Question about Canon NP 6050 Copier
Canon 6050 eo13
Stang strommen och sat pa den igen
  • 18 Answers
E013 usually means the waste toner bottle is full. Or it can mean the toner auger is clogged with toner and tripping the safety switch, in which case you'll have to remove the auger and knock out all the clogged toner. Sometimes sticking the end of a vacuum cleaner into the metal tube will **** out the toner, but not all the time. It's messy. Good luck.
Posted on May 26, 2008
Copy the results are less clear, was set darknes but its results are less clear.
replace toner, if not then replace the corona wire all, if not set the drum dens 7, if not replace the Primary H.V.T. Or P.O. pcb.
Dec 27, 2011 | Canon NP 6050 Copier
Reparar mi paint drive kinston
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
hope this helps you
Klicka p? Start Kontrollpanelen administrive datorverktyg Management h?rddisk h?gerklicka p? enheten v?lj Egenskaper Klicka p? verktyg du b?r se p? Kontrollera nu Klicka p? Start tv? boxar automatiskt ?tg?rda filer och s?ka efter och f?rs?k att reparera skadade sektorer plats sedan ett kryss i b?da rutorna och v?lj sedan kontrollera nu b?rjar eller s? kan du kryssa i en ruta att sedan ?terv?nda efter avslutade den f?rsta reparationen sedan ?terv?nda och markera den andra rutan ska du inte g?ra n?got medan chkdsk p?g?r n?gon ing?ng kan skada den h?r enheten
Jag tyckte att du f?r b?st resultat genom att kryssa i en ruta sedan ?terv?nder efter att det har slutat sedan markera den andra rutan
hoppas att detta hj?lper dig
Sep 18, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Nao roda o dvd..
Klicka p? Start p? panelen Verktyg administrive, Datorhantering Enhetshanteraren scrolla ner CD-DVD ROM-enheter du kan se ett gult fr?getecken? h?gerklick kommer du att ha m?jligheter att uppdatera drivrutin ?terst?ll tidigare drivrutin, eller v?lj egenskaper Allm?nna fels?ka, v?lj f?raren klicka f?r att installera om drivrutinerna p? Uppdatera drivrutin eller avinstallera sedan installera om detta inte l?ser problemet kan det vara ett problem i registret om du inte kan se din h?rddisk i Utforskaren
St?ng alla ?ppna program
Klicka p? Start, K?r och skriv regedit och tryck p? Enter
Klicka p? plustecknet (+) bredvid f?ljande mappar
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Kontroll
Klass
{4D36E965-E325-11CE-BFC1-08002BE10318}
Denna mapp ?r DVD / CD-ROM-enhet Klass Beskrivning i registret. Leta efter n?got av f?ljande namn i den h?gra kolumnen.
?vre Filter
L?gre Filter
?vre Filters.bak
L?gre Filters.bak
Om n?gon av ovanst?ende knappar som visas i steg 4 visas, h?gerklicka p? dem och v?lj Ta bort
Efter bort nycklarna, st?ng Registereditorn
Starta om datorn
?ppna Den h?r datorn och kontrollera om din cd-eller dvd-enheter har ?terv?nt. Du kanske ocks? vill ?ppna Enhetshanteraren och kontrollera att den gula utropstecken och felkod p? CD eller DVD-enheten ?r borta. eller
du kanske m?ste fysiskt koppla ur leder till denna CD / DVD sedan in dem igen detta b?r aktivera guiden Ny maskinvara eller
kanske du m?ste avinstallera starta om datorn installera din DVD / CD sedan installera om drivrutinen f?r denna enhet
Om datorn levererades med ett moderkort disk drivrutinerna kan vara p? det
Klicka p? Start Kontrollpanelen administrive verktyg Datorhantering Enhetshanteraren scrolla ner cd DVDROM enheter om du ser ett gult fr?getecken eller utropstecken? ! eller ett r?tt X h?gerklicka m?ste du uppdatera drivrutinen eller
v?lj Egenskaper allm?n fels?kning, v?lj f?raren klicka f?r att installera om drivrutinerna p? Uppdatera drivrutin
Sep 09, 2011 | LG GSA-4160B DVD±RW Burner
Hej jag har prolim med lexmark cover open
Det kan vara patronerna i bärselen. öppna skrivarens lucka och ta bort bläckpatronerna. Kontrollera cylinderampullen område för några hinder i bärselen vägen. Om inga, stäng locket. Koppla ur och tag bort skrivaren till strömkällan att återställa sig själv. När skrivaren slås , sätt tillbaka bläckpatronerna och kontrollera att de sitter i rätt och säkrade. Stäng locket. Försök skriva ut igen.
May 04, 2011 | Lexmark X3480 All-In-One Printer
Hur gör jag för att skydda min router genom att ha ett lösenord????
TR?DL?S TRYGGHET FR?GOR
Steg 1: Anslut router - Computer (Wired)
Steg 2: ?ppna Router Setup genom att skriva http://192.168.2.1 i adressf?ltet i Internet Explorer
Steg 3: P? v?nster under tr?dl?sa Klicka p? Wi - Fi Protected Setup
Steg 4: L?mna l?senordsf?ltet tomt och klicka p? skicka
Steg 5: Inaktivera det och klicka p? Verkst?ll f?r?ndringar
Steg 6: P? v?nster under tr?dl?sa klicka p? S?kerhet
Steg 7: Aktivera 64 bitars WEP
Steg 8: Skriv ett 10-siffrigt nummer p? nyckeln 1 (2 i varje kartong)
Steg 9: Klicka p? Utf?r ?ndringar
Steg 10: till v?nster under tr?dl?s klicka Kanal och SSID
Steg 11: ?ndra den tr?dl?sa kanalen till 6
Steg 12: ?ndra SSID till ett annat namn (utan mellanslag)
Steg 13: Klicka p? Verkst?ll ?ndringar
Steg 14: Nu Scan och ansluta till detta n?tverk (tr?dl?st)
L?t mig veta om det fungerar
Oct 19, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Hej!Jag har en CASIO EX-Z150. När jag sätter på kameran säger den att kortet är låst. Jag vet inte vad jag ska göra. Det går inte att göra nånting med...
Ibland finns det en liten str?mbrytare p? sidan av SD-kortet som g?r det m?jligt att skriva till kortet av och p?. Om det misslyckas ?r det f?rst med ett annat minneskort.
Aug 19, 2017 | Casio EXILIM Zoom EX-Z150 Digital Camera
Begge gr?¸nne lamper blinker
Hej Flemming,
Heldigt en af de meget få Danskere lige kom forbi - ikke?
- Når du løfter låget skal blækpatronen komme hen til ca. midten, så man kan skifte den, - gør den det?
- Har der sidet et stykke papir i klemme? hvis, - fik du så DET HELE ud?
afventer /Teis
Jan 03, 2009 | Lexmark Z12 Printer
NP 6050 Languge
how to fixed canon np 6050 copier because i dont have manual book
May 03, 2008 | Canon NP 6050 Copier
Abit BL7-RAID
Please formulate question in English, or submit to general questions
Thanks
Apr 17, 2008 | Abit BL7-RAID Motherboard
Canon NP 6050 Copier Logo
87 people viewed this question
old marine
old marine
