Question about Linksys Wireless-G WRT54GL Router
Internet connection I can only get an internet connection if my ADSL Modem is connected to WRT54GL through one of the ports 1-4. I cannot get a connection through via the internet port!B28
  • 111 Answers
Connect a computer to one of the lan ports 1-4.
Connect the adsl modem to "internet" or "wan" port of hub.
Open the hub's configuration page in your browser, usually this is Under Setup->Basic Setup, set the configuration for "Internet Connection Type " to "Automatic Configuration - DHCP". Under Network Setup, enable the hub's internal DHCP server so your lan hosts can get their ip's from the hub. Each local computer should have DHCP enabled. Your adsl modem must support DHCP for this to work, some do not. If it still doesnt work, try setting "PPPoE" instead of DHCP.
Posted on May 14, 2008
Connecting a Linksys WRT54GL. no internet connection detected
The ISP modem connects to the main LAN port on the router. The PC connects to any other port. Done. You should have internet via wire at this point.
Feb 12, 2013 | Linksys Wireless-G WRT54GL Router
My internet connection is slow. wireless home network setup connected to adsl.
is it as slow as when you connect it from the router(not the modem) to your pc with a wire instead of wireless? if so its bc adsl is slow in nature and you may need a filter adapter going into your MODEM first
Mar 25, 2011 | Linksys Wireless-G WRT54GL Router
I have a DSL502T ADSL Router,and have bought a new emachines computer. I can not connect to the internet. The computer has a wireless connection loaded but I want to connect by dailup Please could you help...
You are a bit confused with the various components required for Internet connections.
If you have a dial-up connection with an Internet Service Provider, all you do is connect your computer's modem port to the phone line and dial the phone number of your Internet Service provider.
If you are connected to the Internet Servise Provider by ADSL and have a combined ADSL router and modem then you connect the phone line to this router/modem. If the ADSL modem is separate component then the phone line is connected to the ADSL modem and this modem is connected to the router with a LAN cable and the computer is connected to the router with another LAN cable. If the route is wireless and the computer has a wireless card then you don't need a LAN cable between the router and the computer.
If you are connected to the Internet by ADSL, to secure your Internet connection and configure your computer so it can connect to the Internet, please follow my instruction - click on this link :-
Dec 17, 2009 | Computers & Internet
Linksys speed cut off
First, are you connected via Ethernet cable or are you linking via Wi-Fi? If Wi-Fi the speed is alway slower (up to 54 Mps) If connected by Ethernet, your connection speed should read 100 Mbps. Once you have determined the connection mode and speed.unplug the wireless router and connect the computer directly to the modem. Now test the speed and see if the speed lag is still ther. If not, you have a routing /networking issue but, it it is still the same speed, it could very well be heavy traffic ( a lot of people drawing from the same local area signal., usually at specific times of the day).
Nov 24, 2009 | Linksys Wireless-G WRT54GL Router
I have an ADSL D-Link modem (DSL-300G)that works fine. I hooked a D Link wired router, EBR-2310 and can't get to the internet. It use to work until one day recently the kid moved wires arround because no...
First: Connect your computer directly to the ADSL modem. It has an Ethernet port.
If you can't get to the Internet while your computer is connected directly to the modem, then ytour router never will either. Call ISP if you can't connect to the Internet when directly conencted to the modem.
Next: Check your router wires again, The modem must be connected to the "special" port on the router. Look at the router. There is one port separated from the rest. Connect the modem to that port. Conenct to the Internet.
Still no Internet?
Reset your router by pushing a stylus (straightened-out paperclip) into the reset "hole" on the router (with router powered ON).
Push & hold for 30 seconds or until the lights do their reset dance. Connect to the INternet.
Oct 07, 2009 | D-Link 4-Port Ethernet Broadband Router...
connect the DSL end to the INTERNET port in your modem. then in the ETHERNET ports, connect any computers. then from there you should be able to access internet. if not, follow this to configure
1. in a PC connected to your modem, open a browser and visit
when prompted: username = admin password = admin (or try also <blank> or no password
Sep 28, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Haw I can connect tow adsl line in one modem ?
Your connection should be like this:
PC --> Port 1 on the router
Modem --> Internet or WAN port of the router
Dec 18, 2008 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Zoom router
Have you tried configuring the ADSL modem router for the internet connection?
Its possible that since you have changed the ADSL modem router, you may have to configure the ADSL modem router for it to work fine. The configuration depends on what Internet provider you have but you may try these steps for now:
1. Make sure the connections are correct. Connect the computer to the LAN port and the ADSL line to the port assigned for that behind the device.
2. Launch an Internet browser and access and press enter. If a dialog box appears, set the user name as admin and password as zoomadsl and press enter.
3. On the basic setup page of the ADSL router, set the appropriate encapsulation and other settings based on the settings of your provider. If you do not know the settings for your provider, there is a table specified on the user guide for the ADSL router. Here is the link:
Jul 19, 2008 | Zoom X6 (5590) DSL Modem (55900003)
How to connect linksys router with aztech adsl modem
To setup your router
first check..
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If it is not, contact your Internet Service Provider. If it can go online,
to setup connection..
Step 1:
Connect the Broadband modem to the router’s WAN or Internet port.
Step 2:
Connect the computer to any available numbered port (1, 2, 3 or 4).
NOTE: In this example, we’ll connect the computer to port number 3.
Step 3:
Make sure the power adapter is plugged to an available power outlet.
Step 4:
check if you are able to go online wired..
if not your router has to be configured first,
to config your router i need some more information
your internet service providers (isp)name , and how many computers do u have totally..
Nov 16, 2007 | Computers & Internet
Linksys Wireless-G WRT54GL Router Logo
224 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
