overscan. defective regulator can result in a small raster. most modern receivers today are using ic (integrated cirduit) regulator. but if you are not inclined with this kind of job, better bring it to a qualified tv technician. good luck!
Feb 27, 2007 | Toshiba 27A43 27" TV
InFocus LP 70 Multimedia Projector Logo
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
