Question about Dell Inspiron 1501 Notebook
Dell 1501 won't turn on no power - Dell Inspiron 1501 Notebook
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 132 Answers
Try to take the battery out and turn on with the adaptor alone...
If it works then its a problem with the battery...
Try to turn with the battery alone.. Or try to get a similar battery or adaptor from friends and try.... If everything is not working it could be a faulty motherboard... If u are in warranty call Dell @18006249896.. Out of warranty then contact a local tech....
Posted on Sep 12, 2010
Dell inspiron 1520 won't turn on.
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
Oct 08, 2012 | Dell Inspiron 1420 1501 1520 1521 1525...
Power up laptop dell 1501 ,stays on until you logg on then after log on and programs load all power is lost
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Feb 15, 2012 | Dell Inspiron 1501 Laptop
Dell Inspiron 1501 Power Button won't turn on ....
I would remove the hinge / power button cover again and make sure the little pip that presses the button down it not broken, also check the little circuit board with the switch on to make sure it's not disconnected.
Try switching on with the cover removed.
Feb 02, 2012 | Dell Inspiron 1501 Laptop
Dell Inspiron 1501 won't turn on. When charger is plugged in the green light turns off once it's plugged into the laptop
Power supply problem or power supply connector problem. I can take a look at it for you if you want.
Jan 04, 2010 | Dell Inspiron 1501 Notebook
My 1501 Dell Inspiron wont turn on. The charger
The ac power jack needs to be either resoldered or replaced.
Dec 09, 2009 | Dell Inspiron 1501 Notebook
MY INSPIRON 1501 LAPTOP WONT TURN ON. ITS STARTS
Please follow these instruction to predict the possible errors,
Upon powering on the laptop, press and release many time the F8 button of your laptop until this window appear... Select the highligted in yellow... Post the error codes you can see on your screen for the next troubleshooting tip...
Oct 21, 2009 | Dell Inspiron 1501 Notebook
DELL 1501 INSPIRON THAT SHUT DOWN AND WANT POWER UP
Short or broken lil jack on the mother board. Needs a professional to look at it.
Oct 11, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501, replaced battery and power cord
Power on the laptop without the battery in the unit. If it powers on, then place the battery in and it will start to charge. Sometime the Dell laptop will not see the battery when it is replaced.
Mar 23, 2009 | Dell InspironTM 1501 Notebook
Dell inspiron 1501 work fine turn off last night now wont turn on
You mentioned trying a different battery, try a different AC adapter.
When plugging in the ac adapter to the wall, see if the POWER LED comes on on the adapter, then when you connect it to the computer, see if the LED stays on.
If the issue occurs with both AC adapters (No battery installed) then the motherboard has failed. If one ac adapter works but the other doesn't then the adapter is bad
Feb 01, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 Notebook Logo
89 people viewed this question
Alun Cox
