Question about Acer Computers & Internet
Computer won't book, have restore disc copied to usb drive, have changed F2 settings to boot from usb, won't reboot.
    Genius:
  • 1,478 Answers
When Windows fails to boot it is normally caused by a user installing a program or device and it has caused a conflict with one or more other programs. This will no doubt give you plenty of heartache if you're not certain which program caused Windows to not boot up.
If you recently installed a program or application and know where it was installed,you may be in much better shape as for as correcting the error. Here are common ways to correct the problem of your computer not completely booting up or not booting up at all.
To correct the problem of your computer not booting up,type in "fdisk /mbr" and press Enter to restore your master boot record.Type "Scandisk C:" to check the hard drive for errors that have occurred. You can also type "Sys C:" to hopefully restore files needed to boot up your computer.
THIRD......If the above procedures fail to repair your computer,you can repeat the first part of step one above and select "Start Computer With CDROM Support" re-install Windows. once you are able to re-install windows, the problem should be fix.
Take care.
Posted on Sep 07, 2010
Just install new hard drive in my laptop....old one frozen. i have an activation key for windows 8.1 pro. how do i install new operating system?
Boot from your installation disc. Insert the installation disc into your optical; drive, and reboot your computer. Normally a computer boots from the hard drive first, so you will need to adjust some settings in your BIOS in order to boot from the disc drive. You can enter the BIOS by hitting the designated Setup key during the boot process. The key will be displayed on the same screen as your manufacturer's logo.
  • Common Setup keys include F2, F10, F12, and Del/Delete.
  • Once you are in the Setup menu, navigate to the Boot section. Set your DVD/CD drive as the first boot device. If you are installing from a USB drive, make sure that the drive is inserted and then select it as the first boot device.
  • Once you've selected the correct drive, save your changes and exit Setup. Your computer will reboot.
Oct 31, 2016 | Computers & Internet
Labtop won't turn on
Turn on, hold F8 button down until boot menu appears. Download Norton Boot Recovry to disc from another computer. Install in ur CD/DVD drive. Boot ur computer. Or install ur operating system disc in cCD rom drive. Reboot computer, hold F2 button down, modify BIOS boot sequence so CD Rom in 1st boot device. Boot computer, repair or reinstall operating system.
Sep 08, 2012 | Toshiba Satellite L355D-S7813 Notebook
I have a Medion Akoya E5211 laptop that won#t reboot
How far through the boot process will it go? What version of windows are you running?
To get your data off the hard drive you have a couple of options. The easiest is to take the hard drive out and mount it as a second hard drive in another computer, then simply access the drive from windows and copy your data.
If your laptop is more than a couple of years old (has a pata drive) or your computer does not have an open sata port, then you can use an adapter like this to connect it to any computer with a USB port.
If you don't want to remove your hard drive (and you have a spare usb thumb drive laying around), then you can make a bootable usb drive to boot your computer and copy your files either to another networked computer, or to a usb memory.
To do this, go to http://www.ubuntu.com/download to get a copy of ubuntu linux... click on the "Try it from a CD or USB stick" option.
On the page that opens, under step 1, click on start download to begin downloading the latest version of Ubuntu. You'll probably have better driver support with the 32 bit version.
Then go to step 2. Select "USB Stick" and click on "Show Me How" and a fold out will open with more instructions.
You will be asked to download a utility to mount Ubuntu on your USB drive (needs to be at least 2GB capacity). Download this utility to the same folder as the Ubuntu installer.
Once Ubuntu has finished downloading, run the utility and follow the rest of the instructions from the Ubuntu download page. Note that the instructions refer to version 11.04, but the current version is 11.10.
If you followed their instructions properly, you should now have a bootable USB drive. Insert this drive into an open usb port on your laptop and start it up.
You will most likely need to go to your bios setup and change the boot options to include USB devices. Make sure it it set to check the usb device before the hard drive, or it will just keep trying to boot to the hard drive.
to get into your bios setup you need to hit a key while your machine is first booting... it should tell you something like "Hit F2 now to enter setup". F2 is the most common key, but it could be the delete or some other key.
Once you set up the bios, save the changes and exit to reboot your computer. It should now detect the USB drive and boot to Ubuntu.
Ubuntu is a linux based OS and has good driver support for newer computers, so you should be able to connect to a wired or wireless lan without too much trouble.
Nov 22, 2011 | Computers & Internet
I need to press a key on my keyboard to start factory recovery
Hi and welcome to Fixya!
In order to revert the machine back to its factory setting, you need to have the recovery disk (if you don't have it, call the warranty support line of e-machines so they can provide it to you).
To restore Windows from your recovery discs, you will need to
insert the first backup disc and enable the F12 Boot Menu via the BIOS Setup
Utility.
1 Turn on your computer and insert the first system recovery disc into the
optical disc drive. Restart your computer.
2 During startup when the eMachines logo shows, press the F2 key to enter
BIOS Setup, where you can set system parameters.
3 Use the left and right arrow keys to select the Main submenu.
4 Use the up and down arrow keys to select F12 Boot Menu.
5 Use the F5 or F6 key to change F12 Boot Menu to Enabled.
6 Press the ESC key to enter the Exit submenu, press the ENTER key to Exit
Saving Changes. Press the ENTER key again to select Yes. The system will
reboot.
7 After rebooting, when the eMachines logo shows, press the F12 key to
open the Boot Menu. Here you can select which device to boot from.
8 Use the arrow keys to select the IDE1*, then press the ENTER key. Windows
will be installed from the recovery disc.
9 Insert the second recovery disc when prompted, then follow the onscreen
prompts to complete the restore.
10 Remove the recovery disc from the optical drive once the restore is
complete. Do this before rebooting your computer.
Hope this helps!
Takasashi
Jul 25, 2011 | eMachines E620-5885 Notebook
How to recover to factory settings
reboot and tap F8 as it's booting. select factory restore from that list then follow the prompts. be aware when you do a factory restore all data will be lost so back up your files if you can
May 09, 2011 | ASUS Eee PC 900 Notebook
Trying to recover from acer restore cds but keeps coming up with the above eror number and telling me to restart computer
Hello
Can you read the that recovery disk in another computer/laptop? If yes,put the CD into the tray When you boot your system hit f12, then select your USB cdrom, and it should boot then.
If no,you have to check the BIOS settings to ensure that "CD-ROM Drive" is set as the first boot device, otherwise the PC will ignore the disc.
press F2 at the acer splash-screen during the boot process, or when you see "Press F2 to enter setup" at the bottom of the screen.
On the main BIOS screen there is a menu along the top.
Use arrow key to highlight 'BOOT' in the menu bar.
Now you see "Boot Priority Order"
Yours probably has "IDE 0" as first boot device,
and "CD/DVD as second boot device.
The first boot device (IDE 0) is already highlighted.
Press 'F6' to swap them round, so that first boot device is
"CD/DVD"
Now press 'F10'
Highlight "YES" at the prompt (may already be highlighted) and press <Enter>
PC will reboot, this time from the CD/DVD drive first.
You can leave the BIOS set like that permanently so you don't have to go through all that process again next time, just don't leave a bootable disc in the drive unless you really want to boot from it.
Apr 12, 2011 | Computers & Internet
No operating system found
Make sure you dont have a CD in the drive or a usb flash drive or external hard drive plugged in and reboot. Sometimes they are set to boot off of other devices than the hard drive, and if that is the case, then it wont find your operating system.
Jan 26, 2011 | Toshiba Computers & Internet
Lost restore disk,want to install oem windows xp. computer doesnt read disk
I assume you're saying that the pc is not booting from the DVD/CD? If that's the case, you
need to go to the BIOS setup, where you need to change the device boot order. It's now
probably set to start running from the hard drive, reason why your DVD/CD is not booting.
To go to the BIOS setup, press the F2 or delete, or whatever key the first POST messages
instruct you to use to go into SETUP mode. Different BIOS manufacturers use different
keys, so you have to be quick and interrupt the boot process using the correct key. If you
fail to determine what key it is, reboot once again, until you see/read what key does the
job.
Next, once you're into the setup screens, look for one set of options called Boot Options
or Boot Order. Read the instructions to learn what keys to use to change the values.
Ensure that the first device accessed is the CD/DVD drive, then whatever else next, etc.
Once that's done, save your settings following the prompts, load your DVD/CD and reboot
again.
That should read the disc and start the installation.
Aug 21, 2009 | Dell OptiPlex 170L PC Desktop
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
