Question about Samsung AS18A6RB Air Conditioner
I have a Samsung AQV12JA. Fault code (Gas leak) have replace the outdoor and indoor thermistor per tech line. They said replace outdoor computer board. Board was back ordered for over a month, this is a brand new unit so they sent a brand new outdoor unit. Installed it and get the same error code, any ideas?
  • 1 more comment
  • rsyunker Sep 08, 2010
    The unit does not have a leak the pressures are fine.
    I have the service manual and there isn't any gas leak
  • rsyunker Sep 09, 2010
    We have vacuumed the unit properly and weighed in the correct charge.
    Guru:
  • Samsung Master
  • 468 Answers
As per the error code there should be gas leak from the Air Conditioner. Please visit the link below for a complete service manual with diagrams for more details, I hope it should help:
http://tinyurl.com/23ufvr2
Thanks and regards,
Anil.B.R
Posted on Sep 08, 2010
  • Samsung Master
  • 43,501 Answers
I guess that I would be wondering if you are vacuuming and charging the unit correctly....it would seem that maybe the unit has an incorrect charge...
have you vacuumed the entire unit and carefully weighed in the charge???
heatman101
  • 2,272 Answers
Gas leak is due to loose valve or cracked gas pipe.Check out both.Also reconnect the settings as follows:-- Connect each assembly pipe to the appropriate valve on the outdoor unit and tighten the flare nut. Connect the charging hose of low pressure side of manifold gauge to the packed valve having a service port. Open the valve of the low pressure side of manifold gauge counter-clockwise. Purge the air from the system using vacuum pump for about 20 minutes. – Make sure that pressure gauge show -14.5psi(-0.1MPa, -76cmHg) after about 20 minutes. – This procedure is very important in order to avoid gas leak. – Turn off the vacuum pump. – Close the valve of the low pressure side of manifold gauge clockwise. – Remove the hose of the low pressure side of manifold gauge. Set valve cork of both liquid side and gas side of packed valve to the open position. Mount the valve stem nuts and the service port cap to the valve, and tighten them at the torque of 183kgf•cm with a torque wrench. Check for gas leakage. - At this time, especially check for gas leakage from the 3 way valve’s stem nuts, and from the service port cap. --------------- For the manual of the unit.please click this link for more troubleshooting http://www.acwholesalers.com/v/vspfiles/assets/images/samsung%20aqv09%20aqv12%20service%20manual.pdf Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Sep 07, 2010
  • raj somaiya
    raj somaiya Sep 09, 2010
    If there is no gas leak and pressures are fine then the gas valve voltage needs to be checked.Its sending wrong command to the computer control board so its showing gas leak.Check the voltage at the gas valve and its connections.Also unplug the unit from power for few hours then reconnect and recheck.If same error comes up.Check from any blockages in drain line and drain pump too.
    Thanks for keeping updated with your query.
What is the corrective action for error code 46?
Outdoor unit suction sensor fault. Disconnect from PCB and measure resistance. 10 kOhm at 10°C and 4 kOhm at 30°C. If OK replace PCB, if not replace sensor
Jun 23, 2015 | LG Art Cool LA240HSV 22,000 BTU SingZone...
Error code c4 on darkin
From what I could find it means that the indoor unit has a malfunction on the liquid gas line pipe thermistor. You should refer this terror code to a trained and qualified technician to further investigate the fault for you.
Jun 05, 2013 | Heating & Cooling
It shuts off and blinks 11
AHX18MEV
4 - 12
[8] SELF-DIAGNOSIS FUNCTION
1. Indoor unit
(AH-X18MEV, AH-X18MEV-1, AH-X24MEV, AH-X24MEV-1)
To display the self-diagnosis, hold down the AUX button for over 5 seconds on the indoor unit when the indoor unit is not operating.
• The operation lamp (red), timer lamp (orange) and Super jet lamp lighter) flash to indicate the information of malfunction.
(Display of self-diagnosis result)
The operation lamp (red) and the Super jet lamp (green) flash in synchronization with the timer lamp (orange).
(AH-XP18MV, AH-XP18MV-1, AH-XP24MV, AH-XP24MV-1)
• The POWER CONSUMPTION indicator indicates the information of malfunction by showing the main category error (number) and the sub-category
error (-number) alternately in 1-second intervals.
Example: Compressor high-temperature error
Remark
3. CHART
<INDOOR UNIT> ?:1-second ON / 1-second OFF
Problem
symptom
Outdoor
unit indication
(LED1)
Indoor unit Malfunction
No.
Content of diagnosis Check point Action
Lamp Main Sub Main Sub
Normal
condition
Normal
blinking
? ? ? ? ? Timer (Orange) 0 0 Normal
Operation (Red)
Super Jet (Green)
Indoor and
outdoor
units do not
operate.
1-time ? ? ? ? ? Timer (Orange) 1 0 Outdoor unit
thermistor
short-circuit
Heat exchanger
thermistor short
circuit error
(1) Measure the resistance
of the outdoor
unit
thermistors.
(1) Replace the outdoor
unit thermistor
assembly.
? Operation (Red)
Super Jet (Green)
? ? ? ? ? Timer (Orange) 1 Outdoor temperature
thermistor
short circuit error
(2) Check the lead wire
of the outdoor unit
thermistor for torn
sheath and shortcircuit.
(2) Replace the outdoor
unit thermistor
assembly.
? Operation (Red)
? Super Jet (Green)
? ? ? ? ? Timer (Orange) 2 Suction thermistor
short circuit
error
(3) No abnormality
found in above
inspections (1) and
(2).
(3) Replace the outdoor
unit control
PWB assembly.
? Operation (Red)
? Super Jet (Green)
? ? ? ? ? Timer (Orange) 3 2-way valve
thermistor short
circuit error
? Operation (Red)
? ? Super Jet (Green)
LED1
AU-X24MV, AU-X24MEV
AU-X18MV, AU-X18MEV
LED1
May 27, 2012 | Sharp Heating & Cooling
Canon MP240 printer, error code P8. Can't print, can't clear error code
Possible causes
1 Wrong wiring of Indoor/Outdoor connection
2 Reverse Phase
3 Protection Device operated
4 damaged Outdoor coil thermistor
for more help visit CBR Tech Solutions
Mar 15, 2011 | Canon PIXMA MP240 All-In-One InkJet...
What does error code p8 mean
P8 means Abnormality in outdoor unit.
Check:
1) Wrong wiring of indoor/outdoor
connecting wire
2) Reversed phase
3) Protection device is working
4) Damaged outdoor coil thermistor
Solution:
1) Check the indoor/outdoor connecting wire.
2) Change the connection of electric wiring.
3) Check the protection device.
4) Measure the resistance of the outdoor coil thermistor.
If the resistance is normal, replace the
outdoor controller board
Hope, helpful.
Feb 03, 2011 | Mitsubishi Heating & Cooling
We have a P8? CAN'T FIND MANAUL
P8-Abnormality in outdoor unit.
1.Wrong wiring of indoor/outdoor
connecting wire.......................Check the indoor/outdoor connecting wire.
2) Reversed phase......Change the connection of electric wiring.
3) Protection device is working........ Check the protection device.(LP,HP)
4) Damaged outdoor coil thermistor.....Measure the resistance of the outdoor coil thermistor.If the resistance is normal, replace the outdoor controller board.
5) Check out door coil is cleaned. If not do it.
thanks.
Jan 30, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
What is the meaning of fault code. error 02. abnormal on my hitachi remote control for cooling unit rpc 5aq5-p
Indoor/outdoor safety device activated. If your unit stops within 5 seconds, indoor coil sensor defective or short of gas/leak. If your indoor works and but out door unit works for just 5minutes and stops means outdoor coil sensor defective or short of gas or leak. find by amps. If less amps than mentioned, is gas leak/short of gas.
Jan 27, 2011 | Heating & Cooling
I have a Mitsubishi electric Mr Slimair conditioning. It runs a few minutes in cool mode, then it stops and an error of P8 code appears. When it runs, the fan is not strong.
connecting wire
2) Reversed phase
Solution:
Hope,it's helpful.
Jan 15, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Hi i have a panasonic cs28 cassett units both have F27 01 fault codes. have checked power at indoor and outdoor units can i do anything else
f27- indoor outdoor unit disconnected.
Check power in output of indoor and input of outdoor, if power variation, replace wire.
Normally in this fault code, one of the wire burnt or rat bitten.
Dec 27, 2010 | Heating & Cooling
Evaporator unit turns on for about 15 seconds then turns off
Out of range thermistor can cause the tripping of indoor or outdoor unit. Try to check the resistance of your thermistor it should be 8 to 10 kilo ohms at 25 deg. c temp.
Oct 31, 2007 | LG LSC121PMA Split System Air Conditioner
Samsung AS18A6RB Air Conditioner Logo
401 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
