Question about Krups BeerTender B95 Beverage Dispenser
Blinking screen ans no control of unit does not get cold approx 1 year old
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 8 Answers
Blinking. does not show Temp or calender. I have same problem. unplugged the thermastate and plugged back in. Looks like it tries to
reset but then proceeds to go back blinking. Have not found a solution to problem. Im afraid the cooling unit is out and ro there is a thermastate problem.
Posted on Sep 09, 2010
  • 8 more comments
  • Pete Mote
    Pete Mote Sep 10, 2010
    Blinking screen is most likely a current limit issue. If you unplug the peltier plater or thermoelectric plate the blinking stops. Problem is that the thermoelectric plate has shorted or gone bad. This can be removed and replaced. cost of plate is approx 5$, you'll need a small amount of thermal grease. Time to repair is about 20 minutes. mastecutor@gmail.com
  • Pete Mote
    Peltier plate is bad.Need to replace plate. approx $5 to purchase. mastecutor@gmail.com
  • Pete Mote
    Pete Mote Sep 14, 2010
    Additional Information. Although the Peltier effect plate can go bad I found
    an additional problem with the Krups Beer Tender design. The four
    DC power supply Capacitors go bad. These are 16V electrolytic caps
    3 x 1000uF and 1x500uF. All four of these caps were blown. Replace
    these and the blinking screen and Tender will star cooling once again. Send
    me an email if any questions. mastecutor@gmail.com
  • sbarber2930 Dec 31, 2010
    can you give any guidance on how to replace the peltier plate?
    sbarber2930@att.net
  • davyde84
    davyde84 Feb 23, 2013
    i have a problem in the same board my capacitor c13 is disappeard.. can someone tell me wich capacitor is?
  • davyde84
    hi everyone i have a problem.. i already changed the big capacitor and now after 2 years my board on the other side is broken i lost capacitor c13 can someone tell me wich capacitor is to change it?
  • Enrique Jul 22, 2013
    Hello davyde84.
    Hello davyde84,
    Hello davyde84,
    Capacitor c13 is capacitor e104m (you can search for it in google)
Fridge too cold.Freezer OK.
You probably have an issue with one of the following:
* temperature control assembly (controls freezer and/or fresh food temperatures)
* damper assembly (allows air from freezer to fresh food compartment)
Contact an appliance service company.
Feb 26, 2010 | Refrigerators
Panasonic DMR-EZ28 won't talk with remote
hi you need to reprogram the remote to fit with the unit there have 3 codes for remote 1 or 2 or 3 to reprogram your remote with the code indicated on your display press and hold the [3] and [ENTER/OK] buttons together for approx 5 to 10 seconds, then release
Jun 24, 2009 | Panasonic DMR-EZ28K DVD Recorder
Oven shuts off
Sounds like the spark module has been shorted out and quite possibly the main control board. Apptech.
Oct 19, 2008 | Thermador RDF30 Dual Fuel (Electric and...
Phillips TV Sometimes Come's On No problem and Then Not sometimes with Green blinking light
I HAVE LOST THE TOP PORTION OF MY SCREEN, APPROX 2 1/2". IS THERE AN EASY WAY OF REPAIRING?
Oct 13, 2008 | Philips 32PT6441/37 32" TV
DU1100 Stops mid cycle.
main control cpu unit failing
needs to be replaced
May 09, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Philps TV problem
When I turn the TV on, I get a horizontal line across the screen approx 1/3 from the top. My TV make is Diamond and is approx 6 yrs old
Mar 14, 2008 | Philips Magnavox 27MS343S 27" TV
Refridgerator freezing food
dm, I'm not sure if the thermostat is mechanical or electronic. Assuming mechanical...and I do...turn it to the lowest number...does it turn off? If this works properly, the problem is likely not the control. Does the compressor turn off at any time? If not after an hour or so of operation, the stat could be defective. That's my first guess. Oh, have you made sure that you don't have the ducts in the freezer blocked? The would deflect too much cold air to the fridge section.
Next, defrost the unit and clean the condenser coils. This will help the unit work properly. Then, wait awhile with the unit off. Meanwhile, access the compressor in the rear of the unit. Find the largest pipe coming out of the compressor. Turn the unit on. The largest pipe should frost and then, in about 5 minutes or so...either cause condensation or dry out. If neither happens and the line is either not COLD to the touch or frosty, you're low on gas. If the unit is less than 5 years old, you may get warranty coverage on the sealed unit from the mfgr. Believe it or not, too little gas will cause freezing in some cases!
Nov 28, 2007 | Kenmore 53212 / 53214 / 53219 Side by Side...
Krups BeerTender B95 Beverage Dispenser Logo
1,836 people viewed this question
Top Krups Refrigerators Experts
Tom Chichester
Terry Hair
JonSnell Electronic
JonSnell Electronic
Are you a Krups Refrigerator Expert? Answer questions, earn points and help others
