Question about HP Pavilion dv5-1160us NoteBook Intel Core 2 Duo P7350 15.4' Wide XGA 4GB Memory 320GB HDD ...
I have an HP Pavilion Dv5 wireless laptop. I have used it for 8 months by logging on and connecting with my desktop. However this morning a screen came uo that said "cannot connect to thi page" When I click diagnose the answer is "Turn on wireless capability by turning on the switch usually located on the front or side." Does this mean that the internal wireless connection has gone bad?
  • raspease Sep 09, 2010
    This expert was right on with his answer. I can now use my computor again. Thanks
    President:
  • 1,851 Answers
First of all let's clarify that the wireless connection is between your laptop and the router, not between laptop and desktop. The router is the device that gives the data at the computers in order to view them as pictures e.t.c. The report from your laptop means that the wireless connection is not established. This is because either the distance between laptop and router is long, or someone has switched off the laptop's wi-fi. At the front panel or with a key combination (usually Fn+F2) the wireless connection can be manually switched on - off. Try to locate this switch and turn it to on position.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Posted on Sep 07, 2010
  • Stelios
    Stelios Sep 09, 2010
    I'm happy that you solved your problem using FiXya.
    Thanks and regards
    Stelios
    direct fixya link:http://www.fixya.com/users/technical114
  • gzhao537
    gzhao537 Jan 02, 2013
    Fn+F2 worked! Thabks.
I have a question HP Pavilion DV5 Full
That is you WLAN card (Wireless locale area network card) it is what makes the laptop conect in hotspots.
Oct 23, 2013 | HP New Pavilion DV5-1000 DV5 Series Silver...
I purchased a SBG901 and have connected 2 MAC pc's wireless - 1 HP printer and 1 Compag laptop, I have one more pc which is running Vista on a HP Pavilion dv5 and visited the HP website to update
It might not be anything your doing wrong, the wireless portion of the card may have just gone bad. you could check this out by reconnecting your old router back up to verify it works or doesn't. If it doesn't work your wireless in your laptop went bad presuming that the wireless was not deactivated on the laptop. if it does work the Vista Driver may be incompatible with the new router, you may be able to hook up both routers at the same time which would allow you to keep using your HP system.
Feb 28, 2012 | Arris SURFboard SBG901 Wireless Cable...
I have a HP PAvilion dv5-1125nr and I recently encountered a problem where on startup it shows a white screen. I tried looking at it from all angles to see if there was a faint image but there was nothing....
no photos of white screen presented or posted.
is it white in a dark room???????????
DV5-1125nr (9 years old (first made date) RTC COIN cell time? sure. page 59 tells you how.
http://h10032.www1.hp.com/ctg/Manual/c01550108
lacking any photos , it be impossible to fix this talking in text box.
no?
as they say ,seeing is believing, what you call white I call black.
white on sunny beach, or black in dark room, can be the same.
PAvilion dv5-1125nr
always post what a pC does in the dark, its best.
all text seen , all logos seen (hp or compaq)
any boot screens, any log in screens.
and if the "hit F10 key to enter HP setup" is missing on said screen as seen now for 9 years running.
if that text is missing,
remove the big battery in rear of LP,they short, so get it out now
and first., do that first. always,,,
then run on AC power,
do the HP long reset? (battery out, ac pack pulled
push power button 10 to 30second, not use the ac pack only
it can run on AC forever, end ever , no problems.
do so now.
got that that 9 year old text now? in the dark, ok?
The F10 is BIOS hot key, power on and quickly hammer F10
bingo for BIOS. see that? see those screens, those are first.
if BIOS is dead, it can not boot any OS made.
BIOS does the booting job, see?
here is your support page. at HP, Fixya is NOT HP. so....
https://support.hp.com/us-en/product/hp-pavilion-dv5-1100-entertainment-notebook-pc-series/3744201/model/3795325/manuals?jumpid=reg_r1002_usen_s-001_title_r0001
this OLD PC, is CCFL back lighted, all are.
2010 year is the magic hear we went to LED backlamps.
but your PC is 2008, see?
CCFL do these things
dim, go yellow, do dead, go intermittent and blink(strobes)
if dim, AS I SUSPECT , then its that. (brightness set to max)
CCFL tubes are 99% caused
the HV inverter is 1%
here is the tube sets.
https://www.ebay.com/itm/CCFL-Backlight-for-15-4-LCD-HP-Pavilion-dv4400-dv5000-dv5100-dv5-1000-1100-1200/401259562873?hash=item5d6cef0779:m:mcD2SCb17BxyIvQPKdpd78A
here is the inverter (high voltage inverter for HV CCFL tubes)
https://www.ebay.com/itm/HP-Pavilion-dv5-1125em-dv5-1125eo-dv5-1125es-dv5-1125nr-laptop-LCD-inverter/121175375836?epid=1758409030&hash=item1c369d7fdc:g:CXEAAOSwRbtaAU5l
if you tell what it does in the dark , all things
good or bad,.
answer get 10x smaller, or in fact , dead accurate.
why not just get it fixed by a tech.
all old laptops do this, EVERY SINGLE ONE.
Dec 14, 2017 | HP Pavilion dv5-1125nr Notebook
My HP DV5 1159se was working fine last night and then this morning I go to turn it on as usual and a blank white screen comes up. The start tones are the same and I could even type my password in to log on...
If the inverter board or the back light behind the screen were bad your display would be blank, "but windows would be visible barely" the white screen indicates a bad LCD and must be changed. It is also possible the video cable from the motherboard to the screen has come loose and will need to be reseated back into place to fix it.
Mar 23, 2011 | HP Pavilion dv5-1159se Laptop
I have a pavilion dv5 the wireless touch button is not working but all other button are working how to turn the wireless from the laptop itself without an external swith or touch button , ps: dv5 have only...
dv5 what , use the full model number.
what OS are you running, windows what?????
Why not get the correct HP drivers for wifi features.
from , drum roll..... HP?
ask here this is HP.
warning they wont help unless you answer the 2 questions above.
https://h30434.www3.hp.com/
Jun 20, 2017 | HP Pavilion dv5000t Notebook
How to change the screen on a hp pavilion dv4-1465dx laptop
A) Remove all electrical sources; The AC adapter (Charger) and the Battery.
B) Obtain a multi-compartment container for the screws you will remove. There are screws which look alike, but aren't. You won't realize the mistake until you have the screw in halfway, it is then stuck, and CAN'T remove it. Gives you a warm fuzzy feeling all over.
You can use a clean egg carton in a pinch. Label each egg holder for what area the various screws came out of.
C) Suggest you buy, and wear an ESD wrist strap. (Electro Static Discharge) They cost from $3 to $8. The area you are going into is relatively safe from static shock, as there are no hardware components that are nearby, and prone to Static shock, BUT, it never hurts to be safe.
Static WILL fry out (Short Circuit) the hardware components of a computer, (Laptop or Desktop)
You probably won't see it, or feel it.
Connect the alligator clip to a good ground source. I connect to the metal frame of an empty desktop computer case.
D) I don't find a Service and Maintenance Guide on HP Support, but the information from this link should do very nicely,
1) http://www.insidemylaptop.com/remove-lcd-screen-from-hp-pavilion-dv5-laptop/
It's a dv5 series, but you'[ll find it crosses over to your dv4 series quite well.
Scroll down the page.
Oct 07, 2010 | Computers & Internet
Hp pavilion dv5, flickering screen problem mostly when 26" external monitor is connected, Using Windows Vista 32bit
First restart the computer and tap f10 key on keyboard to enter bios, and check wethere the screen flickers or not you can even try to tilt the screen and check as the drivers doesnt works in bios screen ... if the screen flickers then it is a hardware issue .. if it doesnt then log on to safe mode with networking by pressing f8 as the notebook restarts and then go to device manager by typeing device at the start search and the uninstall the video driver and then reinstall it from hp.com support and drivers ..issue will be resolved if not then do a bios update from hp.com, support and drivers.
Apr 29, 2010 | HP Pavilion DV5-1000US Laptop
Laptop Cannot Find Home Wireless Network
Try logging into the router with your desktop hard-wired and find the 25-digit passcode and use that to log on to the wireless network with the laptop. If not, then check if connection is good by hard-wiring the router to the laptop. Let me know what happens or if you have solved the problem.
Mar 22, 2009 | HP Pavilion a1320n (882780261747) PC...
HP dv5-1160us can't get online. wireless switch off.turn on how
it is the wireless looking light on your laptopn yout laptop havs touch sensors if the wireless light is red then the wifi is off if it is white then it is on.. just touch it to trun on or of.
Mar 19, 2009 | HP Pavilion dv5-1160us NoteBook Intel Core...
HP Pavilion dv5-1160us NoteBook Intel Core 2 Duo P7350 15.4' Wide XGA 4GB Memory 320GB HDD ... Logo
139 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
