Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool super capacity Lsq9549lw0 has trouble spinning on its own.
Washer does fine until the spin cycle . it will pump all the water out but wont spin unless i lay the hose on the ground letting the rest of the water in the hose run out.
  • krystlel Apr 11, 2009
    My washer will agaitate rinse drain the water but won't spin.
  • Anonymous Mar 17, 2014
    whirlpool washer super capacity plus was in spin cycle and the load went un balanced i stopped the cycle by pushing the cycle switch off but the machine wont work any cycle
  • 3 Answers
If the washer does fine thru the agitation cycle (the washing), that means the motor is OK and the coupler is OK.  It would not agitate unless both are OK.  (and don't listen if anyone tells you the lid switch is bad -- machine would not fill & go thru wash cyle). The spin is another matter.  There is a separate tube for spinning the basket.  There is a drive  block at top of the tube (that sometimes fails)  and there is a separate cluch mechanism below, under the tub.  Those places is where you should look.
Posted on Jul 10, 2008
  • JurisB Jul 13, 2008
    I,ve been at the same problem for the very exact Whirlpool model for the past week.  So, in addition to what I said above, it is also possible that the brake has locked & won't let the basket spin and finally it could be the gearcase.  There's a separate gear inside the gearcase that spins the clutch assembly to drive the spin tube that goes up to the basket.  If that gear is gone in the gearcase, the washer will do everything, except spin. (That turned out to be my $150 problem.
    If you are willing to spend the effort to take the top off and remove the cabinet, you can check if the clutch spins (or tries to spin) at the start of either spin cycle, here's a good procedure:
      http://www.applianceaid.com/direct-nospi...
Ok fellas it was the clutch
Posted on Jul 26, 2008
  • 868 Answers
Motor coupler is failng or the motor is on its way out.
Posted on May 23, 2008
Maytag Whirlpool Super Capacity Ultimate Care Washer, it goes through all the cycles except the spin cycle. Will not spin.
Most likely the lid switch or the motor coupler. Is it just doing nothing when time to drain and spin leaving it full of water? If so, replace lid switch. If it's pumping water out and you hear motor running, but it's not spinning, then motor coupler is most likely broken. In second scenario, also could be clutch or other transmission problem.
Oct 31, 2017 | Whirlpool Washing Machines
Whirlpool super capacity commercial washing machine
Sounde like a bad lid switch . With no model number , can't help you further .
Sep 06, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
Whirlpool washer; spin cycle not draining
It sounds like your water pump is broken. there is a motor inside that pumps the water out when the machine computer changes to spin cycle
Aug 06, 2009 | Whirlpool 4.0 Cu. Ft. Plus Washer
Kenmore 3.5 super capacity. will not go to spin
if the drive coupler is broken it won't wash or spin. Does it have a removable lower access panel on the front? if so its an amana. see if u can manually turn the transmission pully both directions. AND make sure there is nothing holding the tub ie nail through tub whole garment between tubs etc.
Jun 11, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool super capacity washer spin cycle stop working
Sounds like you need a new lid switch. Click HERE for prices.
Apr 19, 2009 | Maytag HAV2558 Top Load Washer
Whirlpool LSQ9549lW0
sounds like something is stuck in the water pump. look under the machine and you will see the water pump front and center of machine.
Jul 14, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
829 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
