Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Freezer is cold but frost building up in the front right portion, also frost on top/ceilngi of freezer and back now too.
  • Kenmore Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 07, 2010
I have an amana ASD2522wrw03. The refrigerator portion and the top of the freezer by the frige vent are warm. The rest of the freezer is cold but there is a lot of ice build up. I am assuming that the...
Outside of the unit being very hot then you might have a bad condenser fan motor or dirty coils. If the heavy frost is just on the back wall then you could have a defrost issue, if the frost is all over then the door isn't closing all the way.
Mar 15, 2013 | Amana Refrigerators
Hotpoint (GE)CTX18GJB not cold enough. Just had serviced - tech replaced defrost timer and defrost terminator. The top located freezer gets cold and can hear the fan running - but still not cold enough...
I agree with the tech. if the refriderator isn't frosting it isn't working,their is only 1fan and its in the freezer,The tech could have missed some frost build up that is blocking the air flow into the fresh food section,if he removed all the frost it could take up to 24 hours to get cold ,it should slowly geta bit colder throughout the day,if by tomorrow its still not working have the tech come back and check for frost build up on the vents for air flow into fresh food compartment.
To reiderate their is two types of refrigerators,one that you have to manually defrost and a automatic defrost type where the defrost system which is comprised of the defrost heater,timer&termination t-stat will automatically melt the frost
Jul 28, 2011 | Refrigerators
No cold air
Look into the rear of the freezer and see if there is a frost line building up on the rear panel. If yes the begin by unplugging and manually defrosting the freezer. Im going to locate your service manual and send it to you. You are sure the MBF2254H is your model? Sea Breeze
Nov 15, 2009 | Maytag MBF2254H Bottom Freezer...
Refrigerator is staying at 50 degrees, will not get any cooler
May be your computer board, not turning on the defrost heaters in the freezer section. The freezer will eventually get warm too. Are you getting frost build-up on the rear wall of the freezer? If you are, you can temporarily solve the problem by turning off the whole refrige for a day and open up the freezer door- put towels on the floor under the freezer doors. Then turn it back on - mine worked fine again. I am currently waiting for a computer board replacement. It is behind the metal plate on the back (outside) of the cabinet. Good luck.
Sep 28, 2009 | GE Profile PSW26P Stainless Steel Side by...
Refrig not cold enough, ice buildup on banck panel of freezer
ice build up means your refrigerator is not going through defrost cycle. you have ice build up on evaporator which restricts your cold air flow into the fresh food side. check defrost timer, defrost thermostat located on evaporator behind the wall where your getting frost. check defrost heater. it wraps under the evap.
Jun 21, 2009 | GE Refrigerators
Refrigerator is barley cold, still makes ice, condensation inside of frostless freezer
Hi: The fact that it still makes ice tells me the freezer is a zero degrees. When you said condensation in the freezer did you mean frost? If your defrost heater fails it will cause the frost free freezer to build up frost. The frost will build up and block the vent that supplies the cold air to the fresh food. The defrost heater is behind the metal wall at the back of the freezer, at the very bottom. A glass tube with a metal coil in it. The coil can break and stop the defrosting. Replace that. Use a hair dryer to melt the frost from behind the panel. All of it top to bottom. You need to remove all the frost to free up the airways. I hope this helps, Jeff
Jun 04, 2009 | Maytag MSD2756G Side by Side Refrigerator
Freezer wrk OK but temperature in the bottom fridge not cold
If you have a frost build up on the interior back wall of the freezer, you have a defrost issue. This would include a bad defrost control, bad heater or terminator.
If there is not a frost build up then you may have a bad evaporator fan motor.
Apr 28, 2009 | Frigidaire FRT17G4B Top Freezer...
Freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Aug 05, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Frig not cold but freezer is ice maker not making much ice either
Is your fan blowing in the freezer? Frost on the back wall of the freezer usually indicates a defrost problem... defrost themostate, heaters, take back panel off and check evap for frost build up and if your fan in working.
Aug 28, 2007 | Amana AFD2535DES French Door Refrigerator
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
79 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
