No. I have a Quasar TV, Model TT6267AW, Dynacolor 155 channels.\r\nit makes a popping sound that throws waves or rays that you can feel on your body. I have basic cable.
jomaru
  • 337 Answers
SOURCE: Can receive only channels 1 thru 27 although connected to cable with 70 channels.
First you need to check if your set is in the cable mode and not antena mode,if the set is in cable make sure is in the standard cable mode and not another type of cable like HRC,if it is change it and try the autoprogram to set the available channels.I hope it helps.
Posted on Sep 13, 2006
  • 125 Answers
SOURCE: Quasar VV-2001 TV/VCR combo - msg: Check Antenna Cable Connection
Check first the antenna using another TV. If there is no other TV available, check using an ohmeter. If you are 100% sure tha the antenna is ok then the antenna connector on your Tv is not making a good connection to the antenna plug.
Posted on May 24, 2007
  • 346 Answers
SOURCE: quasar tv/vcr
try this code--003,or 070
Posted on Dec 26, 2007
  • 927 Answers
SOURCE: hitachi ultrascan HD tv 43 inch
Good Day;
If you don't hear the relay click suspect Q003. No power suspect Q912, Q914 & I901. Good Luck, big IRISH.
Posted on Sep 06, 2008
SOURCE: Panasonic 32LX70, I have basic cable and the sound
I have the same issue. Its not the cable because all the other tv's are fine when tuned to those channels....Any luck?
Posted on Mar 23, 2010
Quasar tv # sp3220v video/sound input dont work
Are you sure it is on the correct channel or on input, AUX? I would check your manual and see what channel it goes on. If it's on the right channel the connectors on the tv may be broken or the dvd player is broken.
Oct 27, 2012 | Quasar Televison & Video
I have a Quasar TV that has worked perfectly fine until the other day. Picture is fine, but no sound. The speaker volume is on.
Check all your channels. If you are getting sound on some channels but not others it is a good possibility that your SAP setting is turned on. Simply go into your audio menu and disable the SAP. Not sure about your model tv but some Tv sets had a switch on the back to disable the speakers and some have a setting in the menu to disable the speakers. If you have a digital cable box hooked to the tv it is possible the cable box volume is turned all the way down which will override your tv volume. Check these options and hopefully one of them works for you.
Jul 10, 2010 | Quasar SP-3235 32" TV
I need a manual for a Quasar VV-1305 TV. I
I have a quasar model vv1305 t v -vcr combo. the vcr loads and ejects the tape, but when you try to play or rewind it prints on the screen vcr lock activated . need help
Apr 11, 2010 | Televison & Video
My t.v changes single the channels, if I am seeing a channel the minute changes to another one
Just a word of thought. Make sure your remote control is not pointing at the TV. Ive seen this many times. A faulty remote control sending out random signals to the TV due to fluid spillage in the remote. Try keeping the remote well away from TV and see if it still changes channels. If not, check the channel up and down buttons on your TV. Do they feel faulty when compared with volume buttons etc? If so, you might have a channel button on the TV that is half stuck in. Hope this helps :)
Feb 14, 2010 | Quasar SP-2723 27" TV
Won Quasar TV Model W-2009 (I think that's right model #) but have no manual or instruction with it!
Hi Mel is the manual all you need or do you have a specific question.
thank you
Ray
Dec 28, 2009 | Quasar TP-2009D 20" TV
What channel to use for my dvd
all depends how u have it hooked up if going thru your rf tuner pobally channel 3 if pluged into video
you will need to be on video that is the yellow for video red and white your sound
May 03, 2009 | Quasar SP-2725 27" TV
Connecting older model quasar to dvd/vcr player (magnavox)
Hi and welcome to FixYa,
Initially, the only reason you would need/use a modulator is when the DVD/VCR has no RF OUT and the Quasar TV has no Audio/Video IN. If this were the case, then connections would be:
  • yellow Video Out of DVD/VCD to yellow Video IN of modulator;
  • red/white Audio Out of DVD/VCR to red/white Audio In of modulator;
  • modulator RF Out to RF/ANT/CABLE IN of the Quasar;
  • TV has to be set to either Channel 3 or 4;
  • if Modulator has no RF OUT but instead has a small antenna, still the TV has to be set to either Channel 3 or 4.
If however, the DVD/VCR has an RF OUT, then a coaxial patch cord from this could be connected to the RF/ANT/CABLE IN of the Quasar. The TV has to be set to either Channel 3 or 4. There would be no need for the modulator.
Good luck and Thank you for using FixYa.
Jan 03, 2009 | Televison & Video
Record tv
The VCR will have to be on channel 60 as well in order to record a program. Hope this helps....accordianman
Apr 25, 2008 | Quasar VHQ400 VHS VCR
May 24, 2007 | Quasar VV-2001 20 in. Combo
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
Electro Med Services...
