Question about Linksys WRT160NL Router
MY WRT160NL ROUTER SPEED SLOW DOWN AFTER A DAY OR TWO
I have the same problem. I don't know a permanent solution other than throwing it away, but if you pull the power on it, wait for a minute and then plug it back in, it regains speed.
Posted on Dec 19, 2010
I have a D-Link wireless router DIR-655 with 4 computers on a home-based network. Everything worked fine for 9 months at good speed. All of a sudden the internet is extremely slow. My test between my cable...
Get your router a security key(password) just in case your neighbors are use it.
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
Feb 11, 2011 | D-Link Xtreme N DIR-655 Wireless Router
Slow connection
Your router has small NAT table and this slow down your Internet connection. You can solve router slowness with Router Commander software. This software accelerate your router using dynamic NAT feature and other technologies that speed ups router. You can get it from www.routercommander.com . Good Luck.
Nov 03, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Wireless Repeater Question
Well, it is not possible to configure wireless repeating between WRT160NL and WNDR3700 as WRT160NL does not support wireless repating feature (WDS).
Hope this answers your query.
Regards
Anand
Mar 20, 2010 | NetGear RangeMax Premium Wireless-N...
Linksys wrt160nl wireless router causing e-mail issues
Hmm... That sounds like a port forwarding issue. I take it that you using a POP3 e-mail client since you said your ISP e-mail server sends you your messages? I would suggest that you open up your linksys configuration (the webpage for the settings), click on the Applications & Gaming tab and Single Port Forwarding sub tab. Then, for the first row, select POP3 as Application Name, and your computer's IP Address as To IP Address, enabled it, and click save settings at the bottom. This should hopefully make it work.
Feb 23, 2010 | Linksys Wireless-G WRT54G Router
I have a wrt54g v8 router. Too slow, need to
The firmware will not speed up the router.
If you do upgrade firmware you will have to redo setting as they will be set back to factory after the upgrade.
If you need more speed first make sure its not your computer, or internet connection that is slow.
Think about getting a newer faster router....that one you have there is pretty outdated.
Nov 13, 2009 | Linksys Wireless-G WRT54G Router
Slow
how many kbps router u have if u have then problem the compny give u a boud on the slow speed when u reset your router its take a ip thats ip has a slow speed if its fix then u have change it on DHCP if DHCP is off ur router on fix ip & thats ip is slow taht y u have got a slow speed u have to do this reset your router & reconfiger it your problem will solvs
Jul 19, 2008 | NetGear DG834G Router
Fast browsing slow download!!!
are you connected to a router if you are some times the router will slow the download speed because it has to run throught the router to recignize the ip address every time
Jun 19, 2008 | Paradyne 6211 ADSL2+ Router (6211I1200)
3 PC's networked to BEFSX41 very slow accessing internet
sounds like your internet access is the slow down, not the router. You don't say if you have DSL or CABLE or what.  I'd check there. Make sure you are getting a strong signal.  Hook up one system directly, without the router and check the speed.
Oct 14, 2007 | Linksys BEFSX41 Router (DHBEFSX41)
Netgear router dg834gt
Have look in the router settings for the actual internet connection speeds, as these are a more true reading than the speed check as the speeds can vary at different times of the day and 2 or 3 speed checks can bring different results. your actual connection speed that is showing in the routers settings is the connection you are getting from your ISP. If you are with BT they usually recommend using their latest routers, why i'm not sure, as the only thing i have noted is that the MTU is set at 1500 (Maximum Transmition Units)and in other routers the MTU is automatically set at 1493, so look for the MTU setting and up it if necassary, but not above 1500, also double check all the settings, even put the bt router back in and see if speeds improve, if, you know the BT router is set up purposly for faster connection speeds. Also try checking your speed at a speed test site at a quieter time of day, you will also see different speed check sites give you different speed results.
Jun 18, 2007 | NetGear DG834G Router
Linksys WRT160NL Router Logo
672 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
