Question about Whirlpool ACQ122XK Air Conditioner
I have quiet miser air conditioner that uses a single 15 amp breaker, but the problem is I don`t know weather it`s a 110 or 220.
    President:
  • 1,515 Answers
Hi, if it has a single pole 15 amp breaker. and the end of the cord looks like a regular cord that will fit any 110 receptacle, its a 110 volt unit for sure. No doubt at all, trust me. Good luck and if you have any other questions, just look me up by my user name and I will be here to help you. Don't forget to rate me as I know you will be kind. Good Luck,
Sincerely,
Shastalaker7
A/C, Heating Contractor
Posted on Sep 07, 2010
  • Robert Horton
    Robert Horton Sep 08, 2010
    Hi, just checking in with you to see if you know.
    Shastalaker7
We have a traditional black Hunter ceiling fan. The metal pull broke this morning. I can't turn off the fan or re-attach the pull cord
You can easily fix this. Turn the breaker off that runs the circuit the fan is on. It will likely be a 15 or 20 amp single pole breaker. If you don't know which one it is just turn off breakers until your fan goes off. Look closely at how the fan is assembled and remove the base that the pull mechanism is enclosed in. Them just remove what is left of the pull chain and replace it. They sell the pull chains at Home Depot or Lowes.
Hope this helps.
Sep 13, 2011 | Hunter Heating & Cooling
I am going to install a 3 phase 100 amp circuit breaker panel board to provide service to 9-10 individual air conditioning units. how do i wire these services?
you dont need 3 phase you need a 220v or 110v single phase supply these units usually take about 10 to 15 amps each if this is central units then you can use 3 phase but not nescessary
Sep 07, 2011 | Heating & Cooling
I need to replace a 15/15/15/15 Bryant Quad breaker. It is very difficult to find these for sale. Can a quad be replaced with two twins or four single pole breakers?
The reason for using the quad, is so that if any one of them trips, they all trip. GE used to sell lever covers that would join the levers together. I don't know if they still do. And I don't know if the Bryant breaker is JUST 4 single poles with their levers connected together.
Aug 13, 2011 | Bryant Westinghouse Bqc Quad Circuit...
Wiring 15 amp 250v single outlet for wall ac unit use 12 AWG? blk hot; white taped red to other hot; bare grd to grd teminal?
You are using a 15 amp double pole breaker? If you are the two wires going into the breaker are you line voltage wires. A third conductor usually ground/bare would go to ground terminal. If you have 4 wires and the other one is white, that should be tied into the neutral ground bus back in the panel and is probably wired into the outlet as well. Buy a new outlet and you cannot go wrong.
Jun 26, 2010 | Heating & Cooling
Heat/AC unit in working order, plugged in 20Amp outlet.. no fan?
Hi1
Do you have at least 200 volts at your outlet? Check that first. You said you brought it home from work, so when you plugged it in at home did you plug it into a 120 volt recepticle?
Jan 01, 2010 | Emerson Quiet Kool 12NW46HK Air...
Stop button does not work on amanda quiet zone room air conditioner
hi there,
if the stop button doesn't work,it continously run you can shut off circuit breaker for emergency shuting off.if this a proramable a/c unplug your a/c and put it back wait for 15 minutes .and try to run if still doesn't work your holding relay is shorted from control panel,try to call a service technician to check the actual control panel defective.have a nice day,don;t forget to rate me,thank's a lot.
May 26, 2009 | Amana Quiet Zone 12M12TA Air Conditioner
GFI on cord trips out.
Probable cause is a single pole gfi opposed to a double pole gfi.
* Do not use a single pole GFCI ON A MULTI WIRE CIRCUIT, IT WILL NUISANCE TRIP IMMEDIATELY
Use a two pole GFCI circuit breaker on such circuits.
May 20, 2009 | LG LWHD1800R Wall/Window Air Conditioner
Amps needed to run a central air unit
Central air requires a 2 pole 30 amp breaker or fuse. You may be able to get by without it but 200 amp service is recommended.
Jan 31, 2009 | Weather King 12AJA4801AH Air Conditioner
Whirlpool ACQ122XK Air Conditioner Logo
121 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
