Question about Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket AM2+ 3000 MHz Motherboard Retail
GA-MA790FX-DQ6 Mobo not POSTing Should i reset the bios??
The motherboard doesn't power up to POST screen!! It's a new
pc. When i turn on the power, cpu is working and
everythingelse but Post screen doesn't comes up. Nothing
comes up on my monitor. I took out the ram and there is no
beep sound from the motherboard! Do i have to reset the
Bios? I also want to know if this graphics card(Visiontek
Radeon HD 3870 X2 Overclocked Edition)compatible with this
GA-MA790FX-DQ6! Also on the mobo's Chassis intrusion header
doesn't have a cap on? Does it suppose to have a cap on? Is
it the 4Gb ram(New Corsair Dominator 4GB (2GBx2) DDR2 1066
with Fan
) that i have cause the motherboard not POSTing? Does the
all the fan headers(cpu_fan,sys_fan1,sys_fan2,power_fan)
have to be plugged in?
Well I thought it was problem with graphic card so i tried
it with another card which is Radeon HD3650 512MB DDR2.
Doesn't work either! Nothing comes up on my monitor not even
Power-On Self-Test (POST) There isn't any beep sound either!
Need help please!
  • Jay1f May 15, 2008
    Well i took out all the wires and just cpu and the internal
    speakers then plug in the 8pin ATX and 24pin from psu. Power
    it on then wait for the beep sound but No!! Also i did reset
    the bios but nothing happened. So i figured something is
    wrong either with the cpu or mobo. I went out to get another
    mobo and do that again but no beep sound! It just not going
    to POST screen with two mobo. It probably might be a
    defective cpu!! So i'm gonna sent back the cpu and get a new
    one! :(
You procesor is not suported by the motherboard with the curent bios.you need to do a bios upgrade to f4or f5 bios before your phenom will work.
Posted on Aug 13, 2008
  • 655 Answers
No beeps, indicates you have faulty CPU or mainboard.
  • remove all components even RAM and CPU.
  • insert only CPU and Speaker (without RAM or any other componet).
  • Boot and try to hear, there must be long beep for missing RAM, if not then try to re-insert the CPU or change the CPU/Mainboard.
Thanks and Good Luck
Iqbal
Posted on May 14, 2008
2 Suggested Answers
map9966
  • 2351 Answers
SOURCE: Motherboard is not booting!!!!!
Hi Jay,
Is you're memory installed in the two yellow slots?
Try using only 1 DIMM in DDRII_1 slot.
Page 17 in you're manual. When using only one PCI-E graphics cards you do not need to plug in extra power to the board, as shown on page 19. (Only need this additional 4-pin Molex when running two PCI-E cards).
Check internal connector is plugged in item,
1 ATX_12V_2X (Pg. 23 in you're manual).
(System will not boot without this).
Also item, 2 main power 24-pin Molex cable is securely connected. Chassis Intrusion Header (By default is opened/no jumper). I don't like the CPU getting hot. It shouldn't. Do you have a spare heat sink & fan for you're CPU? Are you 100% the cooling system is running correctly?
Lastly, here is Gigabyte's Qualified Vendors List (QVL), for you're board. Corsair 2GB is not listed.
http://www.gigabyte.com.tw/FileList/MemorySupport/motherboard_memory_ga-ma790fx-dq6.pdf
Luck!
Mike
Posted on May 15, 2008
Do I plug in BOTH the 20+4 ATX power connector AND the 8 pin 12V connector on a gigbyte MB (MA790GPT-UD3h)?
Hi
You only need to plug the 20+4 ATX power connector and how about the 8 pin 12V connector? Well that is use only for legacy type of motherboard that use to require it.
Hope it helps..
Thanks for reaching Fixya
Apr 03, 2010 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Gigabyte MB no boot ga-ma790fx-dq6
did you replace the battery on the mainboard if its weak it will not beep
Aug 04, 2009 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Motherboard GA-MA790FX-DQ6 no monitor
your power supply is too weak to power your video card.
Mar 07, 2009 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Motherboard not booting
i think memory probelm
please change memory and try it
Jul 22, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Windows Vista
If you are having trouble installing the drivers from the Gigabyte CD, than go to Gigabyte's web site for the GA-M61SME-S2 motherboard & download the Vista driver's you need. The web site has some newer drivers. Click on this link to go to the driver site.
http://tw.giga-byte.com/Support/Motherboard/Driver_Model.aspx?ProductID=2507
If you are still having trouble. List what is not installing here.
Same for error messages.
Mike
Jun 26, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Gigabyte GA-MA790FX-DQ6 installation problems
Hi speedfreak44, during the installation of windows one of the drivers did not install correctly & windows registry is messed up.
The blue screen is a typical response from windows. Even though you're windows installed SP2, there are another 89+ updates for SP2. (A reinstall with-out a format is not advised).
Suggest you enter you're bios & disable ACPI. This one I know for sure will show up in windows device manager as a PCI device with no name. Try again to boot windows. If it still fails to enter in standard mode than a complete re-install will be required including a format. Personally I do not use windows XP pro/home w/SP2 CD to perform the format, (After receiving a blue screen).
I have found it is 98% better to use the software tools, downloaded from the Mfg's web site for you're hard drive. Use the bootable software (On a floppy or CD), to format you're hard drive. Most Mfg's hard drive software will allow you to change the cluster size up. Windows standard uses a 4kb cluster size & you loose far more hard drive space. With a 16kb you loose only the file allocation or FAT, which is normal.
Than using the Win XP CD/SP2 install windows, clean.
(No need to format).
When finished installing windows, load the Gigabyte driver CD & install the chipset & other CD drivers. Turn on windows firewall & update windows SP2. (ASAP), (Save SP3 update for later).
It is in the updates of windows to iron out software & hardware driver updates. Do not install you're antivirus software until windows has finished updating its self & you install any hardware updates also through windows update. (Continue to leave the ACPI disabled in bios until updating is complete).
You can enable ACPI, antivirus software & printer software all.
You will find some needed software will install during windows update. Like; Quad Core processor update. With either home edition or pro it is advised to install .Net framework updates 1 at a time & only restart when prompted by windows. Other wise click the refresh button & continue windows updating. (You can save the .Net framework updates for last if you wish). You're video card may need .Net framework 2.0 or better for installation.
I am hell bent on installing windows once & correctly the first time. I understand you want to get this baby up & running but take the time & run the hard drive tools/utilities. (It's worth it)!
Good Luck speedfreak44!
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Please let me know if this got you're system running without the blue screens?
One last item. It's also worth checking the dates on the Gigabyte CD to Gigabyte's web site before installing other drivers. Including the chipset drivers. You want to install the newest drivers the first time around. Here is the link to you're Gigabyte GA-MA790FX-DQ6 motherboard main web site.
(Click on the link).
http://www.giga-byte.com/Support/Motherboard/Manual_Model.aspx?ProductID=2690
Mike
May 27, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Hi Jay,
Luck!
Mike
May 14, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Troubleshooting
What is the brand name of the ram you are using? If you look up on AMD's website, it will tell you what RAM is compatable with your processor and mobo. 45 degrees celcius translates to 113 farenheit. If it is a constant temp that way, it is ok. But just at IDLE speed, means the processor is getting over heated more than likely after opening multiple apps.
Mar 17, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Troubleshooting
How long have you had the system in that configuration? It doesn't seem to be a heat issue running around 45 degrees unless that is the idle temp. I need you to try something, when it shuts down, immediately restart the system in bios and look at the temp for the processor again. I solved my issue by taking a side off of my case and putting a small desk fan blowing directly into it. My idle temp went from 45 down to 27 degrees celcius. In a perfect world, the cooler a CPU runs, the better the system will respond. Find those temps readings for me, and let me know. Also, there may be a small monotoring program in your mobo set up disc to help monitor the temp while windows is running. And also, double check to make sure your processor fan is plugged into the correct spot on the mobo, mine is mislabeled, another issue I had found and corrected.
Trobleshooting
I had the same issue with my AMD Athlon 3800+ dual core. I found that I wasn't getting enough airflow to keep the system and processor cool. You may want to check the heatsink and fan rating for your processor unless it was sold in a bundle. Also, On AMD's of such power, they tend to run hot if overclocked. Look into, if you haven't already 2 case fans to go along with the processor fans. I recommend a 90mm in front and a 80mm in the rear of the case. If this doesn't help, let me know.
Mar 16, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket AM2+ 3000 MHz Motherboard Retail Logo
353 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
