Question about Rheem Water Heater LP Gas Valve
I have a Rheem water heater for a spa. Lately it's been intermitant whether it goes on not. Someone suggested that the gas company needed to install a lager meter/regulator as the heater isn't getting enough gas. I had that done last week and there's no change. Another person says I may have water in the gas line. Your thoughts?
    Scholar:
  • 122 Answers
Did the gas company check the pressure?
propane = "11" to 13" water collumn
natural gas = 3" to 4.5" water collumn
I have actually had the valve go bad, replaced, everything worked great.
also check the thermocouple. this is a cheap repair and the most common problem. if this doesn't solve the problem, then I would replace the gas valve. it is rare, but they do go bad. even had a bad one on a brand new water heater.
as far as water in the line, this too is very rare.
Posted on Sep 08, 2010
  • leftygrove Sep 08, 2010
    Yes, confirming that water in line is very rare. My guy told me he's seen it now twice in 25 years! Lucky me.
How Do I restart the rheem 81v30d
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
http://waterheatertimer.org/How-to-light-gas-water-heater.html
Rheem does not post service manuals.
One reason is that water heaters have changed rapidly last few years, and same model might have different features because Rheem experiments to see which products work after they are sold.
Calls to Rheem for DIY help are largely useless since they want you to call local installer or technician... who will sell you a new heater for more money.
Rheem wants to end DIY repairs since doing it yourself saves you money... which means Rheem, and Rheem-loyal service companies make less money.
http://waterheatertimer.org/Which-is-best-gas-water-heater.html
http://waterheatertimer.org/New-government-water-heater-standards.html
Gene
New government water heater standards
Feb 12, 2015 | Rheem Water Heaters
Rheem water heater pilot lite stays lit, burner goes out
Tripped FV or TRD, or bad gas control valve, low gas pressure, air in gas line.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Unfortunately, Rheem does not post service manuals. Other companies post service manual, but only Rheem uses TRD FV system, while other companies use arrestor screen.
http://waterheatertimer.org/How-to-repair-Rheem-TRD.html
Add a comment and say what you discover.
May 24, 2013 | Rheem 42V75F Fury Heavy Duty Natural Gas...
I have a paloma tankles water heater model #ptg-42pvn i am getting an intermitent error code C4,12. what is the problem?
Copy following link for Rheem-Paloma tankless troubleshoot and error codes:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://waterheatertimer.org/How-to-install-gas-water-heater.html#install
If unit worked before: Maybe bad PC board. Maybe lack of required yearly maintenance.
Common error codes can be caused by not following maintenance protocol such as cleaning combustion parts, checking gas pressure, checking venting, and air intake, bleeding gas line etc.
Too bad Rheem-Paloma manuals do not show HOW to conduct this maintenance, leaving customer with many unknowns, and no way to oversee that maintenance performed by hired technician is complete, and matches recommended maintenance.
Sell unit on ebay, and install tank-type gas water heater.
Mar 20, 2013 | Rheem Paloma PTG-42PVN / RTG2-42PVN...
Rheem rtg-53pvn will not turn on and heat water when hot water is turned on - no error code - remote just goes off like the power is off
Before calling service technician, open following link for Rheem troubleshooting resources including Rheem chat:
Rheem will suggest you catch up on required yearly maintenance which would cover most causes for common error codes, and cover cause of no error code including plumbing problem or loose wire or PC board failure. Combination of problems can also cause failure and these issues would be covered by general maintenance.
Solve most tankless problems same day for $350
Jul 21, 2011 | Rheem RTG-53PVN Indoor Natural Gas...
High water in basement, the push button temp indicator reads both leds lite on both ends. i dont know who to reset
1) Call service technician.
2) If water heater flooded, contact insurance company for possible replacement coverage.
3) Manufacturer's suggest replacement of any flooded water heater.
4) Be very careful around wet or previously wet water heater.
Insulation inside tank will stay wet. Household electricity is grounded to water pipes that are connected to gas or electric water heater. Touching wet water heater can be fatal.
5) Read label on side of tank for product identification.
Read manual for possible part replacement.
http://www.rheem.com/product.aspx?id=772AB3A7-6282-4A0B-8657-21977DFB57E3
http://globalimageserver.com/fetchDocument.aspx?id=4e20f58c-94ce-4ac5-8971-9337178fb90f
http://waterheatertimer.org/Water-heater-manufacturers.html
Apr 20, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Intermitant failure of waterheater to turn on when demand is created, then at other times there's no problem. lately it fails to resond more than it works.
Open following link for Rheem/Paloma/Richmond/Ruud tankless troubleshoot resources including error codes, self help, manuals, parts links, tips, and contact information.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 27, 2011 | Rheem Paloma PTG-74PVP / RTG-74PVP Liquid...
I have the rheem pronto in one of my rentals and the water is cold all the time. Help!!!
3 items possibly:# 1) has that gas company turned off the gas lately to do some work?,and then re-fired the water heater after the work was completed? if so,check the temperature setting on the unit,as most gas companies upon re-start of gas appliances on their line will just set them to LOW,so as not to have an insurance issue with a scalding problem(from someone setting it TOO HIGH) if set above LOW temperature./ # 2) it could be limed up in the bottom and not have the capacity anymore to heat the full capacity of the unit due to this issue & needs shutting down and draining and a fresh re-fill. / #3) if the unit won't fire after the pilot has been lit(held down to keep lit) and then turned to a heat setting from pilot,you can have a defective thermocouple temperature sensor in the flame not letting the gas valve open fully to heat the unit
Jan 25, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Noisy Rheem 16 instant hot water heater
About the only device in that heater that could cause the noise you describe is an electrically operated valve that controls water flow. Rheem is a better-than-average company so I would give them a call and describe your problem to them; I'll bet that they will be glad to tell you which part you need and supply it to you.
We had a heat pump system from Rheem that needed only the replacement of one large relay and the outside unit fan motor during more than 25 years of service and is still operating at age 30 in our former home.
Oct 03, 2009 | Rheem 81VP6S/430126 Water Heater
Rheem Water Heater LP Gas Valve Logo
51 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
