Question about Sharp Televison & Video
Recently there was a storm in my area. Satellite quit working then TV went out. TV is on a surge protector and nothing else quit working but tv. The power light blinks and nothing can be done to make TV come on or stop the blinking. Have tried unplugging to no avail. My TV is 3 mos out of warranty and I can't believe it just quit working. Sharp Aquos 32in flat screen
  • Sharp Master
  • 1,606 Answers
Usually the blinking indicates a power section problem. That could have been from a power surge. Thats a shop job to fix. Since its out of warrenty you need to get an estimate first. Repair costs can be more than a new tv. Last one I saw was $450ish. If you have any local tv repair shops talk to them , then talk to sharp and get contact info for the repair depot and talk to them. Get estimates from all, then compare that to a new tv cost and you will know which way is best for you to go.
Unless you spent almost as much on the surge supressor as the tv they are only actually meant to protect the wiring in the house. The do not react fast enough to actually stop a power surge. They just cut off a short circuit problem so the house wiring doesn't overheat and burn the house down.
Posted on Sep 07, 2010
My HDTV went out in a lightening storm. What could it be?
Is your TV plugged into a surge protector? If not it very well may have gotten a power surge during the lightening storm that fried components in the TV.
Or is the TV connected to a cable box? It could be that the cable box took the hit if it's not plugged into a surge protector.
Or a possibility of both.
Aug 03, 2015 | Proscan Televison & Video
Wont turn on but tries too come on,power light blinkink
Internal power supply failure. Was there a lightning storm in your area recently or utility work being done recently? This two things usually kill TV's and other electronics with surges when power is restored. If the set is under warranty call the manufacture, if not, call you homeowners insurance agent to see if the damage is covered w/or w.o. deductible. At least you can get something toward repair/replacement costs. Future fix, purchase and install a surge arrestor in your main AC panel for the whole house or buy a power strip with a built in surge filter/protector for your expensive equipment.
Jan 23, 2014 | Samsung PN51D490 3D Plasma TV
My sharp LC-46SV50U wont turn on
get the service manual and then open it up and do a voltage check on the 5v standby.
if it's not showing anything, then you need to hunt down if it's the ic, cap, or diode or a combination thereof.
Nov 24, 2013 | Sharp LC46SV50U - Lc46sv50u 46in Lcd Ccfl...
How do i stop lightning from getting in my hdmi lines and shocking my tv? 5 tvs went down in one storm
I would recommend getting a surge protector and using that to protect your televisions. This usually will stop something the lightning from killing your tv's.. I have a surge protector and can still use my tv, computer, anything I have plugged in during a storm.
Oct 22, 2012 | Vizio 42 in. LCD TV
My lg tv won't turn on after a lightening storm
Your surge protector did not function properly, contact the manufacturer of the power strip.
Jul 05, 2012 | LG 55 55LW5600 3D LCD TV
I have a 47 inch sanyo. model# dp46848. A transformer blew in a lightning storm and now the tv will not power on. The power light will come on for 5-10 seconds and then shut off. The tv was on a surge...
But, was the cable/satellite feed protected? Lightning can come in from anywhere, not just the power line. The bad thing about the way cable and satellite installers ground things is, they ground to the same grounding system that the house does, which can backfeed the surge through the entire house - it shouldn't, but it can.
I would, however, contact the maker of the surge strip and attempt to file a damage claim. They all come with a liability warranty of some sort.
Jul 06, 2011 | Sanyo DP46848 LCD TV
We had lighnting storm pass by and our TV was plugged into a surge protector along with many other devices. When the storm passed the TV will not turn on anymore.
Likely, the surge protector failed.
Depending on the manufacturer, you may have some sort of warranty available. That is, the manufacturer of the surge protector may reimburse you for the cost of TV repairs.
But foremost, try plugging the TV directly into the wall. It could be that the socket or surge protector were fried, but your TV is ok.
May 06, 2011 | Insignia Televison & Video
No power on Samsung TV after storm
Hello Zkarim,
I'm very sorry to hear about your unfortunate new's. I had the same problem in my own home maybe a week ago.
Basically if your power flickered on and off at anytime during this storm then there was a power surge that probably fried your TV.
* First check the power where the tv was plugged in. Is it a power strip or a surge protector ? Surge protectors typically have an on/off switch and a separate reset push button.
If it is a power strip then the tv fried because there was nothing to stop it from happening (not even the fuse). If it was plugged into a surge protector then it could be quiet a few years old and not as reliable or the surge was to powerful for the limit on the surge protector.
The only thing you can do personally is send it in for repair if it's under warranty, if it is not then you can have it looked at by an authorized repair technician in your area. Troubleshooting should be fairly low, and you will at least be able to find out your options once they find the defected part.
Thank you for choosing Fixya!
Jul 15, 2009 | Samsung LE32A457 32 in. LCD TV
My tv won't turn on after it went out during a
Leave the TV off and unplugged for 24 hours then try it. If it still doesnt work you may need to consult an engineer. The TVs power supply board may have blown due to power surge/spike. I recommend getting a surge protector to avoid this happening in future.
Jul 10, 2009 | Panasonic Televison & Video
TV won't work after storm
ok lets try this hit the power button on the DVD player some go into stand by mode and when power is interrupted you have to push the button manually also reset the surge protector next get a lamp that you know works and unplug the tv and plug the lamp into the socket where the TV was plugged into turn on the lamp, does it turn on? yes then something wrong with TV again may have been in stand by mode plug back in and try pushing the power switch on make sure the TV if it has a remote is on the right im put to get a picture say like a satellite or cable or DVD player. hope this helps.
May 29, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Televison & Video Logo
122 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
