Question about NorStar Meridian M7310 Phone
Does not matter what button i press, it calls other extension. cannot do any features, etc.
    President:
  • NorStar Master
  • 860 Answers
Sounds like one of the buttons in the top field are stuck down. Check them carefully.
Posted on Sep 08, 2010
How to pick the call from other extensions
I have downloaded several manuals for the Avaya by searching online, some are good basic user guides and some very technical. You can pick up a call in several different ways - here is a copy from the manual on call pick ups:
2.2.2 Call Pickup
If you hear another phone ringing, there are a number of ways that you can answer the call if you know the user, group
or line being called.
1.If already on a call, end the call by pressing Drop or put it on hold by either pressing Hold or pressing the
button which the call is on.
2.Press an idle Intercom or Call Appearance button.
· To pickup a call ringing at a particular extension:
Dial 6 followed by the extension number at which the call is ringing or parked.
· To pickup the longest waiting call in a pickup group:
Dial 66 followed by the pickup group number (1 to 4).
· To pickup the call ringing on a particular line:
Dial 68 followed by the two digit line number.
3. You can continue the call handsfree or switch to using the handset or headset (press the HEADSET button).
To Create a Call Pickup Button (ETR 18D/ETR 34D Phone)
1.At the phone press Feature 00.
2.Program Extension: is shown on the display.
3.Press the button that you want to edit or enter a number between 03 to 80 to select a button. The current setting
of the button is displayed.
4.Press the first intercom or call appearance button.
5.Dial 6 followed by the target extension number.
6.The button function is changed to Call Pickup followed by the target extension number.
· Exit programming by pressing Feature 00. You can also exit programming mode by lifting the handset, then
placing it back in the cradle.
To Use a Call Pickup Button
1.Press the Call Pickup programmed button
May 29, 2014 | Avaya Corded Phone avaparp18d
How do we unrestrict long distant calls nortel t7316e
i got this from Nortel expert and it works:
- press feature **266344
- user ID: 738662 Press ok
- Password: 266344 Press ok
Terminal & Extensions will appear
- press Call Timer button 1 time
write your extension or the extension you need to configure
or press find till you find the extension you need
- press Ring Again button 4 times
Restrictions will appear on the screen
Restrn Filter will appear
- press Ring Again button 1 times
Filters will appear
Normal 02 will appear ( it can be any 2 numbers)
- press CHANGE which appears on the screen
Type 00
and then press the end call button
Jan 12, 2012 | Nortel T7316E 2-Line Corded Phone
How do i forward my office calls to my cell phone
Go into programming, set #322, and your extension to have permissions for forwarding.
Then, set your cell number as a speed dial at your extension. Feature 00, then feature 80 and enter the number as you would dial it from your extension.
then press a button with lights, and press feature 11xx80. where xx is your extensoin number.
When done, press feature 00 to get out of programming.
To activate, press the button you programmed the forwarding on., then the green light will come on. To un forward, press the button again.
Sep 03, 2010 | Avaya Corded Phone avaparp18d
Can I set up an extension to automatically transfer any calls received to a different extension using the T7316E?
You can transfer any incomming calls to another extension using call forward. On the set you wish to foward, either press your foward key or enter feature 4 the display should ask for an extension to send the calls to, enter receiving extension. Press your foward button or feature #4 to cancel fowarding.
Sep 29, 2009 | NorStar T7316E Corded Phone
How do I transfer calls to someone else in the office using Norstar T7316 phone?
If your telephone doesn't have a transfer button programmed press feature *3, the button you want the transfer button to be, and enter feature 70. While on the call press the transfer button (or press feature 70) and the extension you want to transfer to.If you want a screened transfer, wait til the extension called answers,and ask if they wish to talk to the caller on the line. if they dont, pick up the caller off hold. if they want to talk to them hang up and they'll recieve the call. If you want to blind transfer, hang up after youpress transfer and dial the extension and they'll get the call without screening.
Sep 28, 2009 | NorStar T7316E Corded Phone
When call goes to voicemail, it says call being transfered
I understand that you would like to bypass Auto Attendant for your lines.
On extension 10 or 11
Feature 00
Left Intercom, Left Intercome
#208
Line 01
Enter your extension number
#208
Line 02
Do the same for all of the lines.
Go to your extension to program a voicemail cover button. Without it being on voicemail wont pick up
Press Feature 00
Select a button and call it Call Cover press it
Enter Feature 15
Feature 00
Press that button so the green light lights up.
Test.
Jun 18, 2009 | Lucent PARTNER18 Corded Phone
I cant forward calls on a partner 18D phone
Chad first think is you need to enable your extension in comand #322 This is done on ext. 10 or 11 Press Feature 00 Left Intercom, Left Intercom #322 Enter your extension number Press 1 to assign Feature 00 Next you will need to program your mobile number in speed dial On extension 10 or 11 Press Feature 00 Feature 85 Input your mobile phone number Next is to program a button on your phone Go to your phone Press Feature 00 Select a button to program (Press it) Press Feature 11 dial 85 Done Button works like a toggle switch on and off
Jun 10, 2009 | AT&T Partner 18 Phone (315805B)
How do I voice call another extension and use handsfree overthere
Try Feature 66 and the extension.
If you want to program this feature on your set, find an empty button (feature * 0 and press the keys to see what is on those keys)
Feature * 3
press the button that you want to program
Feature 66
this will program the button for Voice Call.
May 28, 2009 | NorStar Meridian M7310 Phone
Adding extension
If she has a working phone, she is set up.
If you want a button to see when she is on the phone, and that calls her when pressed.....First you have to find out her extension number, so just have her call your extension....it will be on the display.
Then, when you know the extension number, at your phone, find a blank button.
Press Feature 00.
Press the button you want to set her up on.
press the LEFT intercom, star (*) and her 2 digit extension number.
when finished, press feature 00 again.
Now, pressing the button, will page her phone.
Jan 08, 2009 | Lucent PARTNER18 Corded Phone
Lost programing
From extension 10.
you have to set the ringing.
feat 00
left intercom twice
right intercom once
enter ext number
touch the lines util they display how you want them to ring
feat 00 when done.
To set the feature to p/u a ringing call
feat 00
left intercom twice
right intercom once.
press: ** (then press lines in order 1, 2, 3, 4, etc)
then press ** again.
feature 00
repeat both for all extensions.
Mar 05, 2008 | Lucent PARTNER18 Corded Phone
NorStar Meridian M7310 Phone Logo
35 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Jose Ma DM.
Jose Ma DM.
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
