Question about Fujitsu fi-5110C ScanMaker Scanner
I have a Fujitsu fi-5110C scanner, which I purchased on July 2, 2009.. After I scan a documents, a black line running up and down the page appears on the scanned image. Jim Allen
  • jim8260 Sep 07, 2010
    I tried that using a pre-moistened eyeglass lens cleaner. Didn't work.
    Jim
    President:
  • 3,278 Answers
Hello, Jim.
The most common cause is from a particle of ink or dust that is attached to the lamp or the glass covering the lamp. As the page runs over the lamp, it registers that spot as black and causes a line to run the length of the page.
To fix this, simply remove the particle from the glass or lamp. The location of the particle will correspond to the location of the line on the page. So note which side of the page this occurs.
Here's an article from eHow regarding cleaning the scanner glass: http://www.ehow.com/how_14267_clean-scanner.html
Pay attention to that black particle.
Hope this helps.
Posted on Sep 07, 2010
  • 10,515 Answers
Try copying without anything on glass.Do you still see the black line?
Thanks!!
Posted on Sep 08, 2010
5650c not scanned. making paper jam. rollers replaced. making big noise.document page stop halfway through
PDF]fi-5650C Image Scanner Operator's Guide P3PC ... - Fujitsu
www.fujitsu.com/downloads/.../scanners/.../fi-5650c_ops-guide.pd...
FujitsuThank you for purchasing the fi-5650C fi-5650C duplex color scanner product. ... 6.1 Removing jammed documents ..... store where you purchased the scanner or an authorized FUJITSU Image Scanner service provider to make repairs to this .... It is adjusted to the width of the paper in order not to scanned skewed pages. 5.
Okidata User's Guide OKIFAX 5650 Error Messagesmy.okidata.com/man-OF5650.../006B738F6240C3BF8525678500678C...Make sure a new drum is available, and replace the drum ... to be faxed or scanned hasjammed in the scanner. Refer to the "Problem Solving, Clearing aTroubleshooting - Oki Printing Solutions in New Zealandwww.oki.co.nz/support/printer/.../index.aspxOki Electric Industry... MB491 ES4191. FAQ: Paper Jam Clearing MB451 MB471 MB491 ES4191 ...MC361 MC362 MC561 MC562 How to setup scan to email. Open the attached ..... Can I disable Colour Copying and make only B+W Copying available? No, it not possible to disable Color Mode when copying via the Scanner Operator Panel.
Jan 29, 2016 | Office Equipment & Supplies
Fujitsu Fi-6670. I have a little (microscopic) piece of paper stuck under the lower screen, so when scanning it appears a blu line over the whole page. How can i get it out? Thanks
Hello Alex,
You need to open the scanner and de-assemble some parts to remove the piece of paper which involves technical expertise. I would recommend to contact a Fujitsu scanner technician or call your nearest service center for assistance.
Thanks & regards,
ScanCare
Aug 28, 2013 | Fujitsu Fi-6240 Flatbed Scanner
I was just upgraded to Windows 7 and after using it for about 3 days, now my scanner is not being recognized by the system. How do I reload it to recognize on my computer without any disks?
http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/
kindly update the fujitsu scanner driver for your 5110 scanner to windows 7..
Mar 14, 2011 | Fujitsu fi-5110C ScanMaker Scanner
How do I make color scanning the default for my Fujitsu 5110C?
on the comp under printer setting find your printer then right click then go to make default priter go to start first controll panel printer and fax,s
Nov 08, 2010 | Fujitsu fi-5110C ScanMaker Scanner
The fujitsu fi-5110C won't scan all pages just takes the whole thing and just scans the first page. Is there a setting where you can make the scanner to scan each page one at a time? thank you :)
Please follow the information provided below:
If all the pages are being fed through ADF and if image format is TIFF, then you may require another application to view the multi page TIFF image. If you're using ScandAll 21 or ScandAll Pro application for scanning, you have to choose multi page scan option in Batch Scan Setting. Please follow the help contents provided in the scanning application.
Hope the above information is helpful. Please revert if you have any doubt.
Regards,
TechSatya
Jun 29, 2010 | Fujitsu fi-5110C ScanMaker Scanner
Reinstall the scanner
The printer my have corrupt the setup of your scanner. So try and uninstall the setup properly and install it again.
How to unistall go to your control panel-Double click on Add or remove programs-then click on the scanner's setup then click on remove or change.
LATEEF FOR FIXYA
May 14, 2009 | Fujitsu fi-5110C ScanMaker Scanner
Can only scan simplex or duplex
The scanner can scan in either simplex or duplex mode only. If blank page is scanned, then it will appear BLANK, else someone would say, my scanner is not scanning properly! Remove balnk pages using software or sort on file size and delete the small sized files. Take care to ensure they are really blank.
S. Mohan, India
Nov 20, 2008 | Fujitsu fi-5110C ScanMaker Scanner
Scanning a black vertical line down the left side of the document
funny thing. I cleaned it. I had looked before, but didn't see the line on the surface of the glass so i thought it was internal. A closer 2nd look revieled a distinct line on the surface of the glass, probably from pen or marker ink that wasnt dry.
Scanner repaired, pride slightly damaged. thanks for the response
Jul 22, 2008 | Fujitsu ScanPartner fi-5120C Pass-Through...
How to scanning double sided document in fujitsu 5120c scanner
You may want to try using Laser Fiche. This scanning software allows you to select "Duplex" which allows you to scan double sided document
Oct 23, 2007 | Fujitsu fi-5120C
Fujitsu fi-5110C ScanMaker Scanner Logo
322 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Electro Med Services...
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
