Question about Proview Televison & Video
How can I get closed captions on my Proview TV. I use the remote that came with the TV for on/off and volume, using the cable remote for everything else. Now that my hearing has become very limited, I am sure closed cations will help me continue to watch TV. Using the "cc" button on the Proview remote produces nothing. Thanks.
  • 11,896 Answers
Do you have a menu or settings button on the remote? If not, go up to the tv itself, press the up and down volume arrows at the same time, some tv's you have to press the up and down channel buttons at the same time. Then you should enter a menu. On the menu, there should be settings for CC. Otherwise try a universal remote and control everything with that remove. Most have working cc on them.
Posted on Sep 07, 2010
How to turn off closed captioning without original remote
You must have its remote control to close the closed captioning function.
Dec 24, 2012 | Memorex MT2274 27" TV
Sharp Aquos LCD TV 52"
Does your cable company support CC?
Apr 08, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
How do i add channels on my tv
The closed caption just suddenly appeared on my screen with no buttons pressed. It won't turn off. I no longer have the original remote for this Durabrand 13" DU1301 TV . I was using the Time Warner Cable remote and have a basic cable box attached to the TV. Everything was fine until suddenly with no buttons pushed the closed caption came on. Is there anything sort of buying a new tv to fix this
Sep 11, 2011 | Durabrand DU1301 TV
I have an Orion 19"
You usually need the original remote. The trouble with universal remotes is that they generally control only the basic functions of a TV (power, volume, channel) but not much else. Without the original, you often lose other functions. You can try the front panel buttons if yours has them. On some sets the on-screen menus allow you to access caption settings.
But are you sure the captions are coming from the TV? Sure, the TV is displaying them, but if you have a satellite receiver, cable box or digital set-top box, the captions may be coming from that device. This is likely to be true if the captions just mysteriously started and you don't have or aren't using the TV original remote. These devices often don't allow a TV's built-in caption decoder to work properly, so they provide captions themselves. You may have turned captions on using that device's remote. Check the menu for caption controls.
Jul 10, 2011 | Orion1934 19" TV
Thank you for the help,for my insignia tv,ns-lcd32-09ca,to find the close caption,but beside that i have no manual,i also have no remote,i use the one for all remote and that works ,i still don't know how...
You can use the TV buttons to get access to close caption by pressing menu, volume up or down to select setup when you get to setup press channel down to close caption and use volume up or down to turn it on.
Let me know if you need further assistance.
Jun 13, 2010 | Televison & Video
I have problem with our Magnavox TR2510C101. My toddler press everything and now it turns out there is black screen (square) cover the image. Do you know how to fix it? thanks!
You have accidentally gotten the Closed Caption turned on....
Here is how to turn it off....
1) Press the MENU button either on the front of the TV or on the original TV remote.
2) Use the Volume + or Volume - to highlight "SET"
3) Use Channel - or Channel + to highlight "CLOSED CAPTION"
4) Press Volume + to access the CLOSED CAPTION menu.
5) Press Channel - or Channel + until OFF is highlighted.
6) Press Volume + or Volume - to confirm selection.
7) Press the TV/AV/EXIT button on the remote to exit or the MENU button on the front of the TV.
GOOD LUCK and please rate this solution...
Jan 14, 2010 | Philips Magnavox 27MS343S 27" TV
Can't get closed caption off of television
If you have the original remote use the closed caption button to turn it off. Without the remote, hold down both volume buttons on the front of the tv to bring up the menu. Use the the channel and volume buttons to navigate in the menu. Select the center icon at the top of the screen. Go down to closed caption. Select OFF. Wait for menu to go away.
Mar 05, 2009 | Sansui DTV3200 32" TV
No remote to turn off Closed Captioning
if your tv has a menu button on it enter and try ot turn it off via thr front control buttons
Apr 07, 2008 | Philips Magnavox Learning Universal Remote
Captioning
Try getting into the tv menus with the menu button on the remote or the menu button on the tv. Find closed caption or CC and turn it off in the menus.
Nov 02, 2007 | RCA Universal Remote 3 Device Remote...
Closed Captioned
Assuming whatever your TV receiving from has close caption. (Not all TV channel has close caption) Solution 1) Get a new universal remote that support your model and has close caption button. Once you program in the code for your TV model and it works then all button should also programmed including th close caption button. Solution 2) Search online for the owner manual and read see how to turn it on using buttons on TV (if possible). Solution 3) Get new TV with close caption. (If you have an old old TV with bad and huge pixels then this solution is the best. Your eyes will thank you.)
Aug 25, 2006 | Panasonic CT-32G11 32" TV
Televison & Video Logo
76 people viewed this question
Top Proview Televison & Video Experts
Steven Wander
Steven Wander
Tony
joncin91
Level 1 Expert
Are you a Proview Televison and Video Expert? Answer questions, earn points and help others
