Question about Samsung Digimax S630 Digital Camera
New batteries.when i push botton to turn on,it tries then lens doesn't come out all the way out then it beeps and goes back in.
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Sep 07, 2010
I have a samsung S500 and when I turn it on the lens doesn't open or extend and it will beep 3 times and shut off. I have tried new batteries and nothing works. I took it to a camera shop and they
Well, have you ever considered that the lenses MIGHT be defected? If it's true, you can send it back to the manufacturer, as long as it wasn't YOU who made it defected.
Another tip, is maybe the lens isn't made for that type of camera.
Lastly, the lens can just be broken, so you should carefully examine it, and see INSIDE of it, to make sure all of the parts are their. Hope this helps (:
Jun 11, 2012 | Samsung Digimax S500 Digital Camera
The lens on my samsung camera keeps getting stuck. When I turn it on it it beeps a few times and nothing happens,the lens doesnt open or anything. Before that it would justt beep and the lens would not go...
Make sure you have installed freshly charged batteries on your Kodak Camera. If you already have but problem still goes on, then try to do a little fix.
With your camera turned OFF, hold the camera on your right hand with the lens facing the ground. Then hit the camera's base on your left palm as you push the button to turn on the camera. You might have to do this a few times. What happens is that there could be a grit of sand that got stuck between your lens' barrel and the camera's base, preventing the lens to retract freely. If the above solution does not work, you might want to apply a bit of force by twist-pushing the lens inside with your index finger while trying to turn on the camera. The idea here is to remove that grit out of the camera.
Please let me know how this goes. Thank you for using FixYa.
Jan 22, 2011 | Samsung Cameras
We have a Fortress Scientific 2000 electric scooter that hasn't been used for several years. We put in new batteries, it shows fully charged, comes on and has a steady beep, but won't go forward or...
Your break release shifter is in the push the scooter mode. Put it back in gear and the horn doesn' beep and it should run..
The horn beeping is the alarm to tell you the break release is on.
It is usually located under the seat on the body of the top of the battery housing. Looks like a stick with a ball on it.
Oct 03, 2010 | Electric Mobility Mobility Electric Power...
Won't stay on even with new batteries- it beeps then turns off
my camera is doing the exact same n i'm hunting the net right now for some kind of solution!! :( i think its something to do with the lens, mine was completely stuck, but i gently pushed it n it went back in and moves in and out fine, but the cam still comes on for a couple of seconds makes this wierd beep n goes off again!
May 27, 2009 | Samsung S760 Digital Camera
Samsung NV10 heeelp!Pleeease
Not sure about the battery... that could be it and I haven't tried switching it out for a new one yet, but in the meantime I am getting around this problem my grabbing the lens with my fingers and "helping" come all the way out... just give it a little pull, a little encouragement and it will come all the way out... but the trick is that you have to do it right after you try to turn it on and before you get the beeps...
So if your lens is stuck out right now and the camera is powered off, then turn the camera on and then pull the lens out before you get the beeps... once you give it a little tug, the mechanics should take over and it will extend all the way... the LCD will come on and you'll be good to go...
Like I said, I'm having this problem too and my girlfriend suggested we change the battery... I guess that's possible, that the battery is not holding enough of a charge to push the lens all the way out... I'll investigate how much a new battery costs and then determine if I think its worth a try...
Jul 10, 2008 | Samsung NV10 Digital Camera
Lens stuck open
try little rubbing alcohol around outer surface of lense this should loosen up the sticky ness of it
remove the memmory card and turn on this should reset camera
May 13, 2008 | Samsung Digimax 4500 Digital Camera
Okay
Your lens is definately broken.
Does the lens stand out in a funny position?
If it does try grabbing hold of it and twisting it slightly while trying to push it back in a correct position.
These camera models do not have lens units available as a service replaceable part and you take it back to the manufacturer they might give you discount on a new model.
Good luck.
Feb 16, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
My Samsung S850 Wont Turn On
cameras beep when it has a problem. most likely the lens get stuck or lens gear failed or motor drive gear to lens, or allot of other problems like it doesnt reconize the optical sensor.
look online for the beep codes and problems.
ty
hope I helped
Jan 27, 2008 | Samsung S850 Digital Camera
Sumsung digimax
get a butter knife or any thin object like that and use it to push out the lens and turning it on at the same time you will hear a clicking noise which is normal once completely out, use your hand with a gentle but firm presure move it form left to right
and then hopefully it should work after that
x
Jan 14, 2008 | Samsung Digimax S500 Digital Camera
It turns on but then turns off
You need new batteries... My camera did the same thing
Dec 15, 2007 | Polaroid I533P Digital Camera
Samsung Digimax S630 Digital Camera Logo
231 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
