Question about Kenmore Heating & Cooling
I have a Kenmore dehumidifier (model 580.54351800). It runs for a few minutes then shuts off. The only way to turn it back on is to remove and re-insert the water bucket. then it runs for a few more minutes and shuts off again
SOURCE: runs for a couple of minutes and then stops
Try cleaning out the air filter using cold water. I did not even know the unit had one until I had the same problem. Pull out the bucket. The filter is located where the front top edge of the bucket would be located if it were in the instrument. Remove it by pulling straight down. It may be taped to the instrument for shipping purposes. According to the manual, this should be done every month. I have had the machine since Katrina and this is the first time I have had a problem. Hope this helps.
Posted on Aug 19, 2007
  • 184 Answers
SOURCE: dehumidifier
IS THE ROOM HUMIDITY LOW. IF IT IS BELOW 30% THE HUMIDISTAT WILL SHUT DOWN THE UNIT. THE AMMBIENT TEMP SHOULD BE ABOVE 65 DEGREES AND THE HUMIDITY SHOULD BE ABOVE 50 %.
Posted on Apr 05, 2008
  • 185 Answers
SOURCE: i have a dehumidifier that
check your coils and your fan
Posted on Apr 08, 2008
22yooper
  • 828 Answers
SOURCE: I have a Whirlpool dehumidifier,
The refrigerating system has lost it charge.
Posted on Jun 15, 2008
SOURCE: LG dehumidifier
I Have an LG Dehumidifier and water has leaked out to the basement floor, it has a hose that drains into the floor
Posted on Oct 05, 2008
How to repair my kenmore 58054501500
ck the water catch bucket , sometimes ive seen machines stop after running a few minutes because it shook catch bucket from its perch
Jul 16, 2014 | Kenmore Dehumidifiers
My dehumidifier kenmore model 580.52650 is working fine but turn off and turn back on every three minutes it is this dangerous, any solutions ? THANKS.
I think the problem may be caused by the humidity extraction level you have the unit set on. (i.e. It's set to high). Lower the humidity extraction level to 35%. This will allow the unit to run longer and extract more humidity, before it either shuts off, because the humidity level has been reached or the bucket is full and needs to be emptied.
Don't forget, the air intake filter should be cleaned regularly.
Hope this helped you. Please let me know.
Jul 08, 2011 | Kenmore 54501 Dehumidifier
My dehumidifier will turn on but after a few minutes it shuts off on it's own.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Apr 26, 2011 | Whirlpool AD70USS Dehumidifier
My dehumidifier shuts off within a few minutes of turning on. There is humidity in the air but it is not collecting any water in the bucket. I feel air being sucked in the front and blown out the back. I...
heatman101
Apr 21, 2011 | Kenmore 54501 Dehumidifier
Dehumidifier runs for approx. 15 min works fine then shuts off and doesn't come back on.
run it without the filter with a 1 part vinegar 4 parts water. then try it with a clean or new filter. You may need to run it a few (5-6) times before it stops shutting off by its self.
Aug 22, 2010 | Kenmore 54351 Dehumidifier
Dehumidifier not collecting moisture
Normal 0 When you push the power button, the blower fan comes on. In a few minutes you should hear a second "click"--that is your compressor starting. Do you hear that second click?
Jan 31, 2009 | Kenmore 54501 Dehumidifier
Dehumidifier
Mar 26, 2008 | Kenmore 53301 Dehumidifier
Constant on-off cycle
If the unit is freezing up I suggest replacing the sensor assembly. Just replaced mine because the thermistor that is on the suction line went bad and would not send the reversing valve into defrost.
Oct 09, 2007 | Kenmore 54701 Dehumidifier
Heating & Cooling Logo
89 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
