Question about Nokia 6600
Memory card my phone can't detect the memory card.
  • tesajene May 27, 2008
    My phone won't detect the memory card. Unable to format card as it's not found. Please help!!!!
So wu
Posted on May 14, 2008
My micromax q5fb mobile cant detect memory card
Hi
Now use the simple trick to detect the memory card, because in china phone no safely remove option. so while remove the memory please switch off the mobile and while putting the memory card you have to again restart you phone otherwise it can't detect. try this trick may solve you problem.
God Luck
Sep 09, 2011 | Cell Phones
I have a blackberry curve with a 2gb memory card but now when I want to access the memory card it shows there is nothing on but I have music and pictures on the memory card
Hi
Firstly check whether u have inserted memory card correctly . If that is correct then check whether the phone is detecting the card. I think blackberry has an option to check it .
If the phone is detecting the card then check for the free space it is showing on the card . If it is showing the correct space and not showing the contents then switch off and switch on the phone after removing the card .
If the phone is not detecting the card then check the card using a card reader there also if it not getting detected then you need to check the card whether it has some physical problems. If the card is getting detected on the card reader check your phone with some other card and even after that if the same situation exists then you can take your phone to a service center
Oct 27, 2010 | Electronics - Others
Memory card no dedect,and no files in displade.
Hi,when a memory card does not detect on phone, it simply because the the memory card you inserted into the phone is not properly fixed or the memory card you inserted into the phone is damaged,that's when if doesn't detect the memory card on the phone.
You can insert the memory card inside a card reader or a friends phone that uses the same memory card type to confirm if the memory card is not damaged yet.
I guess that will solve the problem.
Take care.
Oct 11, 2010 | Sony Ericsson G502 Cellular Phone
3110 Cellular Phone: my Nokia 3110 classic is indicating no files found...
Check whether memory card is detected or not from the gallery, if it is so then you better format it and reinsert or try with another memory card. Most of all this is virus and file corruption problem, Good luck..
May 05, 2010 | Nokia 3110 Cellular Phone
Samsung SGH L 170 cannot detect memory card
First, try using a known working memory card into your Samsung phone. Or, insert the undetected memory card into another phone so that you could isolate the problem.
If the phone did not detect the known working memory card, then, you need to contact the manufacturer of the phone for repair.
There's a possibility that the memory card slot of your phone is no longer working correctly or they just need to replace some components.
Good luck and have a great day!
Jan 28, 2010 | Samsung Cell Phones
I did a reformat but still my phone cannot detect the memory card
1. If your memory card can be detected on your computer, then try to completely format the card.
2. Goto Start >> My Computer >> Right-Click the memory card icon >> Format >> Uncheck the Quick Format option >>
Start >> OK / Yes (confirm the request!).
3. If the memory card cannot be detected / readed by your PC, phone, or camera, then that card has become corrupt / unrepairable!
4. You should replace that memory card with a compatible one!
please rate this advice if it helps...tc! :)
Sep 24, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
My phone is not detecting the memory stick micro
Format the memory card in pc or any other phone then insert in your phone it will work.
Aug 11, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
Cannot detect my 4gb memory card
First you should format your 4gb card with your phone software so that itll create the file system.
then your phone will detect the memory card
Aug 06, 2009 | T-Mobile MDA Compact Smartphone
Formatted memory card of nokia N72 not detecting in the phone
See if the phone detects a different memory card. If it doesn't detect any cards at all, try to reset/update the phone firmware.
If that doesn't work the card slot might be damaged, maybe dust and dirt?
Feb 04, 2009 | Nokia N72 Cellular Phone
Nokia 6600 Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
