Question about Kenmore 16483 Built-in Dishwasher
My glasses are not coming out clean, they have stuff on them
  • Kenmore Master
  • 43,501 Answers
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Sep 08, 2010
My whirlpool GS6NBEXR refrigerator ice cube maker leaves slimey, flaky residue at the bottom of my glass. What can I do?
Diana, if I understand you ok, the ice you put in the glass leaves slimy residue. So that slimy stuff has to be in the ice cube. Well remove the the ice maker unit and thoroughly clean this ice holder and throw away the ice cubes in the kitchen sink and see if leaves slimy stuff. As for slimy stuff, while the unit is out, check any leaks etc. BTW any smell?
Jan 06, 2014 | Whirlpool GS6NBEXR Side by Side...
When copying we are getting 2 lines down one side of the copies
Only when copying? What about printing? There are a couple possible causes. The easy one to check for is to make a copy by laying your original on the glass. Now make the same copy using the automatic feeder on top. If the feeder copy has the lines but the glass copy does not then the problem is coming from the ADF scanner glass which is the thin strip of glass that is just to the right of the large main glass. If so then just clean the strip of glass with a soft cloth and some glass cleaner. Note that sometimes the stuff that might be stuck to the glass is hard to get off. If BOTH the ADF copy and the main glass copy have the lines then most likely the lines are coming from the drum unit. If you have the copier hooked up for use as a PC printer then does the print from the computer have the lines as well? Then it most definately is coming from the drum unit and you would need to replace it. If the PC prints are clean then the drum is not the cause.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 28, 2010 | Sharp AL 1631 Copier
When i make copies a line appears on the right side of the copy. This problem does not occur when i scan to copy only when the document runs through the feeder
Clean the document feeder scanner glass. This is the much smaller strip of glass that is to the right of the large main glass. This strip of glass is used ONLY when using the feeder. So if you are getting a dark line when using the automatic feeder but not when laying a document on the glass then just clean the strip glass. 100% sure this is your problem. You may need to clean it several times as I have seen stuff get stuck to this glass.
Jun 02, 2010 | Xerox WorkCentre XD120f Copier
Hard build up of cloudy film on glasses and silverware ruined.
Can you try using vinegar on one of the silverware pieces for me and let me know if that helps? Sounds like it may be a hard water issue.
Sep 26, 2017 | Kenmore Dishwashers
How do i clean my lg cookie
Do you or someone you know wear glasses? Use lens cleaner (not the liquid stuff - the stuff that comes in the little wrapper). Do not use paper - it will scratch your screen.
Alternatively, you could check the manufacturers recommendations.
Thanks for your question at FixYa.com
Jan 04, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
Was cooking fudge-hot sugary liquid boiled over onto glass cooktop. I tried to clean, but appears as if glass top has been ruined. It is rough. Tried scraping with razor, but does not help. Used cooktop...
Maybe try white vinegar - apparently you can clean glass hobs with it & it might help dissolve the fudge stuff if you pour it on that. I wouldn't use a razor as you might damage the hob more.
Dec 15, 2009 | Jenn-Air JED8430 Electric Cooktop
Burnt on stains on the inside glass door of my kitchenaid oven
DeBruce Polish should remove those types of problems and also render the surface more "Cleanable". This stuff really works on glass anomalies.
Check out debrucepolish.com.
DEBRUCE METHOD on You Tube
Apr 11, 2009 | KitchenAid 32 in. KECC508 Electric Cooktop
Dirty Ice Dispenser
I am having a similar problem. The black stuff is all over the inside--it's probably mold. Anybody out there with good advice?
Jun 04, 2008 | Refrigerators
Crusty stuff on glasses after wash cycle
I never figured out what caused this problem. I cleaned it and took it all apart, could not find any debris lodged anywhere. However, I solved this problem! I now only use Cascade Complete dishwasher detergent. Has to be the "complete" version of Cascade. No more grit - nice clean dishes now and sparkling glasses.
Jun 01, 2008 | Hotpoint 24 in. HDA2000Z Built-in...
KITCHEN AID KEBC107KSS03 DOOR. REMOVE INNER PANEL. CLEAN GLASS
LOOK WHERE THE HINGE METS THE OVEN DOOR FACING..you will see on the hinge a tab with the door open pull these forward this will lock the hinges do this on both sides then closed the door slightly and lift up the door will come off then you can unscrew the bottom scres to access glass
Feb 22, 2008 | KitchenAid Architect Series KEBC107KSS...
Kenmore 16483 Built-in Dishwasher Logo
41 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
