Question about Brinkmann 810-8905-S Stainless Steel Propane All-in-One Grill / Smoker
It won't put out enough gas to cook. Can only use one burner at a time because it will not put out enough gas volume or pressure to burn more than one. And that one has to be on high in order to get enough flame to cook as if it were on low. I've changed the regulator, the gas bottle( several times) and blew air through the lines to be sure the lines and the burners were not obstructed. What would be your next suggestion. Because for what I paid for this unit and the very few times I have been able to use it without cussing and trying to figure out why it can't do something as simple as blow gas through a line, I think someone should be replacing it with something else comparable. That would my suggestion. Because I love to grill out and feel sick everytime I look at $700.00 worth of new junk sitting there unusable.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 221 Answers
Many newer grills have a safety feature built in where the valve will not
allow gas to flow if the burner valve is in ON position when the valve on
the tank is opened.
Try this - Shut of all valves, disconnect and then re-connect hose to tank,
turn on valve above LP tank, THEN turn on burner valve, light w/ spark or
match...
This feature can be really frustrating if you don't know it is in
operation...
Posted on Sep 09, 2010
Gas burns only low flow
Sounds like you may have to clean the gas lines out at the burners. Get a pipecleaner and wiggle it around in there - the common problem is little spiders, as they love the smell o f gas and crawl in there to hide. They always make a web so this makes the burner not work. Happens with BBQ's all the time too.
May 25, 2015 | ilve 48" Pro Style Gas Cooktop - Stainless...
I have a 5 Burner Thermador gas cook top SGS305FS and if I am cooking something on the middle burner, and turn on the other burners to cook something else, it seems to take a long time for the other...
You need to have the gas pressure read after the gas valve while in operation to se that the manifold pressure is not below 3.5" wc for nat gas or 11 " wc for propane.
Apr 16, 2014 | Kitchen Ranges
My Neff T67S76NO hob has a Wok burner problem, I think. The inner ring flames are fine but the outer ring can't be turned above half on before the flames start to go ragged. The more it's turned up th
it sounds to me that u need to reduce pressure although u say pressure is correct try reducing pressure and see what happens i presume u use bottle gas L P G?............in any case the flame shud not ever lift of burner and flame doesn't need to touch pan to cook hope this helps
Jan 07, 2014 | Cooktops
Pilot burnes yellow and stays lighted when I turn the may burner on its on for about 30 sec. then goes out pilot and burner
You may be low on gas in the tank and there's not enough pressure and/or volume of gas to sustain it. Also, try carefully cleaning the burner elements.
Jan 19, 2011 | Blue Rhino ES200209 Open Flame Gas Patio...
I have a whirlpool gas stove, professionally converted to propane and it"s cooktop doesn't cook hot enough when frying, it doesn't crisp the surface I don't think the burners are burning at the correct...
Have them come back and check the gas pressure... either the tank regulator or the stove regulator are running at too low of a gas pressure... for propane it should be at least 10" WC...
heatman101
Aug 31, 2010 | Whirlpool Kitchen Ranges
The first two burners on the left light and have good gas flow. When I light the middle and the left two burners the flames flicker and go out, like there is not enough gas. I cleaned the burners, tried...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Aug 22, 2010 | Kenmore Elite 900 sq. in. Cooking Area Gas...
Oven not heating enough
check your round screw-in fuses. I suspect 1 is burned out. there are typically 2.
Sep 07, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Why is my natural gas grill not getting enough gas to cook in a timely manner?
plugged burners or low gas pressure are your only two choices.
Jun 15, 2009 | Weber Gas Go-Anywhere Grill
Not enough gas to range?
you either have a gas pressure problem from your meter outside or a bad pressure regulator on the range. if you use a magnehelic guage (get from a plumming supply house) you should be getting about 11inches of water coloum, or you can call your gas company to check it out... Let me know how it goes.
Jan 09, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Brinkmann 810-8905-S Stainless Steel Propane All-in-One Grill / Smoker Logo
159 people viewed this question
Top Brinkmann Grilling Experts
Paul Carew
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Are you a Brinkmann Grilling Expert? Answer questions, earn points and help others
