Question about KitchenAid Dishwashers
We have a kitchenAid dishwasher -- just installed last year new-- we cannot get the rinse aid low light to go off. We have filled it up to where it can no longer hold anymore and the light is still on. I have tried to cut the power on/off and it still remains on. Any suggestions on how to get the light to go off? thank you.
  • 5,081 Answers
Check to see if the "Heat Dry/Lock" button is lit up. If it is, press the button and hold it for four seconds to unlock your dishwasher controls.
Close your dishwasher door firmly and press the "Cancel" button. Wait two minutes for your KitchenAid dishwasher to drain and reset.
Close the dishwasher door and press the "Start/Resume" button if the "Start/Resume" button is flashing.
Throw your circuit breaker or remove and replace the appropriate fuse to reset your KitchenAid dishwasher to the factory default settings.
Posted on Sep 07, 2010
'low rinse' stuck on with full rinse aid, can't start wash cycle
Actually, if you look closely at that Low Rinse button or emblem, you will see a little lock symbol above the words "Low Rinse", and I'll bet THAT light is the one that is on. Basically, you have the control lock (or child-lock) turned on. To turn it off, you have to press and hold the Sanitize button for 3 to 5 seconds until that light goes off. Now your dishwasher will work!
Mar 11, 2015 | Samsung DMT400RHS Builtin Dishwasher
Actually, if you look closely at that Low Rinse button or emblem, you will see a little lock symbol ABOVE the words "Low Rinse", and I'll bet THAT light is the one that is on. Basically, you have the control lock (or child-lock) turned on. To turn it off, you have to press and hold the SANITIZE button for 3 to 5 seconds until that light goes off. Now your dishwasher will work!
HOW TO CHANGE FROM LOW RINSE TO HIGH RINSE
Fill up the rinse-aid resevoir. Or (depending on exactly what you are asking), turn the little indicator just inside the rinse-aid fill port to a higher number.
Feb 22, 2015 | Samsung Dishwashers
The last few times I filled the rinse dispenser and ran the dishwasher I notice the arrow showing the rinse aid is almost empty. Impossible. What is going on with this?
THE ANSWER IS YES. FROM YOUR DESCRIPTION IT SOUNDS LIKE THE DISPENSER PUMP OR RESERVOIR IS LEAKING. YOU NEED TO REPLACE THE WHOLE SOAP DISPENSER. ALTHOUGH DISH WASHERS NEED THE HELP OF RINSE AID IT IS ONLY DISPENSED A DROP OR TWO AT A TIME DURING THE FINAL RINSE CYCLE PART OF THE WASH. HOPE THIS HELPS AND THANK YOU FOR READING THIS.
Oct 07, 2014 | KitchenAid Dishwashers
I have an Electrolux Dishwasher that always starts on low rinse
Hello Friend, this is Z. Thank you for your post!
I see that your Electrolux dishwasher starts cycle on low rinse. This typically indicates your dishwasher has low rinse aid. The RINISING AGENT LOW light, typically located near the Rinse Only Pad, comes on at the end of cleaning cycle when the rinse agent reservoir is low. The light will remain on through 5 successive cycles or until the reservoir is filled. Also, using rinse aid will enhance dryer performance and reduces water sports and filming. Hope this helps!
Jun 04, 2014 | Electrolux Dishwashers
The "Rinse Aid" red light
The rinse aid light is just an indicator to let you know the rinse aid is low. You fill it in the container next to where you put the detergent. Just push the yellow button and the lid will pop up. rinse aid is more important on the newer miele dishwashers, as they dont have "active drying" like the older dishwashers did. They depend on the rinse aid to sheet the water off the dishes at the end of the cycle. They are designed this way to reduce energy consumption. If you choose not to use rinse aid, and you dont mind wet dishes at the end of the cycle, either disregard the red light, or fill the rinse aid dispenser with water to trick the machine into thinking it is full.
If you are not going to use the onboard water softener, you can turn it off. Refer to your owners manual, or call miele tech support at 800 843 7231 and they can walk you through the programming to disable the water softener. these are not fault lights, they are simply reminders that you need to fill the containers.
Jul 20, 2011 | Miele Dishwashers
Kitchenaid KUDS02 Rinse Aid dispenser does not work
I don 't know how to fix the dispenser; however, there is a jet dry product that is sold in stores that is in solid form, you just clip it to the upper rack. I have seen it in Wal-Mart in the detergent aisle.
Sep 28, 2008 | KitchenAid 24 in. KUDS02FRSS Stainless...
Fisher Paykel DD602 burning smell
What is the Jet Dry? if you mean rinse aid, then no this light means that you need to put in more rinse aid
Mat
Aug 04, 2008 | Fisher and Paykel 24 in. DD-602 Built-in...
1987 In-Sink-Erator Classic Supreme (Just like KitchenAid from that era) - leaked Jet Dry after it was filled. Haven't taken door apart yet to figure out what is wrong. Also, after washing/rinse/dry is...
You have to replace the rinse aid compartment if not the whole inside door shell ,the reason for the coating is because your not using rinse aid.If you are using the same soap than you need to replace the leaking dispensor.
May 20, 2008 | KitchenAid Dishwashers
Dishwashers Logo
227 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
