Question about Canon PIXMA MX330 Multifunction InkJet Color Printer
I've lost touch with my manual. I am trying to send a fax (it was working well before) transmission What is EDM Tx The destination line rings and rings but does not answer my fax call? whadaya whadaya please. I need the normal fax mode please.
    President:
  • 3,278 Answers
Hello, Karen.
If you mean "ECM TX", that is Error Correction Mode
Here's the link for your manual. http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx330#BrochuresAndManuals
1. Click the link, select [ Save ], specify "Save As", then click [ Save ] to download the file.
Memo :
If you select [ Run ] ( or [ Open ] ) instead of [ Save ], the file will be automatically installed after it is saved.
2. The downloaded file will be saved in the specified place in the self-extracting form ( .exe format ).
3. Double-click the downloaded EXE file to decompress it, then installation will start automatically.
You may want to look at the Getting Started Guide, which you can find here:
Hope this helps.
Posted on Sep 07, 2010
How do i set my fax machine to recieve and send faxes
Dear
Connect the telephone line to the LINE socket of the fax machine and a telephone receiver unit to the EXT socket of the fax machine.
To send a fax, put the document on the platen glass (face downward) or face upward in case of ADF.
press on hook dial, (here the dial tone on machines speaker)
dial the fax no. ( wait for call connection and here the fax Rx. tone)
press START.
To receive a fax two procedure can made, manual- lift a hand set of telephone receiver on incoming ring, here the TX tone(periodical beep tone) press * 9 * of the telephone receiver. In auto mode go to fax setup select ans. to ring or auto fax etc. to activate atuo reveive of fax.
Hope this may helpful.
Thanks.
Aug 11, 2014 | Samsung SCX 4521F All-In-One Laser Printer
How do I change the Baud rate on a canon f80 fax
To set the receive speed
Change RX Start Speed Setting The message [START AGAIN] will appear if phone line conditions are less than perfect. Decrease the transmission (RX or send) speed if this message appears frequently on the LCD.
  1. On the operator panel, press <Menu>.
  2. Press the left '<' or right '>' arrow repeatedly until [USER DATA] appears.
  3. Press [Set].
  4. Press the right arrow repeatedly until [FAX SETTINGS] appears.
  5. Press [Set].
  6. Press the right arrow repeatedly until [RX SETTINGS] appears.
  7. Press [Set].
  8. Press the right arrow repeatedly until [RX START SPEED] appears.
  9. Press [Set].
    1. The factory default RX (send) Speed is 33600 bps.
    2. You can select from the following RX Speeds:
      14400 bps
      9600 bps
      7200 bps
      4800 bps
      2400 bps
  10. Press the right arrow to display the applicable RX Speed.
  11. Press <Set>.
  12. Press <Stop> to return to standby mode.
To Set the Send Speed
Change TX Start Speed Setting The message [START AGAIN] will appear if phone line conditions are less than perfect. Decrease the transmission (TX or send) speed if this message appears frequently on the LCD.
  3. Press [Set].
  5. Press [Set].
  6. Press the right arrow repeatedly until [TX SETTINGS] appears.
  7. Press [Set].
  8. Press the right arrow repeatedly until [TX START SPEED] appears.
  9. Press [Set].
    1. The factory default TX (send) Speed is 33600 bps.
    2. You can select from the following TX Speeds:
      14400 bps
      9600 bps
      7200 bps
      4800 bps
      2400 bps
  10. Press the right arrow to display the applicable TX Speed.
You can download a copy of the user manual for the F80 at
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=7175
Please make sure to rate this solution. Thanks.
  1. Press <Set>.
Apr 29, 2010 | Canon MultiPASS F80 All-In-One InkJet...
Cant send or receive fax just get a fast busy signal when I try to send fax. please help
Normally a fast busy signal indicates a problem with the phone line. You need to call the phone company and have them do a "line check"
Sometimes they can fix this over the phone, sometimes a service call is required. No charge to you tho.
Mar 01, 2010 | Office Equipment & Supplies
TX Report misses out Destination Number
The ID on the TX report only show the ID if the ID is programed on the fax machine you send it to.The only way is to ask the destinated party to program the Fax name.
Apr 30, 2009 | Canon FAX-JX200
I want to have the MX310 to answer on 4 rings
Change the ring count 1. Press the <Menu> button repeatedly until [FAX SETTINGS] is displayed.
2. Use the [ left.gif] or [ right.gif] to select [RX SETTINGS] then press <OK>.
3. Use the [ left.gif] or [ right.gif] to select [ RING COUNT] then press <OK>.
4. Use the [ left.gif] or [ right.gif] to select the desired number of rings. Press <OK> then press <Stop/Reset>.
To print the Activity Report, Coded Speed Dial List, User's Data List or Memory List: 1 . Press <FAX>, then press <Menu>.
2 . Use leftright.gif to select [PRNT REPORT/LIST], then press <OK>.
3. Use leftright.gif to select the desired report, then press <OK>. The report or list is printed.
Try to download the manual
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=15603#DownloadDetailAct
I hope it helps!!!
The TX Report and RX Report print upon transmission or reception offaxes depending upon the settings made in [FAX SETTINGS->TXSETTINGS->TX REPORT] and [FAX SETTINGS->RX SETTINGS->RXREPORT], respectively
Dec 08, 2008 | Canon PIXMA MX310 All-In-One Printer
Turn off confirmation page
log into the web administration page as administrator
choose fax/scan tab
report settings
Tx Report
choose turn on/off/if tx fail
I chose both single and multiple destinations
if tx fails
Tested scan to email and fax to bad addresses and page printed as confirmation of failure
No pages printed for successful Tx
Note - you can still manually request confirmation at printer menu
Fax/scan
fax menu
tx report
on
enter
start fax or scan to email
Nov 05, 2008 | Minolta bizhub 200 All-In-One Printer
Busy signal when trying to send fax
of course..is that phone line, by chance a high speed internet connection?
May 28, 2008 | HP PSC 950 All-In-One InkJet Printer
FaxJet 335, tx error
call the number manually . and does it answer with a warble immediately or does the phone ring a lot and then answer.
your timeout may be set too short on the sending fax setup.
Dec 14, 2007 | Philips FaxJet 375 Plain Paper Inkjet
Fax
did you specify a destination to save the fax to ?
follow your user manual for instructions on how to do it propperly
The problem is in your configuration double check it
if you are still getting problems download and use winfax its fast easy and works
Dec 10, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Canon fax 2060P not recieving faxes
It seems that the protocol is failing. Just check, by printing a receive report. If there are errors it is after the check frame. If no errors, it is failing before the check frame. In either case, 1st aid is to listen using a handset for noise or static on the line. If the line is clear, then you will have to call service to change the tx/rx attenuation.
Dec 06, 2007 | Canon LaserClass 2060P Plain Paper Fax
Canon PIXMA MX330 Multifunction InkJet Color Printer Logo
56 people viewed this question
old marine
old marine
