Question about Amana Refrigerators
IS THERE A RESET BUTTON ON THE AMANA SZD26VW SIDE BY SIDE REFRIGERATOR
aborcass
  • 2651 Answers
SOURCE: Amana Side-by-Side Refrigerator Not Cold
can be a few things, if you open the freezer door do you hear afan running?? perhaps the fan is no good?? is there a large amount of frost on the lower plate of back wall of freezer??? very common issue to have a bad defrost thermostat.
Posted on Feb 19, 2009
jan mczeal
  • 632 Answers
SOURCE: AMANA REFRIGERATOR SIDE BY SIDE IS NOT COOLING MODEL 36531
Check/do the following:
Note: You may need the service of a qualified technician to do the job. The compressor and condenser are not user serviceable.
  1. Check for any open or burnt wiring and rewire if necessary.
  2. Check fuses and circuit breakers.
  3. Check and reset overload relay.
  4. Turn the thermostat knob to the proper setting.
  5. Pullout the capacitor and check it. Using an ohmmeter, connect the test leads to the capacitor terminals. Do the same with the test leads in reverse.The pointer must deflect to the right and smoothly moves back to the left. Otherwise capacitor is defective. Replace it with the same specifications.
  6. If compressor and capacitor is found okay, check for open thermostat. Unplug the unit and connect test leads of ohmmeter to the plug terminals. Turn the thermostat knob. The ohmmeter pointer must deflect, otherwise replace thermostat.
  7. If all of the showed no problem then you probably have a low refrigerant in your unit. Check for any leak and recharge.
Posted on Sep 04, 2009
arikrom
  • 528 Answers
SOURCE: Amana side by side. Freezer is working. Refrigerator isn't'!
  1. take all from freezer side out
  2. open back wall
  3. check if the fan is damage
  4. check the heater element
  5. check thermostat
  6. one of them is bad
  7. good luck
Posted on Jan 02, 2010
  • 572 Answers
SOURCE: Is there a reset button on an Amana side by side refrigerator?
check the compressor relay.
Posted on Feb 08, 2010
Sheikhtijani
  • 1284 Answers
SOURCE: Proper refrigerant levels for Amana Side by Side refrigerator
Hi, normally the suction pressure on a refrigerant -22 system will be between 60 pounds gauge pressure (which keeps it above freezing point) and about 80 pounds. This depends on the temperature condition.Make sure that the superheat and subcooling are correct to see what is to be considered normal for the conditions you have present.
Take care
Posted on Jun 03, 2010
How do I reset the water filter change light after changing the water filter?
press and hold the water filter button for 10 seconds. and it should reset
Mar 03, 2011 | Amana 22.6 cu. ft. Side-By-Side...
How do i reset the filter light on my refrigerator msd278ge
Simply press and hold the dispenser lock and auto light buttons on the dispenser (at the same time) for four (4) seconds until the filter status indicator begins to flash, then release the buttons. On some Amana refrigerators, you need to press the dispenser lock and water buttons for four (4) seconds until the filter status indicator begins to flash, then release the buttons.
Also note that
  • Remove the old water filter from your refrigerator by turning the handle counterclockwise and pulling it out of the filter holder. The filter is located in the upper right corner of the refrigerator.
  • Step 2Slide the replacement filter into the filter holder and turn it clockwise.
  • Step 3Press and hold the "Reset Filter" button until the indicator lights go off if your model refrigerator has a "Reset Filter" button on the control panel.
  • Step 4Hold the "Lock" and "Light" buttons on the control panel until the filter indicator lights turn off if your model refrigerator does not have a "Reset Filter" button. For models that do not have a "Light" button, press and hold the "Lock" and "Water" buttons.
  • Good luck......
    Jul 29, 2010 | Maytag MSD2758GEB Side by Side...
    I cant get my refrigerator unlocked
    Hi: I don't know if you have the manual, but you have to hold down the lock button down for several seconds to release it. That how it works. I hope this helps and you don't need service. As a last resort unplug the fridge for an hour ( don't open it in the interim) then plug it back in and see if it resets. I hope this helps, Jeff
    May 31, 2009 | Amana 22.6 cu. ft. Side-By-Side...
    How to reset red lite on water filter,on front offrig
    Press and hold the lock and water buttons at the same time for 5 seconds the green light will flash 3 times when it is reset. Good luck
    Apr 23, 2009 | Amana ARSE66MB Side by Side Refrigerator
    Ice Maker
    well ur refrigretor is;nt producing enough gas to produce ice make sure u hire some expert who can examin and solve it.
    Mar 18, 2009 | Amana ARSE66MB Side by Side Refrigerator
    Amana SZD26VW about 10 years old - no water or ice
    probaly the water inlet pump behind the fridge is defective or the filters are clogged I'd change the filter first if this dosen't help i'd say change the water inlet pump
    May 09, 2008 | Amana 22.6 cu. ft. Side-By-Side...
    Refrigerators Logo
    75 people viewed this question
    Top Amana Refrigerators Experts
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Sal DeAngelo
    Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
