Question about Samsung MW1030WA Microwave Oven
How do I take the door apart on a Samsung SMH7187 microwave?
  • 5,911 Answers
To disassemble the door on MOST microwave ovens, all you have to do is remove the inner door panel that goes around the perimeter of the glass. The panel is pressed in place and can be removed by using a small screwdriver or putty knife and carefully insert along the seam of the inner panel to release the clips that hold it in place so you can pry the plastic up. Work your way slowly around the perimeter of the glass to pop the panel loose. Use care not to pry against the glass. The glass is tempered and also has an RF shield that shields you from harmful RF radiation.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. On some microwave ovens, you may have to remove the upper grill cover over the door (if equipped) to accommodate door removal. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
NOTE: Some doors have a hinge pin that needs to be removed, or screws holding the door in place at the hinge.
There are several parts sources available that you can use to purchase replacement parts (if required):
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites on the list also offer helpful exploded view parts listings to aid in parts identification and location. Just type in your model number and locate the parts listing for the door. If you have any questions, or require additional assistance, please let me know. I hope this advice is helpful.
NOTE: If your model number does not appear on all the websites, use the PART NUMBERS from the Sears website as your search criteria. In many cases the model number may not reference to all websites, but the part numbers WILL.
Posted on Sep 07, 2010
Testimonial: "Great write up and worked like a charm. I got the parts from partstore.com, fast shipment. Apparently Samsung MW's are prone to the endcaps breaking."
The door latch broke
Slightly different model, but this will help you fix it.
https://m.youtube.com/watch?v=JqeeGBhRwFw
Feb 06, 2016 | Samsung SMH2117S
I took my microwave apart to fix the broke spring in the door & put everything back exactly the way it was &it wo nt do anything ??????
Bad luck. Are you sure you mounted everything everythinh exactly the way it was? No pieces missing or left over?
Best procedure is to that a photo of each step.
My adivec: Do it agaim carefulley. I no luck, look for a repair service
Maybe you can fine a video tutorial for your Microvwve in youtube?
Something like this
Broken microwave door
Samsung Microwave Door Latch Spring Repair when your door won latch closed
Over The Range Microwave Oven Door Repair Help
Repair Replace bad Door Switch Mechanisms on Whirlpool Microwave
and there are come more
Oct 28, 2015 | In Microwave Ovens
Why samsung smh9187w door will not latch
Had the same problem on my Samsung SMH9187. The two latches are cheap plastic. After watching a video on U tube on how to get the door apart, I fixed it with a paper clip and ordered the parts online (two years later I still have the paper clip holding the plastic latch in place). Look for the SE error to happen next, its not made very good.
Jul 02, 2014 | Samsung SMH9187 Microwave Oven
Samsung smh9187w microwave oven door will not close
The hinge latch hooks are flimsy on many of these but almost any shop can repair this issue--unit has to be taken apart.
Aug 29, 2012 | Samsung SMH9187 Microwave Oven
Samsung microwave door won't latch
You will need a Samsung dealer repairman, the inner mechanism will need to be serviced because for some reason it is jammed or there are broken parts.
Apr 08, 2012 | Microwave Ovens
My Samsung SMH7187 Microwave oven display reads "SE". How do I fix it?
"SE" means you have a shorted membrane keypad.
Actually the best overall solution to this problem is usually to order a new controller assembly (control box) and install it yourself. It's pretty simple.
We have a similar service manual and have uploaded it to our site here to help you.
Your part numbers may be different, so you can find helpful exploded views by entering your actual full model number at the Sears Parts Direct Web site here.
At our Web site , we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Some connectors on the relays may have a lock:
We're happy to give you with help and appreciate your thoughtful rating of our answer.
Jan 03, 2011 | Samsung SMH7178STD Microwave Oven
How do I get the door apart on a Samsung SMH7187 microwave?
We have the service manual for model SMH7178, and maybe it will be enough help.
http://www.microwavedisplay.com/smh7178_std_ste_sm.pdf
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screw(s) you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
In some cases, you then have to gently rotate the handle to unlock it.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Sep 07, 2010 | Samsung MW1030WA Microwave Oven
Hi, I have a mh1150 whirlpool microwave. One
door doesnt typicaly come apart, door should be replaced. it is a barrier for harmful waves.
Oct 30, 2009 | Whirlpool MH1150XMQ Microwave Oven
I have a samsung smh7187 microwave over the range and in the middle of cooking it just shut off. The vent at the top of the unit is still open. The outlet is fine, other things work fine in it-I unpugged...
I would suspect the oven cavity's thermal cutout / thermostat, the magnetron's thermal cutout / thermostat, and/or the fuse.
We have the service manual and have uploaded it to our site here to help you.
Note that your model number's suffix may be different than this manual covers exactly.
Oct 04, 2009 | Samsung SMH7178STD Microwave Oven
Samsung MW1030WA Microwave Oven Logo
371 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
