IHAVE A DVD PLAYER RECORDER DVD3460. I ENTER THE DETAILS IN THE TIMER AND IT RECORDS THE DETAILS AS VALID, 5 TIMES IN A ROW IT SHOWED FAILED.IT HAS ON OCCASIONS RECORDED CORRECTLY, BUT NOT OF LATE?? PLEASE ADVISE. DENNIS dcswain@orcon.net.nz
  • dcswain May 14, 2008
    the model is a phillips dvdr 3460
    dennis
    Genius:
  • 1,142 Answers
Thank you for posting your concern details however i would be
needing few more details from your side if necessary and
allow me few mins to come up with the resolution.
Posted on May 14, 2008
  • Maanita Chadha
    Maanita Chadha May 14, 2008
    May i know the model and the make of the product in details
    so that it can help me resolving the issue is a more prompt
    manner
  • Maanita Chadha
We have a Philips DVD3460 recorder. Where in the manual does it inform us on while Watching T.V. and DVD is recording another T.V. channel?. Would love to know " how to do this"?
It depends on your setup.
Think of the Philips DVD3460 as an independent, standalone television set. It has its own analogue tuner, and its own video input.
If you have an analogue RF TV signal (coaxial cable) going in to the Philips DVD3460, you can watch whatever you want on any other TV connected to the TV signal coaxial cable, since the regular analog TV cable carries all of the channels.
However, if you are using a cable or satellite box and use the "Video in" function of the DVD recorder or just have the DVD recorder tuned to channel 3 or 4 to record from a cable or satellite box, you can't record one channel and watch another unless you have a second cable box..
Apr 24, 2011 | Audio Players & Recorders
Timed recording
you need to program the vcr and connect the signal to him the channel you need to usa put it on him enter to the menu and put the timer to record it
Oct 22, 2009 | Samsung DVD-V4600 DVD Player/VCR
Timed Recording - Won't record VHS or DVD
Bought a new Sony DVD recorder/player with VHS.
Dec 29, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Toshiba DVD recorder timer recording does not start
Does the unit not require to be in "Standby" for recording to commence.
Nov 30, 2008 | Toshiba DRW2 DVD Recorder
Timer programming
The remote control is key to timer recording. Notice the selections are color-coded: grey-black for VCR, gold for DVD. Then look at the second and third rows of buttons. Each button has multiple functions depending on if the VCR or DVD button has been pressed. To record from TV signal to VHS, press the VCR very top button. (The controller will also control your TV if set up properly, so be sure the small switch at the top-left of the controller is set to the VCR/DVD side. I use a separate controller for my TV so I never change this.) Now press the "PROG." button located beside the "3" button. (Your television must be on and set to "see" the VCR not the normal TV signal.) Now look at the second row of buttons, the ones with the "+" signs. The grey words below them indicate what they'll do when pressed (the same buttons do what the gold words say when the DVD is selected.) So to set the start time, press the first "+" button with the word "START" below it. That sets the start time of the show you want to record. It'll go in 30-minute intervals if you hold it down, otherwise it's a minute-at-a-press. If you go too far, you can back up with the third row's "-" button. When you have the start time set, move on to the next button labeled "STOP" and similarly set the end-time of the program. Continue with the third "+" button to set the date you want to record. Lastly, set the channel by pressing the fourth "+" button labeled "CH." It's a bit tedious if you have a high channel number to get to. When you have all these set properly, it's important to then press the "TIMER" button (located next to the keypad number 6). That turns the VCR off but "watching" for the settings you've just made, and it'll wake up and do the recording at the proper moment. You can confirm you've got it waiting by looking at the display on the VCR; to the left of the channel number a red "clock" image should be lit. That says it's waiting. You can program several shows to record by repeating these steps, or you can do them all sequentially by setting the first one, then pressing the "PROG" button again (rather than the "TIMER" button) and setting up the next recording. When you're done, THEN press the "TIMER" button and the VCR will go to sleep until it's assigned wake-up time.
Sep 16, 2008 | JVC HR-XVC30U DVD Player/VCR
Samsung DVD-V4600A Combo DVD / VCR will no longer timer record to Videotape
Storms tend to fry most delicate electronics. Quality surge protection is required.
Ben
Jul 25, 2008 | Samsung DVD-V4600 DVD Player/VCR
Timer Recording
This is from the KR10 manual. Hope it helps.
1. Set the clock before setting a timer.
2. Insert a recordable disc with enough space.
Then:
1. Press [TIMER PROG] on the remote
2. Use up/down arrows to select "New Program" then press [ENTER]
3.Use up/down arrows to enter the date, then press right arrow
4. Use the arrow keys to enter the start and end time, then press right arrow key.
5. Use the up/down arrows to select the external input position to which your cable/satellite box is connected, then press [right arrow]
6. Use the up/down arrows to select a recording mode.
7. Press [ENTER] when all items are entered.
8. Press red [I/O ON STANDBY] to set a timer programming.
DO NOT FORGET THIS LAST STEP! The timers will not work if the recorder is not in standby mode.
Jul 24, 2008 | Toshiba D-KR10 Multi-Drive DVD Recorder
Magnovox MWR20V6 will not begin recording when it should.
This is more a work-around than a solution, as the unit is failing to function normally; however, having the identical problem I observed that the unit is failing to power on at 2:00 minutes before beginning recording, a necessary step to record to DVD.
My work-around is the following:
1) Set up the timer, inputting necessary date, time, etc. as normal. With the unit still powered on, start the timed recording mode by pressing timer set, as normal. You will see the red clock icon and the DVD logo iluminate on the VFD.
2) Press the Standby-On power button. This will power the unit on in VCR mode. You should at this time be unable to switch from VCR to DVD mode since the DVD is still in timer mode. LEAVE THE UNIT POWERED ON in this manner. The timer will function and the DVD will record normally.
I have no clue why my unit suddenly forgot how to power up on its own in order to record to DVD. If anyone has an answer for that one please post!
Tom Gee
May 03, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
DVD Recording from Television on DVD and VHS
First off, be sure that you are on the channel that you want to record!!
Press the setup button, the SETUP menu screen appears.
Select "timer rec set".
Then another screen comes up... select "new"
Enter your times, dates, etc.
Dec 18, 2007 | Sansui VRDVD4005 DVD Player/VCR
Record
i have uploaded the user manual for this model, it should be visible within the next 24 hours. the quick version is this:
if you haven't done so yet, set the clock
menu/ use up/down arrows to select "clock set", press right arrow to select, set day, year, etc using up and down arrows, when each is set, the right arrow moves you to the next bit
once clock is set
timer recording
menu
use up and down arrows to scroll to timer recording, and press the right arrow to select
set the program number (1-8)
set frequency (once, daily, weekly)
set the date to record
set start time (i usually go 5 mins prior)
set end time (i usually go 5 mins after)
set channel number
set tape speed
exit by pressing clear/c reset
press t-set to activate the timer
the timer rec light should come on, the timer recording will not be active unless you press the t-set button
hope this helps
trin
Nov 16, 2007 | Sylvania SRD3900 DVD Player/VCR
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
