Question about Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series - Sens - A - Speed Walk Behind Mower - 10685
2 cycle lawn boy model 10301 self propell lawn mower runs for a few seconds and then dies.
5 Suggested Answers
SOURCE: my craftsman rotory lawn mower 6.5 hp self
You have water in in the carborator, I'll bet. I had this same problem. Here's what I did.
I emptied the gas tank, put in a new spark plug, changed the oil and then unscrewed thd big nut on the bottom of the float container (attached to the carborator near the rubber gas injector button) and emptied and cleand the float container. Then i put it all back together, pulled the cord and the same thing happened, but this time i could keep it going by having my daughter constantly pushing the rubber gas injector button. After it had run for a minute with this constant pushing of the button, all the water was gone from everytwhere and it worked.
Posted on Aug 13, 2009
  • 133 Answers
SOURCE: Craftsman self propelled lawn mower will not propell
Take off the cover up front on the self propel. Engage the self propel and make sure your cable is not broken. If that is ok then remove the wheels and inspect the molded cogs on the inside of the wheels and make sure they are not stripped out. If they are stripped go to www.sears.com and on the tool bar click on parts direct. Under model number enter yours and it will take you to a parts diagram. Get the part number for the wheels and go to local small engine parts dealer and get new. You can also do a search on the web for the wheels and maybe get them cheaper.
Good luck and let me know if this helps or you need any more help.
roundo4
Posted on Aug 16, 2009
SOURCE: Honda lawn mower, self propelled mechanism not working
check the mechanism first before changing the gearbox its possible that the cable might jump out from the pulley or the cable is worn out or its possible that the gear on the tire is worn out to if not then that would be the time for you to change the gear box it would be hard to change it if you don't have the right tools to work on it if you know how everything work its not that hard to replace it just make sure were everything goes memorize the parts before disassembling cause that would be you guide to reassemble it...goodluck
  • 420 Answers
SOURCE: lawn boy 2 cycle mower won't start
Replace the spark plug and retry.
If a new plug does not work push the spring button on the bottom of the carburetor to make sure fresh fuel is in the fuel bowl.
if this does not work remove the spark plug and squirt some light oil (like wd 40) right into the spark plug hole; roll the engine over slowly a couple times using the starter rope. put the plug back in and snap the plug wire in place. If the mower now starts after a couple pulls it means the rings are worn, replace the rings.
Posted on Jun 01, 2010
Lawn boy self propelled mower won't move backwards
is it belt driven can you pull it back when it not running
Apr 11, 2013 | Garden
Toro self propelled lawn mower dies after an hour
maybe u have to much oil in it or there mite be a stone in the carberator or petrol tank thats blocking the petrol ?
Aug 07, 2012 | Toro Garden
I have a Toro self propelled walk behind mower model # 20016. The self propelled just stopped working. My owners manual does not mention anything about the self propell. Can you direct me as to what to...
Toro 20016 self propelled walk behind when the wheels are engaged it moves, when the wheels are not engaged, the wheels look up.
What should I do to fix the problem
Apr 19, 2011 | Toro Lawn Boy Self Propelled CARB Walk...
2 cycle lawn-boy self propelled 6.5 hp Gold Pro Won't start
If you replaced the plug and still dont have any spark you probably need a new coil. If you do it yourself and find the coil on Ebay or a good onliine parts seller you could do it for a reasonable price.
Jul 14, 2010 | Garden
Lawn-Boy Insight Series 21-Inch 190cc 650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower: my engine will only stay running for about 3 secon...
Maybe the engine is running with the fuel from the primer bulb (about few seconds), the carburator is not working and need to be removed checked and cleaned, the most common fail is a jet clogged.
May 17, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Mower starts but boggs down and then dies
Sounds like the air filter media is full of muck.
You need to clean it.
Everything should then be fine....
Jul 01, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Engine won't start . Pour gas in cylinder it starts then quits.
hi lou. your carbeurator is gummed up. It will need to be removed, soaked in carb cleaner for three hours and then rebuilt using the correct kit.
if you are not familiar with how to do this i recommend that u have it done by a lawn mower pro
May 28, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series -  Sens - A - Speed Walk Behind Mower - 10685 Logo
137 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
Jim Parker
Jim Parker
lnbn1975
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
