Question about Danze Plumbing
I am a plumber with a customer who bought a Danze Single Handle Shower Valve. It has a bronze finish. I do not want to scratch this valve. The valve is leaking. I need to know the correct approach to taking the valve apart so that I can find the problem.
  • 8,197 Answers
May I get the model # of the valve so I can help you more.
Posted on Sep 07, 2010
Why does the water not flow from shower valve when turned on?
Do you have water coming out of the tub spout and not the shower head? If so how does the water get directed to the shower head,is it by pulling up the diverter on the tub spout?If water is still coming out of the tub spout then the diverter is bad and the tub spout needs to be replaced.
May 09, 2012 | Danze & Single Handle Tub And Shower...
Installed new Danze shower valve the water is on but will not come out why?
shut off your water and pull the cartridge out off unit...make sure you have no trash in cartridge...turn water on without cartridge in but only part way to see if you have water flow to value...then make sure no damage to cartridge or some of these have plugs that need removed on install of cartridge....you may need to remove test plug that is in there ....try this...good luck
I have a Danze D112000BT Single Control Pressure Balance Mixing Valve with Screwdriver Stops that was installed in 07, it been working fine then last week it all of a sudden became really stiff to turn...
Danze cartridges are known to have problems after time with hard water. If you call Danze at 1-888-328-2383 USA
Canada: 1-800-487-8372
They have a lifetime warranty of defects, and will replace the cartridge for that valve for free. It will actually be best to have a plumber do it because taking the cartridges out can be simple, putting them back in and tightening it up the way it should be can be tricky. It is nice that you have the valve with the screwdriver stops. That allows you to remove the cartridge without having to turn the water off to the entire house. Simple turn each stop to turn the water off, remove cartridge, put new cartridge in.
May 01, 2011 | Danze & Single Handle Tub And Shower...
I have Danze, single handle shower faucets that were professionally installed in 2005. One shower faucet has not hot water, just cold and when the handle is turned on all the way to hot, there is an itty...
Replace valve canister- no construction- just remove after taking time to shut off water- a few screws and the job takes 15 minutes. I take for granted you have good water hot/cold to the fixture. This fix will cure most temperature balance problems.
The single lever system is a EZ care system. Note the canister can malfunction faster when exposed to untreated hard water.
Nov 17, 2010 | Danze & Single Handle Tub And Shower...
Need an instruction sheet for cartridge replacement for Danze Sheridan tub and shower faucet
This link will get you to the Danze illustrated parts list for the Sheridan single control tub and shower valve.
http://www.danze.com/products/pdfs/D510055_ip.pdf
Aug 08, 2010 | Danze Sheridan Tub & Shower Faucet
My shower vavle does not close off the water completely to the shower or the tub. Any suggestion of what may be the problem?
If the valve is found on the spout replace it as it may have corruded calsium build up. if it is a valve between the hot and cold water than shut off the water to the house and pull off the valve take to store and replace with a like one. Good luck.
Mar 04, 2010 | Danze & Single Handle Tub And Shower...
Danze pressure balance single handle shower faucet (D500558BN) pipes vibrate when adjusting hot and cold water.
it the valve is full of dirt or needs to replaced not all the time but i have fix many buy just cleaning it out or pipes are fasten down. try just cleaning.
Jun 10, 2009 | Danze D500558BN Parma Shower w/ 4"...
Shower valve leaking
here is the link to the pdf file http://www.plumbersurplus.com/pdf/07606.pdf
If you cant get directly to it from the above link, go to plumbersurplus.com/prod/danze-D51001BNT then click on "documents"
Apr 04, 2009 | Danze D510011BNT Brushed Nickel Melrose??...
Danze shower kit
your husband is 100% correct unless you change the shower head or take the one off that is there and take out the little plastic filter thats right inside where it screw on to the shower arm,, easy fix
Nov 09, 2008 | Danze D500558T Parma Shower w/ 4"...
Plumbing Logo
54 people viewed this question
Top Danze Plumbing Experts
David Wiebe
Level 1 Expert
Donni Steen
john h
Are you a Danze Plumbing Expert? Answer questions, earn points and help others
