Question about Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX
Runs, but will not idle. - Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX
    Brigadier General:
  • 4,088 Answers
Turn the idle speed screw (not the idle jet screw--L) CW 1/4 to 1/2 turn so that the engine continues to run, but the chain doesn't turn. Make sure the air cleaner is not plugged. Hope this helps!
Posted on Sep 09, 2010
Throttle body stuck, rough idle
Have you cleaned the throttle body bore and plate of carbon/deposits ? This can cause idle and off idle symptoms .
Nov 25, 2015 | Cars & Trucks
Runs rough idle
your idle valve may be dirty or needs replacing would check this as it controls idle. sits on the intake with wires coming out of it.
Mar 22, 2014 | Suzuki Grand Vitara Cars & Trucks
My Chevy 2500, 2001 runs rough when it cold outside
It can be issue with low fuel pressure,the fuel pump is getting old both needs to be checked.Also get the IAC valve checked.
Go through the related help links with similar problem,it may help:---
Click the links below:---
Engine Idles Rough and Dies? http://whatisbyme.blogspot.in/2012/05/1994-lexus-es300-engine-idles-rough-and.html
van idles rough? http://howtobyme.blogspot.in/2012/01/2004-ford-freestar-van-idles-rough.html
runs lean and idles rough? http://technoanswers.blogspot.in/2012/02/ford-runs-lean-and-idles-rough.html
Car still runs Rough after tune up?
http://howtobyme.blogspot.com/2011/12/car-still-runs-rough-after-tune-up.html
2006 kia rio runs rough http://technoanswers.blogspot.com/2012/10/2006-kia-rio-runs-rough.html
Idle flair is noticed on car? Rough idle? car will not idle? Erratic idle speed? http://technoanswers.blogspot.in/2012/02/idle-flair-is-noticed-on-car-rough-idle.html
Rough idle, staling and Erratic shifting? http://technoanswers.blogspot.in/2012/03/rough-idlestaling-and-erratic-shifting.html
These details will help.
Thanks.
Nov 06, 2012 | Cars & Trucks
High idle
most cheaper generators do not have a idle kick down and are made to run at 1850 rpm's the older ones run at 3600 rpm if it has a no load idle system there will be a switch
Aug 27, 2012 | Craftsman 5600 watt Generator
328 gts 1986 very rough idle, running rich you can smell the gas from the exhaust . runs fine once the throttle is pressed
you need to adjust your idle screw on your carb i could tell ya how on that type of car but your running to high of an idle and flooding your cylinders thats y it is idleing rough and you can smell the gas, adjust your idle screw back a little and then you might want to check your plugs and make sure you didnt fowl and of them with it running rich
Apr 21, 2011 | Ferrari 328 Cars & Trucks
2004 150 runs good but won't idle and idle screw does'nt seem to make a differance
well if it didnt run good i would say carburator needs cleaned or rebuilt.if bike performs fine you can adjust the idle at the hand throtle on handle bar ,just loosen the nut and unscrew a little at a time untill desired idle is acheved and then tighten screw back down.
May 21, 2010 | 2005 Honda CRF 150 F
2001Pontiac Grand Am Rough Idle In Drive Only
I had the same problem with '99 GA I changed the idle control valve , solve the problem
Mar 23, 2009 | 1999 Pontiac Grand Am GT
Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX Logo
124 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
