Question about LG KU990 Viewty
Touch sensitive screen not working
Touchpad callibration will not work or recognise anything being touched
  • 2 more comments
  • ninjadic May 14, 2008
    my phone wont let me txt ring or anything
  • Anonymous May 14, 2008
    same problem! ll of a sudden the touch screen doesnt work!!! soooo angry, please help!
  • manusrivatsa May 18, 2008
    Ya me too having a same problem touch screen not working even after rebooting, removing n replacing battery, sim, memory card
  • Anonymous Jun 30, 2008
    Touch screen not working , sometimes .
I found a solution for the LG KU990 Viewty touchscreen not responding problem. After thinking about twisting my phone, I came up with another solution which actually works every time. The touchscreen works via layers of plastic that when contact is made, a signal is triggered from the coordinates of the contact. However, when the phone has pressure, these layers of plastic stick together somehow. So, to fix it.... Get a small strip of adhesive tape that will not leave a sticky residue on your screen. Apply that tape in several spots on the surface of the screen, and lift it away from the phone with light pressure. Repeat this in several areas of the screen. That's it. You're done. Your screen should function properly. Simply recalibrate the touchscreen at this point in your settings menu. I hope it helps everyone with any type of touchscreen. I know it helped me. The touchscreen phones are totally useless using only the hard keys!
Posted on Jul 11, 2008
THANKS FOR YOUR HELP
DIDNT REALLY HELP ME THOUGH YAANO :D
ID APRICIATE IT IF YOU GAVE ME SOME MORE INFO
MY PHONE HAD BROKEN
LIKE NEED CALIBRATING BUT I CANT GET ONTO THE MENU TO CALIBRATE IT????1
ELPP'
Posted on Dec 18, 2009
Have you put anything on the phone other than the protective film? did you put it in a leather case that has a thick plastic covering it? was it pressed against something? did it get magnetized? if so, then that might be the problem. cause it says in the manual that putting anything over the LCD screen, sitting on it or having it near any strong magnetic field might render the touch panel useless.
restarting and or replacing the leather case might do the trick but for the "big ones" you need to send it back for repairs.
Posted on May 20, 2008
    Problem Solver:
  • 11 Answers
If the touch screen suddenly stops working.. you should restart the phone. It is troublesome.. I know..
If the touchscreen is not really working ever after re-booting the phone. then you must return it from where you got it. That is totaly un acceptable..
be sure to apply a bit of pressure also. Viewty is not as sensitive as Iphone.
Posted on May 15, 2008
I have to hit touch pad 3-4 times to work when doing anything Dell Inspiron 1501
Make sure you have the latest touchpad driver from support.dell.com, then in the touchpad settings (Control panel, Mouse, touchpad tab) adjust the sensitivity.
If adjusting the sensitivity has no effect then it may just be wearing out, which would mean a palmrest replacement. Those are around $20
http://shop.ebay.com/i.html?_from=R40&_trksid=p5197.m570.l1313&_nkw=inspiron+1501+palmrest&_sacat=See-All-Categories
Jul 18, 2011 | Dell Inspiron 1501 Notebook
I have a Dell laptop computer with Windows Vista Basic. The mouse on the screen has become very sensitive and sometimes it clicks on an item when it scrolls across the screen. How can I make it less...
  1. Right-click on the desktop and select Personalize > Mouse Pointers . The Mouse Properties settings window will open.
  2. Alternately, click Start and type Mouse in the Search field, and select Mouse when it becomes available in the program list. The Mouse Properties settings window will open.
  3. Select the Device Settings tab. Select the Synaptics TouchPad device and click Settings . In the Properties for Synaptics TouchPad window, expand the Sensitivity topic.
  4. Select the PalmCheck option to adjust the sensitivity of the touchpad to avoid erratic cursor movement caused by accidental touching of the pad during normal typing.
  5. Select the Touch Sensitivity option to adjust how much finger pressure is required to move the mouse on the screen and how responsive the touchpad is to taps.
Jul 12, 2010 | Dell Vostro 1000 Notebook
My Hp dv5 suddenly started giving problem when typing the cursor is jumping. what will be the reason? I cannot type continuously. I hav to search for the cursor where it goes. suddenly it disappears and...
This issue could be due to corrupt Touchpad drivers or corrupt Touchpad sensitivity settings or corrupt BIOS settings. To isolate this issue, please perform the steps provided below: 1. Uninstall and reinstall touchpad driver on the notebook. 2. Decrease the Touch Sensitivity of the Touchpad. If you are using Windows Vista on your notebook then you can follow the steps listed below for decreasing the touch sensitivity of the touchpad: a. Click Start and type ?Mouse? without quotes in Search field. b. Click on Mouse from the results list. c. This will open d. Click on Tapping tab in the Mouse Properties window. e. Click the Touch Sensitivity Button to launch Touchpad settings. f. Move the slider to the desired setting (in between Light touch to Hard touch) This will adjust the Touch sensitivity of the touch pad. Now check for the issue. 3. If the issue persists, then update BIOS on your notebook. To update BIOS, go to the HP drivers download page for your notebook model and then download and install the latest available BIOS update.
May 20, 2010 | HP Pavilion dv5000t Notebook
Asus touch pad too sensitive
There should be settings in the touch pad software on your machine or in the task bar that you can directly access to change all manner of personal idiosyncrasies related to HID. (Human interface device) Try also going into the control panel and looking for input devices, mouse, touchpad and adjusting the settings from within there.
Mar 11, 2010 | ASUS Computers & Internet
Touch screen doe not respond, it terns on visually but it don't let me do anything the touch screen don't work.
there is a callibration for touch screen in the touch screen settings.. if that does not work - the touch scren probably needs to be replaced.. It happens unfortunately..
Have a great day
Mar 06, 2010 | LG Prada KE850 Cellular Phone
Acer aspire touchpad over sensitive
Your laptop should have software pre-installed for your touchpad. This should probably be in the Control Panel. Once you find the software there should be options to change the sensitivity. Hope I helped.
iSpearz.
Jan 11, 2009 | Acer Aspire 5500 5570-2609 Laptop
Acerr Aspire 5315-2940
I don't know if you mean that your cursor suddenly moves as you are typing? If so, it is likely your touch pad is too sensitive. I have a mouse w/mouse pad but never disabled the touch pad. So i disabled the touch pad and it solved it for me. If you want to be sure it is the touch pad being over sensitive, then type a paragraph but keep your fingers and palms far away from the touch pad. If the problem improves, like it did for me, then the touchpad is too sensitive. You can go into the settings for the touchpad to change the sensitivity setting to make it less senstive and see if that works and it does not then press Fn +F7 keys to disable the touchpad.
Aug 26, 2008 | Acer NSK8458AN Keyboard
Problems with TouchPad
only thing i know is to replace the pad.
Nov 06, 2007 | Creative Labs Zen Touch MP3 Player
Sensitive touch pad
Hi, click on start and control panel. go to mouse properties. Try to look for a tab that says either touch or touchpad. you can change the sensitivity settings there. however if this doesnt work, this could only mean that this is a physical problem with the toucpad. try to apply pressure on the outer side of the touchpad. if it moves, you're gonna need a replacement palmrest.
Oct 02, 2007 | Dell F3534 Touchpad
LG KU990 Viewty Logo
953 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
