Im using buffalo external hard disk. HD-CE1.OTU2. but when i connect to my laptop it shows 'you have to format this hard disk before you can use it" and it is vry slow when i use it n it always not responding.
    Guru:
  • 689 Answers
Theres a few different types of filesystem the main ones being betwwen Linux and Windows system theres even new ones that are just coming into popularity--so reformat must be with correct type
Posted on Sep 07, 2010
Need to format my portable HD (Buffalo 3.5 500GB Mini-station) before using as External HDD for my TV (LG 42LA6200)?
BUFFALO TOOLS Buffalo Tools is a feature-rich suite of optional software included on many Buffalo Drive-Station and Mini Station storage products. Any or all of the following components of Buffalo Tools may be installed on Windows PCs.
Buffalo's Backup Utility is an easy-to-use and fully featured backup software for Windows PCs and can be used to back up one or multiple computers with a single Buffalo external hard drive.ECO Manager is an energy efficiency tool used to conserve energy and reduce battery consumption by regulating the power usage of the hard drive, cutting power to the drive during extended periods of inactivity.RAMDISK is a simple utility that allows you to create a RAM disk on your Windows PC which creates a small, but extremely fast environment to work on files in.SecureLock software for Windows provides complete control of the data encryption on your Buffalo external hard drive, providing password protection and software data encryption.
Only basic external hard drive functionality is supported with this operating system; some included utilities may not work. The HDD default format is NTFS; to work with Mac, reformat the HDD using Mac Disk Utility.
I would plug it into a windows 7 or Vista and the computer's USB. The computer should recognize it. Click start then computer and find the icon for your drive and right click your Icon. In the drop-down window look for 'format' and that should help you format your drive. is a feature-rich suite of optional software included on many Buffalo Drive-Station and Mini Station storage products. Any or all of the following components of Buffalo Tools may be installed on Windows PCs.Buffalo's Backup Utility is an easy-to-use and fully featured backup software for Windows PCs and can be used to back up one or multiple computers with a single Buffalo external hard drive.ECO Manager is an energy efficiency tool used to conserve energy and reduce battery consumption by regulating the power usage of the hard drive, cutting power to the drive during extended periods of inactivity.RAMDISK is a simple utility that allows you to create a RAM disk on your Windows PC which creates a small, but extremely fast environment to work on files in.SecureLock software for Windows provides complete control of the data encryption on your Buffalo external hard drive, providing password protection and software data encryption.
Oct 21, 2013 | LG 42" 6200 Series LED HDTV - 42LA6200
I can,t record t.v on my buffalo Hd-lb1.otu2 uk external harddrive on my Panasonic tx-p55vt30
the hard drive MUST have a certain type of file to record(save) and your file may NOT be compatible check specs and then you might find answer
May 28, 2012 | Buffalo Technology DriveStation Computers...
Windows 7 won't recognise buffalo hd-ce1.otu2
you might back up your data to another drive if possible
then format your buffalo drive then transfer it back
i have had similiar issues with xp and w7 using usb drives and have found that i have to designate certain usb drives to the computer running windows 7 and same running xp
if i try to use the one designated to windows 7 in my xp get this drive is not formatted do you want to format
although these drives are not buffalo just usb data drives but of large capacity 128GB
make sure the lead/s that attach to your hard drive are securely seated
if your computer came with a motherboard disc the drivers could be on it
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
hope this helps
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Feb 13, 2012 | Buffalo Technology Computers & Internet
Popular issues: problem with Buffalo Technology (HD-CE500IU2) 500 GB USB 2.0 Hard Drive My laptop is no longer recognizing the Buffalo External Hard Drive. When I plug in the USB to my laptop,
HI guys, I found a solution to a similar problem with the buffalo portable HDD that I brought from my friend. I just changed the HDD cable with the cable from Western Digital My Passport HDD and all problems were sorted out. Physically the WD cable is bit thicker than the Buffalo HDD cable. So suspect the cable is the problem. Please check if this is the problem with your Buffalo HDD before formatting. All the best
Indrajit Pande
Dec 27, 2011 | Computers & Internet
My buffalo external hard disk can not read since yesterday, I/O device error. previoous was working fine. Do not know why? my Buffalo external hard disk model :HD-PX320U2
it is a PNP (PlugNplay) device. Try using a different cable to connect to your pc. Should the problem remain, hook it up to a different computer and if it doesn't see the drive, it will be an electronic circuit failure inside the box. The data is still on the hhd but you will have to obtain a new circuit to bring the hhd back online for use.
Apr 13, 2011 | Buffalo Technology (HD-PE320U2/WH) 320 GB...
Every time I connect my Buffalo Hard disk (HD-PE320U2) and try copying data it shows IO device error. I don't know what to do! help me. Formatting did not help!!!!
That error signals the fact that the motherboard can't communicate properly with the controller of the disk. It's a hardware fault and it's unfixable - this disk is dead, replace it.
Feb 07, 2011 | Buffalo Technology (HD-PE320U2/WH) 320 GB...
External Buffalo Hard Disk 500 Gb model no HD-PF500U2/BK-AP not detecting when connnected to a laptop or a desktop PC
Check the usb port function in the computer bios settings and be sure that it is set to yes. Connect properly your external drive. If it has two wire usb connections, use both to obtain the maximum power that will be need by your drive.
Dec 18, 2009 | Buffalo Technology 500GB DRIVESTATION...
Computers & Internet Logo
125 people viewed this question
David Payne
David Payne
