Question about Poulan Garden
How do I remove the ignition module in a 2300cva chinsaw?
    Brigadier General:
  • 4,088 Answers
Remove the starter mechanism and the left side cover to expose the flywheel and ignition module. If you have little or no spark, try setting the pole gap using a thin business card for a gap gauge. Turn the flywheel magnets under the ignition module poles, insert the card into the gaps, loosen the module screws and allow the poles to contact the magnets. Reset the screws and try for spark. Hope this helps!
Posted on Sep 09, 2010
Where Is the anti theft module
Passive Anti-Theft System (PATS) Transceiver module is around the key lock cylinder behind or under the plastic cover on the upper steering column'
Passive Anti-Theft System (PATS) Transceiver Removal
  1. s4h~tr~en~file=ani_caut.gif~gen~ref.gif CAUTION: Electronic modules are sensitive to electrical charges. If exposed to these charges, damage may result.
    Disconnect the battery ground cable, Refer to Section 414-01
  1. Remove the ignition switch lock cylinder.
    1. Insert the ignition key into the ignition switch lock cylinder and turn to the RUN position.
    1. Push the ignition switch lock cylinder release tab with a punch while pulling out the ignition switch lock cylinder.
    2. If equipped, remove the tilt wheel handle.
    3. Remove the upper and lower steering column shrouds.
      1. Remove the screws.
      1. Remove the upper and lower steering column shroud.
      2. Remove the lower instrument panel steering column cover.
        1. Remove the lower instrument panel steering column cover.
        2. Remove the instrument panel steering column opening cover reinforcement.
          1. Remove the bolts.
          1. Remove the instrument panel steering column opening cover reinforcement.
          2. Remove the anti-theft transceiver module.
            1. Remove the screw from the bottom of the transceiver module.
            1. NOTE: Only apply pressure or leverage below the key cylinder lower rib.
              Disconnect the electrical connector and remove the module.
Dec 24, 2014 | 2006 Ford Taurus
How to replace ignition switch in a 2005 chevy malibu
IGNITION SWITCH REPLACEMENT
REMOVAL PROCEDURE
1.Remove the instrument panel (IP) cluster.
2.Remove the knee bolster.
3.Remove the I/P center trim panel.
4.Remove the ignition switch wire harness connector.
5.Remove the theft deterrent control module wire harness connector.
6.Remove the ignition switch lock cylinder.
7.Disconnect the park lock cable at the ignition switch.
8. Remove the ignition switch at the IP screws.
Image - 1
9. Remove the ignition switch assembly.
10.Remove the ignition switch bracket screws.
11.Remove the theft deterrent control module.
Image - 2
12.Remove the ignition switch bracket.
INSTALLATION PROCEDURE
Image - 3
1.Install the ignition switch bracket.
2.Install the theft deterrent control module.
3.Install the ignition switch bracket screws.
NOTE: Refer to Fastener Notice in Service Precautions.
Tighten the screws to 5 Nm (44 lb in).
Image - 4
4.Install the ignition switch .
5.Tighten the ignition switch screws.
Tighten the screws to 2.5 Nm (22 lb in).
6.Connect the park lock cable at the ignition switch.
7.Install the theft deterrent control module wire harness connector.
S. Install the ignition switch wire harness connector.
9. Install the ignition switch lock cylinder.
10.Install the I P center trim panel.
11.Install the knee bolster.
12.Install the I P cluster.
Image 1 d7344ac5-6e5f-4114-8faa-23bf7604107d.png 0b4f88b4-5e6e-48f0-8503-df723612d94e.png 22b3f198-449c-4417-a826-aa8b11cddcfd.png 5996e9cb-4503-445f-b97b-17d69eea7c08.png
Thank you for using Fixya.com
Master Tech Lee
www.autorepairhelp.us Ask Automotive Repair Questions
May 03, 2014 | Vehicle Parts & Accessories
How to install a 94 buick regal ignition modulator
take the negative cable off the battery,unplug the plugs relaled to the ignition module.remove the ignition wire from the coils ;remember where they were removed from so that you don't cross the wires. once that you've done that remove each coil and the ignition module will be cler and available for you to remove the screws that holds the module in place. install the new module, be sure to follow all directions and repeat the removable instruction in reverse to install new module.
Sep 03, 2012 | 1994 Buick Regal Gran Sport
Can't remove blade to change it. How does it some off. The cap looking pience won't budge
If your talking chinsaw then the chain comes off not the whole track and to get the cain off just loosen the blade track and it comes right off . You can get a new chain or get the old one sharpened,unless tey are expensise for the model I would get new- Heck Harbor freight sells them for cheap ,just make sure you buy the right length(inside diameter)
Jun 30, 2011 | Garden
Where is the ignition module located on 2004 honda civic lx
I searched under 'ignition module' on autozone.com and 'no parts for ignition module' turned up.
I looked under DIS or Distributorless Ignition System and found the coils are inserted in the top of the engine and this tells me that it's likely that the ECM or PCM controls the spark on these cars.
Civic
1.7L Engine
  1. Disconnect the negative battery cable.
  2. Remove the ignition coil cover (A), disconnect the ignition coil connectors (B), then remove the ignition coils (C).
  3. Installation of the ignition coils is the reverse of the removal procedure.
    Fig. Remove the ignition coil cover (A), disconnect the ignition coil connectors (B), then remove the ignition coils (C)
Jan 24, 2011 | Honda Civic Cars & Trucks
I am looking for a spark plug wiring diagram for 1997 buick park ave 3.8 to see if the wires may be crossed.
Sometimes the coil packs are numbered from the factory --- Firing Order 1-6-5-4-3-2
Ignition Coil Removal & Installation To Remove:
  1. Before servicing the vehicle, refer to the service precautions in the beginning of this section
  2. Disconnect the spark plug wires from the coils
  3. Remove the fasteners securing the coil(s)
  4. Remove the coil(s) from the ignition control module
To Install:
  1. Install the coil(s) to the ignition module
  2. Install the coil fasteners
    • Torque to 40 in-lbs (4.5 Nm)
  3. Connect the spark plug wires to coil assemblies
Ignition Module Removal & Installation To Remove:
  2. Turn the ignition OFF
  3. Disconnect the 14-way connector from the ignition module
  4. Note the position of the spark plug wires and disconnect from the coils
  5. Remove the fasteners securing the coil(s)
  6. Remove the coils and the Ignition module from the bracket
To Install:
  1. Install the coils and the ignition module to the bracket
  2. Install the fasteners that retain the ignition coils to the ignition module
    • Torque the fasteners to 40 in-lbs (4.5 Nm)
  3. Install the nuts and washers that retain the ignition module to the bracket
    • Torque the screws to 70 in-lbs (8 Nm)
  4. Connect the spark plug wires to the coils assemblies
  5. Connect the 14-way connector to the ignition module
    • Torque the screw to 19 in-lbs (2.1 Nm)
Oct 26, 2010 | 1997 Buick Park Avenue
How do you remove the ignition coil
Each ignition control module (ICM) has the following circuits:
An ignition 1 voltage circuit A chassis ground An ignition control circuit for each cylinder A low reference circuit
The PCM controls spark by pulsing the ignition control circuits to the ICM to trigger the coils and fire the spark plugs. The PCM and ICM are internally protected against shorts to power and ground on the ignition control circuits.
The spark plugs are connected to each coil by a short boot. The boot contains a spring that conducts the spark energy from the coil to the spark plug. The spark plugs are tipped with platinum for long wear and higher efficiency.
Ignition Control Module (ICM) Connectors
Fig. Ignition coil locations 2001-2004 4.8L, 5.3L, 6.0L Engines
2.2L (L61) Engine
  1. Turn OFF the ignition.
  2. Remove the accelerator cable from the bracket.
  3. Remove the accelerator cable bracket bolt.
  4. Remove the accelerator cable bracket.
  5. Disconnect the ignition control module (ICM) harness connector.
  6. Remove the ICM retaining screws.
  7. Remove the ICM from the ignition coil housing.
To install:
  1. Install the ignition control module in the ignition coil housing.
  2. Install the ICM retaining screws. Tighten the retaining screws.
  3. Connect the ICM harness connector.
  4. Install the accelerator cable bracket.
  5. Install the accelerator cable bracket bolt. Tighten the retaining screws.
  6. Install the accelerator cable to the bracket.
2.2L (Ln2) Engine
  1. Remove the air cleaner outlet from the air cleaner.
  2. Remove the ICM electrical connectors (1) and spark plug wires (2).
  3. Remove the ignition coils bolts (3).
  4. Remove the ignition coils and ICM assembly.
  5. Installation is the reverse of the removal procedure.
2.4L Engine
  2. Remove the accelerator cable from the hold down clip.
  3. Remove the cruise control cable, if applicable.
  4. Remove the bolt from the fuel line retaining clip.
  5. Disconnect the 11-pin harness connector for the ignition control module (ICM).
  6. Remove the bolts from the ignition coil and the ICM assembly-to-camshaft housing.
  7. Remove the ignition coil and ICM assembly from the engine.
  8. Remove the screws that retain the housing to the cover.
  9. Disconnect the coil harness connector from the ICM.
    CAUTION When removing the housing from the cover, make sure the ground strap stays in place.
  10. Remove the housing from the cover.
  11. Remove the screws that retain the ICM to the cover.
  12. Remove the ICM from the cover.
    Fig. Removing the ICM from the camshaft cover
To install:
CAUTION DO NOT wipe grease from the module or coil if the same module is to be replaced. If a new module is to be installed, a package of silicone grease will be included with the module. Spread the grease on the metal face of the module and on the cover where the module seats. This grease is necessary for module cooling.
  1. Install the ICM to the cover.
  2. Install the screws that retain the ICM to the cover.
  3. Install the ground strap, if necessary.
  4. Connect the ignition coils connector to the ICM.
    CAUTION When installing the housing to the cover, make sure the ground strap stays in place.
  5. Install the housing to the cover.
  6. Install the screws that retain the housing to the cover.
  7. Install the spark plug boots and the retainers to the housing, if necessary.
  8. Install the ICM assembly to the engine while carefully aligning the spark boots to the spark plug terminals.
    CAUTION The ICM cover bolts must be installed using isolator washers with the rubber side facing down.
  9. Install the bolts that retain the ICM assembly to the camshaft housing after coating the bolt threads with LOCTITE, or equivalent. Tighten the bolts to 16 ft. lbs. (22 Nm).
  10. Connect the ICM 11 pin harness connector.
  11. Install the bolt to the fuel line retainer clip.
  12. Install the accelerator cable into the hold down clip.
  13. Install the cruise control cable, if applicable. Connect the negative battery cable.
Hope this help (remember comment and rated this).
Apr 05, 2010 | 2000 Chevrolet Blazer
I need a schematic to replace the PCM (Powertrain Control Module)in my 1994 Fodr thunderbird 3.8L V6 without/supercharger ..Is this is Big job for a backyard mechanic and how long should it take, my real...
  1. Easy job and should have no problems here some help
  2. Detach the engine control sensor wiring connector from the ignition control module by pressing down on the locking tab where it is stamped PUSH, and remove the connector.
  3. Remove the ignition module and the module bracket from the front fender apron.
  4. Unfasten the two ignition module retaining screws, then remove the ignition module form the module bracket.
To install:
0900c1528006b5b4.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 2: The ignition module on 1994-95 vehicles is mounted on the front fender apron
  1. Install the ignition module onto the module bracket. Tighten the retaining screws to 24-33 inch lbs. (2.7-3.7 Nm).
  2. Position the ignition module and bracket assembly onto the front fender apron. Secure with the retaining bolt and tighten to 35-50 inch lbs. (4-5.6 Nm).
  3. Attach the engine control sensor wiring connector to the ignition module.
  4. Connect the negative battery cable.
Nov 19, 2009 | 1994 Ford Thunderbird
How do I change an ignition coil on a V6 1997 Grand Am?
Removal Procedure
  1. Remove all the electrical connectors at the ignition control module.
  2. Note position of spark plug wires for installation
  3. Remove the spark plug wires from ignition coils.
  4. Remove the screws securing coil assemblies to ignition control module.
  5. Disconnect coils from ignition control module. Installation Procedure
    1. Install the coils to ignition control module.
    2. Install the screws and tighten to 4-5 Nm (36-44 lb. in.) .
    3. Install the fasteners securing assembly to engine and tighten to 8 Nm (70 lb. in.) .
    4. Install the spark plug wires as noted during removal.
    5. Install the electrical connectors to the ignition control module
  6. Hope this Helps !
Sep 30, 2009 | 1997 Pontiac Grand Am
HARD STATING CHINSAW ZR10926
try:
- Control fuel level, min. 25% tank capacity. and off course use correct ratio of fuel/oil
- Check air filter is clean.
- Remove spark plug,dry it, clean it and adjust it, and replace it, if necessary.
Jan 24, 2009 | Homelite Garden
Garden Logo
76 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
