Question about GE GTS22WCP Top Freezer Refrigerator
Freezer stops making ice. when it is cut off it starts again and then stops
  • GE Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Posted on Sep 12, 2010
Refrigerator and freezer not getting cold enough
Yes the defrost timer should come on by itself and if it does not just turn the timer again clockwise and replace timer because this will cause the refrigerator to not defrost. I don't have the amount of time off for yours but some timers are off for up to 30 minutes three times a day.When looking at the rear wall of freezer do you see frost build up? The ice maker will stop making ice most times above 5 degrees inside freezer. Let me know Thanks Sea Breeze
The defrost timer for your model is=> 68233-3 Defrost Timer
Aug 22, 2012 | Refrigerators
Frigidaire side by side freezer - LOUD noise...
It sounds like the evaporator fan is hitting ice that is built up on the evaporator coil. When it's making the noise, open the freezer door and see if it stops.
(Most models are wired so that the evaporator fan cuts off when the freezer door is open.)
Check the inside back, lower panel of the freezer for ice built up or frost on it. If there is, you have a defrost problem that is most likley a bad heater. It's located around the coil inside the freezer behind the panel you will be looking at. The defrost problem would explain the freezer not freezing ice cream.
Nov 12, 2009 | Frigidaire FRS26R4A Side by Side...
We had a power cut for a couple of hours and ever since the freezer has stopped making ice, I have emptied and dried the ice cube storage bin, checked for any kinks in the water pipe, any suggestions?
it may take a while for your fridge to cool down that water again. if this happened in the last half hour or so. im guessing your fridge may take upto an hour to drop a load of ice.. this also depends on the ambient temperature
Nov 11, 2009 | Freezers
Ice maker stopped making ice. I had to melt ice
Jim, you will need to replace the heating element and most likely once this has been replaced, your ice maker should work properly unless the ice broke another part on your ice maker.
I would start with the heating element first.
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service with your model number and we will get the correct part out to you asap!
We look forward to getting your ice maker working properly again soon!
Thanks, Ella
Nov 09, 2009 | GE Profile Arctica Stainless Steel Top...
Feezer does not make ice. there is cold water. Installed new filter
Check the temp inside the freezer with a thermometer. It should be between -10 and 0 degrees. The ice maker has a thermostat that cuts it off once the temp gets above 5 to 8 degrees. (According to the model) If your freezer is warm, check the inside back panel of the freezer. If it has ice or frost on it you have a defrost problem. This will have to be repaired before the ice maker will work. If you have ice or frost, your freezer will also continue to warm up until your fresh food section gets real warm.
Please rate solution
Sep 23, 2009 | Frigidaire FRS26R4A Side by Side...
Ice make not making ice, water dripping in Freezer
need to replace coolant in the freezer. Either that or electricity cuts out. check cable
Aug 24, 2009 | GE Refrigerators
Ice maker and water stopped working, hear a clicking sound. We tried cutting power and starting again, it stopped making the noise, but we still got no ice or water, and after a couple hours started making...
the sound from the icemaker is coming form the water solenoid valve, which needs to be replaced. if your frezer is cold then the fan is fine, most are switched to turn off when you open the door so you arent likely to see it running unless you set up a camcorder in your fridge :-)
Aug 14, 2009 | General Electric GSH25JSXSS Stainless...
Ice maker makes too much ice
In my Kitchen Aid bottom freezer there is a metal arm(?) that I lift up to stop the ice maker from making ice. When I start running low on ice, I push the metal arm(?) back down for it to make ice again. Hope this is the solution for your Kitchen Aid too.
Jul 22, 2009 | KitchenAid Superba Architect KSCS25INSS...
A very unusual 'croaking' frog like noise from the back of the freezer compartment. It stops if the freezer door is opened and starts again once closed. The freezer light switch is involved: With the...
I have a Kenmore Elite Trio and the freezer was making a frog sound. I found the solution.
My model number is 596.75523400. The sound will stop when the freezer is opened. It will stop again when the freezer drawer is open and the light switch is pressed to turn off the light. The ice drawer was full but it had stopped making ice.
Here is the fix in less than 10 minutes using only a screwdriver.
  • Take out the two freezer baskets
  • Remove the freezer door from the two slide tracks.
  • Unplug the icemaker electric connection at the back wall. Depress the clips on the side of the plug and wiggle it loose.
  • There are 3 screws that attach the icemaker to the left freezer wall. Remove the lower screw and unscrew the top two about ½ way out.
  • Slide the icemaker up so the slots slip over the 2 screws.
  • Put the icemaker in the sink and run a bit of water on the frozen cubes until they fall out.
  • Take the screwdriver and check the water inlet hose/pipe for ice that obstructs the flow of water into the ice maker.
  • Re-mount using the 3 screws and plug in the electric connector. Make certain the water inlet tube is positioned thru the retaining hole before you remount the screws.
  • Replace freezer door and baskets.
Jun 05, 2009 | Maytag MBF2556HEW / MBF2556HEB /...
GE GTS22WCP Top Freezer Refrigerator Logo
Top Refrigerators Experts
Sal DeAngelo
dweatherby
