Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Scales floating in water
I noticed floating particles (look like clear scales) in the water being dispensed, so I changed the filter at the bottom of the fridge. The water being dispensed still has lots of floating particles that look like clear scales. How do I fix this please?
    Genius:
  • 1,073 Answers
Purge the water in the door for 3-4- mins. and replace the filter
Posted on May 16, 2008
Water dispenser beep-beep
I am wondering about the hose you shoved in and the leak stopped. Is the hose you pushed in buckled where it hooks on or is there a buckled spot where the water comes out of the fridge. Just a guess.
Mar 03, 2017 | Hotpoint HSS25GFP Side by Side...
Black & White Particles in Water
Those filters are behind the grill, down at the bottom of the refrigerator. You will need to turn it 1/4 turn, counter-clockwise then pull out. With your make and model number go to Lowes or Home Depot and get a new filter. After installing it take the time to run about 5 gallons of water through it before using for drinking water. (This clears the filter of an anti-microbial agent used during manufacturing.) This will fix your problem.
If this is helpful to you, please take a sec to rate me. Thanks!
Don
Apr 04, 2012 | Refrigerators
I have a side-by-side ref. It use external filter. I notice that water out of filter (before going into ref) is clear but when I collect water from water dispenser of my ref is cloudy and some very tiny...
was the outside filter factory? by this I mean does the unit have an internal filter ? if no, then you need to flush the system, clean the outside dispenser components, lime or rust has accumulated on the dispenser if the water from the outgoing side of the filter is clear ( is the ice clear and fed by this same water source? if so,, its just outside build up that needs to be cleaned
Jul 03, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
We changed the filter to the water dispenser but
run about 2 gallons of water through the filter, if it did not help - the stuff is coming out the tubing between the filter and the dispenser. Check water hardness. If you have water softener, make sure it works properly.
Apr 11, 2010 | Whirlpool ED2FHGX Side by Side...
Jenn Air fridge water dispensor stopped working
Hi: You press the switch and it makes a faint humming noise. That tells me the switch on the front panel is ok. The switch for the ice and water is actually on the bottom of the ref. The internal system of the ref is not under city water pressure. Ice is made so that's ok. There is a solenoid where the water attaches to the fridge down below which can fail. Just for giggles try tapping the switch with the plastic handle of a screwdriver. To loosen any scale that might have built up. As I'm unemployed also I'm giving you that trick. Otherwise I would just say replace it. I hope this helps, Jeff
Jun 09, 2009 | Jenn-Air JBR2088HES Stainless Steel Bottom...
Whirlpool Side by Side- semi-translucent tape likedebris in water
Sounds like the plastic from the icemaker is chipping off the unit in the ice making process.
If your water is running clear except through the refrigerator that is my suggestions. Although normally the plastic color is blackish.
Jan 12, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
WAter dispenser stopped working
Change the filter in the refrigerator. ..just change it..
Is there something wrong with the kitchen faucet?..
drinking bottled water..??.. are you drinking ACID RAIN??.... think not...??
read this:
Acid Rain Students Site PH Scale
now read this..
Analyzing Comparing Brands of Bottled Water
Oct 11, 2017 | GE CleanSteel GSL25JFTBS
Particles in ice cubes
Most new water/ice systems have break-in procedures in the manual, including flush a couple gallons of water through the water dispenser and disposing the first 24hrs of ice.
Are the particles present in the filtered water before adding ice? If so, you can probably assume the contamination is from the water tank so you should flush several gallons of water through the system to get rid. If the particles are present after adding ice, try pulling out the ice bin and dumping the ice.
Dec 30, 2008 | Whirlpool ED2FHEXN Side by Side...
Water does not dispense from door
I found that the door on the GE side by side doors are not accessable and cannot be repaired if a water line inside the door is defective. The entire door must be replaced at a cost of almost $370. The problem, which seems to be quite common relative to the lack of water at the dispenser, is the result of the water tube in the door freezing due to excess cold levels in the freezing compartment. This is probabley due to poor insulation around the water line as in exits near the ice dispenser gate. The solution is simple, lower the freezing level and use water frequently to keep it from freezing. Also, keep the lines clean by changing the filter often if the local water source is laden with particulates. I think GE should foot the bill for changing doors or re-engineer the doors to access the area where the water line makes contact with the cold surface of the inside panal.
Nov 11, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Particles floating in whirlpool filtered water.
okay - we have had this same problem for around 6 weeks - We called a service repairman to come out and he said that these "floaties" are harmless bacteria. We should disconnect the filter and flush the system by using 1 gallon of water a day (wasting it) after the chlorine in the water is allowed to build up again then the "floaties"- bacteria- will go away---- gross :-( We will see if it works---
Oct 16, 2007 | Refrigerators
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
812 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
