How do I clear the memory on a Canon H12425 fax machine...?
3 Suggested Answers
SOURCE: Canon MP530 - Fax Memory is Full... How do I clear?
Check your ink cartridges and fill any that may be low. I got that error because one of the cartridges (magenta) needed to be refilled. The printer was storing failure reports in its memory until they could be printed out, leaving no room to fax new documents. As soon as the ink cartridge was replaced, the reports printed and freed up the memory to send out faxes.
Posted on Aug 15, 2008
shishirgarde
  • 114 Answers
SOURCE: On my Canon MX310, the display says
Try this step ... found it on Canon's website
Issue: ERROR LCD: WAITING FOR REPORT
Solution: Set [AUTO PRINT RX] to ON (MX300 / MX310)
AUTO PRINT RX When [AUTO PRINT RX] is set to [OFF], incoming received faxes will be temporarily stored to memory and transaction reports (TX, RX and Activity) remain in memory. The default setting is [ON], which means incoming received faxes and transaction reports will automatically print. The fax machine will not automatically print a received fax and will store it in memory in the following conditions.
  • Ink is low or has run out
  • The paper size and type is not set correctly
  • Paper has run out
  • The Output Tray is closed
To set AUTO PRINT to ON, please follow these steps.
  1. Press the <FAX> button to enter the Fax menu.
  2. Press the <Menu> button. [FAX SETTINGS] is displayed
  3. Press the left or right arrow button to select [RX SETTINGS] , then press <OK> two times.
  4. Press the left arrow to select [ON], then press <OK>.
    Note: When AUTO PRINT RX is set ON, a sub-menu will appear to PRINT WHEN NO INK.
  5. At sub-menu PRINT WHEN NO INK, decide if you'd like the machine to continue to print incoming received faxes if ink is low.
    CAUTION: When this option is set ON, the fax machine will not monitor the ink level of the ink cartridges. If ink is low or out, received faxes will print with streaks or blank. Furthermore, once the fax is printed, it will be deleted from memory.
    1. To print received faxes when ink is low or out, press the left or right arrow to select [ON] and then press <OK>.
    2. To store received faxes in memory when ink is low or out, press the left or right arrow to select [OFF] and then press <OK>.
  6. Press the <Stop/Reset> repeatedly to return to Fax standby mode.
Posted on Nov 17, 2009
H12425 model
ricoh sp1200s drum error tarbulsuteng
Jun 26, 2013 | Office Equipment & Supplies
How do I clear the memory in my Canon CFX-L4000 Plain Paper Laser Fax
Hi function + memory reference (04) + set + star (astrix /*) keep repeating till display reads memory clear.
Oct 14, 2011 | Canon CFX-L4000 Plain Paper Laser Fax
Memory Full Canon i-sensys Fax L120
try this
press "menu" and then "#" button, go to service mode. Select the "clear data function". and select "memory clear"
Sep 03, 2009 | Canon i-SENSYS FAX-L120 Plain Paper Laser...
Canon H12425 that paper catches on when trying to fax
the gear inside the machine is bit moved you should adjust the gear to make it proper...
Apr 21, 2009 | Computers & Internet
Says "memory is full" How do we clear memory?
MEMORY IS FULL, NEED TO BE RESET.
FAX INBOX IS FULL
SEE IF THERE A WAY TO DO IT THREW THE CONTROL PANAL ON THE COPIER IF NOT THAT IT WILL A FILE IN THE ONLINE PORTION OF YOUR INTNET PROVIDER.
ROD
OR
ONLINE
CANON LC8500 MEMORY IS FULL
OR
CANON LC8500 HELP CLEAR MEMORY
OR
CANON LC8500 RESET SWITCH
OR
CANON LC8500 SERVERCE MANUAL AND DRIVERS
ROD
Feb 09, 2009 | Canon LaserClass LC 8500 Plain Paper Fax
HOW DO I RESET MY CANON FAX JX200 TO FACTORY DEFAULT
hold menu and #
press down to select clear
press Start/Copy
Trojan :)
May 10, 2008 | Canon FAX-JX200
259 people viewed this question
jasbo
jasbo
