Question about Puzzle Massey Ferguson Tractor
My tractor made a pop sound and quit moving. it still runs but, just won't move
Ariens ezr 1540
Check your drive belt above blade belt
Dec 21, 2013 | Garden
HUSKEE SHIFT ON THE GO LAWN MOWER WONT MOVE
Sounds like a pulley key is missing. That will cause the pulley to spin on the shaft without the shaft turning.
Jun 19, 2013 | Garden
Mower starts and runs but won't move forward or reverse and brakes don't work.
If your transmission is automatic on the drive axle, look for a small lever inside the frame and below the seat. It can be hard to find the first time. This lever disengages the drive inside the auto gearbox so the mower can be pushed by hand. If the lever is not not moved, pushing the mower also tries to turn over the engine making it impossible to move. With the lever moved accidentally the drive is disengaged and the mower won't move in either direction. The lever operates a flexible cable that comes out from the auto transmission.
Dec 12, 2012 | Craftsman 24 Hp 48" Deck Yard Tractor
Poulan Pro riding mower won't turn right. I can
there is a plastic connector that holds the steering shaft down into the drive gear the plastic cracks and wears out then the gear jumps passed the teeth its about a $15 part
Jun 14, 2012 | Garden
I Have craftsman 20hp variation speed 42
sound like the carb needs a good cleaning
Apr 06, 2012 | Garden
I have a John Deere RX 75 that worked perfectly fine. I just did maintenance by greasing some fittings and I sprayed WD-40 on some of the moving parts under the seat (throttle, levers, etc.). After I...
If it's a hydrostatic, most likey you pulled the manual over-ride (only way to move the tractor manually). By leaving the over-ride level in the disengaged position, the tractor will start & run, but not move forwards or backwards. Correct by closing the the lever to it's closed (operational) position.
Oct 18, 2011 | John Deere Garden
Model LT2000 hydrostatic drive wont move in either direction drive belt started smoking than quit now tractor wont move in either direction
If the main drive belt, from the engine to the rear end of the tractor broke, you won't move, nor will you hear a whining or grinding noise!
An easy check- inspect if each rear wheel has a key installed between it and the axle shaft. One pops out- it won't drive.The key is a square piece of hardened steel that is inserted into the axle, then the wheel hub is slipped over it and the axle, then the necessary fastener is installed to keep the wheel on. This could be either a bolt, or a spring clip. And, if the transmission has failed, you may or may not hear any whining or grinding noises!
My guess it the drive belt is toast as you said it was smoking, look at it and the order a new one. Here is a site you may be able to download a manual, Tim:
http://www.searspartsdirect.com
May 23, 2011 | Garden
Won't move
check drive belt and tension pulleys under machine if belt is stretched or damaged replace if popped off pulley check all to make sure one has not froze causing it to pop off also check rear pulley on axle sometimes pops off and just spins
May 15, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Puzzle Massey Ferguson Tractor Logo
42 people viewed this question
Top Puzzle Toys Experts
Gary Nitowski
Lesley Cameron
Lesley Cameron
Are you a Puzzle Toy Expert? Answer questions, earn points and help others
