Question about Avaya 4424D Corded Phone
How do you discover the Extension # assigned to a Lucent 4424 phone?
If it is on a Legend/Magix, you can press:
SPeaker
0
0
If IP Office, just call another extension.
Posted on Sep 08, 2010
How do you assign a dedicated line/phone number to a Avaya/Lucent 4424 desk phone on a Lucent phone system?
Which Lucent Phone system?
Legend/Magix or IP Office?
What ind of line? POTS or a DID off of the PRI?
Sep 07, 2010 | Avaya 4424D Corded Phone
Can you program a 18D phone to bring back up an incoming call number? Does that have to be programmed per each phone or from extension 10 for all phones?
Yes :-)
It has to be programmed from extension 10 and from the phone. One sets the destination and the other sets the button. Technically, you can do everything from the main phone, but it's easier to do the system programming from the main and the extension programming from the extension, that way you can see the button you're assigning to the feature.
Check out the quick guide here. http://public.carl.airpost.net/Avaya/Partner%20ACS%20quick.pdf
Page 38 gives you the #31x commands to set up CID, and page 110 gives you the featrure codes you need to assign to the extenson buttons.
Carl
Jul 07, 2010 | Lucent PARTNER18 Corded Phone
I want all incoming calls to come through my extension only.
What it sounds like you want to do is restrict the automatic system answering to certain extensions. This is done via feature code 204.
To identify the lines on which outside calls should be answered by the system:
  1. Press feature +(00)+(system program)+(system program)+#204
  2. Enter the two-digit system line number of the desired line.
  3. To assign or unassign the line, press (Next Data) until the appropriate value appears.
    1 = Assigned
    2 = Not Assigned (the factory setting)
  4. To identify another line, press (next item)or (prev. item) until the line number appears on the display. Then repeat Step 3.
  5. Repeat Steps 3 and 4 for all the lines that you want to identify.
  6. Select another procedure, or exit programming mode.
Aug 31, 2009 | Lucent PARTNER18 Corded Phone
Need to turn voice mail off. no access to mailbox or passwords
This has to be done from extension 10 or 11
Feature 00
Left Intercom, Left Intercom
#206
Line 01
Press 2 (not assigned)
Do same for all lines.
Your incoming calls will bypass auto attendant.
Cheers
Apr 28, 2009 | Lucent PARTNER18 Corded Phone
Stop ringing at certian phones when outside calls come in.
http://dstech1.com/programming-line-ringing/
Partner, all releases.
Examples
Receptionist Call Routing. If you want calls to be answered by the receptionist first, set the lines at the receptionist's extension to Immediate Ring and the lines at the users' extensions to No Ring. (This is the factory setting)
Receptionist Backup. If you want all calls on a line to ring directly at users' extensions -with the receptionist providing backup -set the line at the users' extensions to Immediate Ring. Then set the line (or lines) at the receptionist's extension to Delayed Ring. An incoming call that is not answered by a user within 20 seconds will also ring at the receptionist's extension.
Programming
To change the way outside lines or pools ring at an extension:
  1. Press [ Feature ] [ 0 ] [ 0 ] [ System Program ] [ System Program ] [ Central Tel Program ].
  2. Enter the number of the extension to be programmed for Line Ringing. The green lights next to the line or pool buttons on the phone show the current Line Ringing settings for all lines assigned to the extension. (If a line is not assigned to a button, the green light next to the button is off.) The following ringing options can be shown by the green light next to the line button.
    • Immediate Ring - on steady
    • Delayed Ring - flashes slowly
    • No Ring - flutters quickly
  3. To change Line Ringing for any line, press the line or pool button until the button light shows the correct setting (the setting for the currently selected line or pool also appears on the display).
  4. Continue programming or exit programming mode.
Jan 09, 2009 | Lucent PARTNER18 Corded Phone
Intercom
Are you referring to page all phones?
you have to put all phones into a ringing group first.
From extension 10 or 11
Feature 00
Left intercom
Left intercom
Press #502
At the group prompt, enter the group number you wish to use (1-4)
At the extension prompt, enter the extension number you wish to add to the group
It will say 1-assigned or 2-not assigned
Press 1 to assign it to the group
Repeat for all extensions
Feature 00 when finished
Now, to page the group, you will press "Intercom *7x (where x is the group number)
Example, Intercom *71 to page group 1
If you wish to put that on a button, you must go to each phone.
At each phone...
Press Feature 00
Press the button you want to program
Press the LEFT intercom button and *71 (for group 1)
Feature 00
Repeat at each phone you want the button on.
Sep 29, 2008 | Lucent PARTNER18 Corded Phone
Dial code features for setting up extions buttons.
Look around for a little red book about 4x6 inches. It has all of the feature access codes for a partner phone.
Feature buttons for intercom are programmed by FEAT 00
Press button to program
Press Intercom and dial ext
End by pressing FEAT 00
Carl
Sep 05, 2008 | Lucent PARTNER18 Corded Phone
Voice Mail
if you can not transfer a call to voicemail, there isnt a mailbox made. If you transfer a call and it doesnt go to voicemail, then there isnt a mailbox OR it isnt assigned to the voicemail group.
To assign a phone to go to voicemail (if there is a mailbox made)
at extension 10 or 11
press feature 00
LEFT intercom
Left intercom
#310 (auto VMS cover)
group 7
enter extension number.
If it says 2 not assigned, press "1" so it says assigned.
Press feature 00 when done.
If it still does not work, you need to build a mailbox. Will need to know EXACTLY which voicemail it is in that case.
Jan 15, 2008 | Lucent PARTNER18 Corded Phone
Ring back
If you call the extension internally, does it just ring no answer?
You will need to go into programming:
At extension 10 or 11:
Feature 00
Left interom twice.
#310
enter the extension you are having a problem with
pres the 1 button
the display will say 1-Assigned
Feature 00 to exit.
Jan 02, 2008 | Lucent PARTNER18 Corded Phone
Avaya 4424D Corded Phone Logo
87 people viewed this question
Top Avaya Lands Phones Experts
george  peters
george peters
Cabanaboyz
Cabanaboyz
Level 1 Expert
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
