Question about Velbon CX-440 Tripod
I need an arm that winds up the head from the tripod, but I am not sure what it is called
What do I do to attach the camera after attaching it to the mount piece?
the quick release plate, that you are calling the "mount piece" will just snap onto the head of the tripod - if you aren't sure, a good way is to take off the QR plate from the camera, and then, with the screw threads face up, see how it fits into the head - many times, you have to engage the spring lever, so when you set the plate inside the head, it will snap locked into place. Then, re-mount it on your camera, and do the same thing, and there ya go.
Jul 01, 2014 | Manfrotto Camera Supports 3405BN JR. BLK...
Head won't secure to tripod
Two potential issues. 1. Perhaps you have just not screwed it on tight enough. Just tighten the black knob as much as you can then screw the head on your legs as tight as you can. 2. If you can't even do that I will assume that the hole on the bottom of the head is too large for the screw on the tripod legs, in which case you just need a a bushing adapter. Like this one:
http://www.bhphotovideo.com/c/product/882988-REG/Sunwayfoto_tn_15_Bushing_3_8_1_4_Stainless_Steel.html
Apr 10, 2014 | Gitzo Gh2750qr Series 2 Magnesium Off...
Customer service for giottos
To order service parts contact the importer:
Canada-JCL Sales (Richmond B.C.)
USA-HP Marketing (Pine Brook NJ)
-Inform them of the tripod model and possibly provide them with photos of where the spreader arms attach to both the legs & the center column...., you may require additional parts.
Mar 31, 2013 | Giottos Vt-809 3-section Compact Tripod...
I dont know which head would fit my tripod
Most tripods have a standard screw on top. This allows users to mix&match tripods and heads. Thus, just about any head should fit your tripod. If you're not sure, take your tripod with you to a good camera shop and see if any of their heads fit. If one fits, it's a pretty good bet that the others will as well.
The choice of the type of head (pan-head or ball-joint), its weight, cost, and other factors are, of course, up to you.
Feb 11, 2012 | Photography
There's a wiggle when I try to pan side to side (so there's always a slight **** in the video). This is a fairly new tripod (Manfrotto 7321yb), so not sure if it's a defect, or something that I need to...
The first thing that comes to mind with this issue is that this is not a real video tripod. This is a still tripod. With that said you might just want to try to make sure the pan/tilt locks are fully unlocked, then move the head back and fourth quickly (without the camera attached) for a few seconds to actually warm up the head.
Hope that helps!
May 03, 2011 | Manfrotto 7321YB Tripod
Hello i have a vanguard ov-500 i need a quick realese coz i lost my and is there a way to change the qs-10 or top of the tripod for a new one
Im sorry this tripod has a built in mounting screw making it unable to change or alter the head of the tripod for anything else, don't get discouraged though as you can find many tripods for a small amount of money at http://www.bhphotovideo.com/c/search?Ns=p_PRICE_2%7C0&ci=2635&N=4291756644 just be sure to check and make sure it has an interchangeable or quick release head
Mar 01, 2011 | Vanguard International MK-4 Tripod
The spring on the release arm not working/broken Manfrotto 410
that is not a repair that the user can make. Contact the service department at: manfrottodistribution.com
Mar 17, 2010 | Photography
My fluid video tripod head is stuck to the tripod. help! note: i have the manfrotto 503hdv head, and the legs are actually manfrotto 055CXPRO3 i have tried tightening the head controls. i have...
Make sure you are loosening the 3 grub screws under the tripod head to release it from the tripod center column. there are the 3 slotted screw heads under the grey part of the tripod head. Make sure you back them all the way out before you start to loosen the head.
Jan 28, 2010 | Manfrotto 503HDV Head and 351MVB2 Tripod...
Breakdown Manfrotto 3265 ball head from 190xb tripod
IT SOME TIMES TAKES A LOT OF EFFORT TO SEPARTE THE HEAD FROM THE TRIPOD. MAKE SURE YOU REMOVE THE 3 LITTLE SCREWS FROM BELOW THE HEAD, AND MAKE SURE THE TRIPOD AND HEAD ARE NOT COLD. IF THEYA RE WARM THEY WILL SEPARATE EASIER.
May 06, 2008 | Manfrotto MagFiber 190MF4 Tripod
3030G pan tilt head
The little brass arm is supposed to be a safety switch. In one position the release lever bumps into the brass are and will not turn so the quick release willnot come off. In the other position the brass arm is away from the lever so it swings freely and the quick release plate will come off. With the brass arm open the quick release lever shoulde lock open until you push the quick releae in place. If none of this seem to work on your head, you may be missing parts. Try www.bogentripodparts.com
Feb 19, 2008 | Bogen Communication Bogen Manfrotto 3030G...
Velbon CX-440 Tripod Logo
Top Velbon Photography Experts
JP Services
JP Services
Bill Eager
Are you a Velbon Photography Expert? Answer questions, earn points and help others
